Base class for fast, thread-safe interface communication providing automatic signal management, connection handling, and high-performance data exchange between Unity and external systems. More...
| void | DeleteSignals () |
| string | State |
| InterfaceState | state |
| new string | ErrorMessage |
| bool | IsReconnecting |
| int | InputSignals |
| int | OutputSignals |
| int | CommCycleMs |
| int | CycleCount |
| int | UpdateCycleMs |
| bool | AutoReconnect |
| bool | DebugMode |
| bool | IsConnected |
| virtual async Task | EstablishConnection (CancellationToken cancellationToken) |
| Establishes connection to the external system. | |
| virtual async Task | CommunicationLoop (CancellationToken cancellationToken) |
| Main communication loop executed each cycle after connection is established. | |
| virtual void | CloseConnection () |
| Closes the connection to the external system. | |
| void | Start () |
| new void | OnEnable () |
| new void | OnDisable () |
| void | FixedUpdate () |
| virtual void | CopyPropertiesToThreadSafe () |
| void | OnConnected () |
| void | OnDisconnected () |
Protected Attributes | |
| int | privateCycleCount |
| int | privateCommCycleMs |
Properties | |
◆ CleanupAfterBackgroundThread()
protectedvirtual |
Reimplemented in realvirtual.FestoInterface, and realvirtual.ManualPhysicsBlueprint.
◆ CloseConnection()
protectedvirtual |
Reimplemented in realvirtual.EthernetIPInterface, realvirtual.FestoInterface, realvirtual.KukaInterface, realvirtual.MitsubishiMcpXInterface, realvirtual.BlueprintFastInterface, realvirtual.BlueprintFastInterfaceSimple, realvirtual.ManualPhysicsBlueprint, realvirtual.PerformanceTestInterface, and realvirtual.TestFastInterface.
◆ CloseInterface()
virtual |
Reimplemented from realvirtual.InterfaceBaseClass.
◆ CommunicationLoop()
protectedvirtual |
Reimplemented in realvirtual.EthernetIPInterface, realvirtual.FestoInterface, realvirtual.KukaInterface, realvirtual.MitsubishiMcpXInterface, realvirtual.BlueprintFastInterface, realvirtual.BlueprintFastInterfaceSimple, realvirtual.FastThreadedInterface, realvirtual.PerformanceTestInterface, and realvirtual.TestFastInterface.
◆ CopyPropertiesToThreadSafe()
protectedvirtual |
Reimplemented in realvirtual.EthernetIPInterface, realvirtual.FestoInterface, realvirtual.KukaInterface, and realvirtual.MitsubishiMcpXInterface.
◆ EstablishConnection()
protectedvirtual |
Reimplemented in realvirtual.EthernetIPInterface, realvirtual.FestoInterface, realvirtual.KukaInterface, realvirtual.MitsubishiMcpXInterface, realvirtual.BlueprintFastInterface, realvirtual.BlueprintFastInterfaceSimple, and realvirtual.FastThreadedInterface.
◆ FixedUpdate()
protected |
◆ GetChangedInputsForPLC()
protected |
◆ GetInputsForPLC()
protected |
◆ IsManualPhysicsMode()
static |
Returns true if any FastInterfaceBase instance has enabled manual physics mode.
◆ OnApplicationPause()
protectedvirtual |
◆ OnCommunicationError()
protectedvirtual |
◆ OnCommunicationStarted()
protectedvirtual |
Reimplemented in realvirtual.FestoInterface, realvirtual.BlueprintFastInterface, realvirtual.FastThreadedInterface, and realvirtual.PerformanceTestInterface.
◆ OnCommunicationStopped()
protectedvirtual |
Reimplemented in realvirtual.FastThreadedInterface.
◆ OnEnable()
protected |
◆ OnInterfaceEnable()
| void realvirtual.FastInterfaceBase.OnInterfaceEnable | ( | ) |
Also called by OnEnable for late-added (dynamically created) interfaces.
Implements realvirtual.IOnInterfaceEnable.
◆ OpenInterface()
virtual |
Reimplemented in realvirtual.FestoInterface.
◆ PostAllScenesLoaded()
virtual |
◆ PostFixedUpdate()
virtual |
Implements realvirtual.IPostFixedUpdate.
Reimplemented in realvirtual.ManualPhysicsBlueprint.
◆ PreFixedUpdate()
virtual |
Implements realvirtual.IPreFixedUpdate.
◆ PrepareForBackgroundThread()
protectedvirtual |
Reimplemented in realvirtual.FestoInterface, realvirtual.MitsubishiMcpXInterface, and realvirtual.ManualPhysicsBlueprint.
◆ ReadChangedInputsThreadSafe()
protected |
◆ ReadInputsThreadSafe()
protected |
◆ RebuildCachedSignalArrays()
protected |
Call this after dynamically creating or removing signals (e.g., after import). Must be called on the main thread.
◆ ResetInputChangeDetection()
protected |
◆ SetManualPhysicsMode()
| void realvirtual.FastInterfaceBase.SetManualPhysicsMode | ( | bool | enabled | ) |
When enabled, disables Physics.autoSimulation and requires manual stepping via StepPhysics(). Interface signal synchronization continues automatically in PreFixedUpdate and PostFixedUpdate. Uses reference counting to coordinate multiple interfaces - physics is restored only when all interfaces disable manual mode.
◆ SetOutputFromPLC()
protected |
◆ SetOutputsFromPLC()
protected |
◆ Start()
protected |
◆ StepPhysics()
| void realvirtual.FastInterfaceBase.StepPhysics | ( | float | timestep = 0f | ) |
Only affects physics simulation - interface signal synchronization continues automatically. Must be called when manual physics mode is enabled via SetManualPhysicsMode(true).
◆ UpdateSignalCounts()
protectedvirtual |
◆ WriteOutputsThreadSafe()
protected |
◆ WriteOutputThreadSafe()
protected |
◆ AutoReconnect
| bool realvirtual.FastInterfaceBase.AutoReconnect |
◆ CommCycleMs
| int realvirtual.FastInterfaceBase.CommCycleMs |
◆ CycleCount
| int realvirtual.FastInterfaceBase.CycleCount |
◆ ErrorMessage
| new string realvirtual.FastInterfaceBase.ErrorMessage |
◆ InputSignals
| int realvirtual.FastInterfaceBase.InputSignals |
◆ IsReconnecting
| bool realvirtual.FastInterfaceBase.IsReconnecting |
◆ MaxReconnectAttempts
| int realvirtual.FastInterfaceBase.MaxReconnectAttempts |
◆ OnlyTransmitChangedInputs
| bool realvirtual.FastInterfaceBase.OnlyTransmitChangedInputs |
◆ OutputSignals
| int realvirtual.FastInterfaceBase.OutputSignals |
◆ ReconnectAttemptCount
| int realvirtual.FastInterfaceBase.ReconnectAttemptCount |
◆ ReconnectIntervalSeconds
| float realvirtual.FastInterfaceBase.ReconnectIntervalSeconds |
◆ State
| string realvirtual.FastInterfaceBase.State |
◆ state
| InterfaceState realvirtual.FastInterfaceBase.state |
◆ UpdateCycleMs
| int realvirtual.FastInterfaceBase.UpdateCycleMs |
Property Documentation
◆ IsInterfaceReady
get |
◆ ShowIsConnectedField
getprotected |
