MitsubishiMcpX interface for high-performance communication with Mitsubishi PLCs using MC Protocol. More...
| async void | ImportDevices () |
| void | DeleteSignals () |
| string | IPAddress |
| PLC IP address. | |
| int | Port |
| MC Protocol port. | |
| int | ConnectionTimeout |
| Connection timeout in milliseconds. | |
| bool | OptimizeBatchReads |
| Enable batch optimization. | |
| int | MaxGapSize |
| Maximum address gap in batch. | |
| int | MinBatchSize |
| Minimum batch size. | |
| int | MaxBatchSizeBits |
| Max batch for bits. | |
| int | MaxBatchSizeWords |
| Max batch for words. | |
| string | GXWorks3CsvFile |
| GX Works3 CSV file path. | |
| bool | UseStandardGXFormat |
| Standard GX format. | |
| bool | CreateDeviceHierarchy |
| Create hierarchy. | |
| bool | ImportComments |
| Import comments. | |
| int | MaxImportDevices |
| Max import limit. | |
| bool | ValidateDeviceAddresses |
| Validate addresses. | |
| bool | ImportPhysicalInputs |
| Import X devices. | |
| bool | ImportPhysicalOutputs |
| Import Y devices. | |
| bool | ImportInternalRelays |
| Import M devices. | |
| bool | ImportDataRegisters |
| Import D devices. | |
| bool | ImportTimers |
| Import T devices. | |
| bool | ImportCounters |
| Import C devices. | |
| bool | ImportStateRelays |
| Import S devices. | |
| bool | ImportSpecialDevices |
| Import SM/SD devices. | |
| string | State |
| InterfaceState | state |
| new string | ErrorMessage |
| bool | IsReconnecting |
| int | InputSignals |
| int | OutputSignals |
| int | CommCycleMs |
| int | CycleCount |
| int | UpdateCycleMs |
| bool | AutoReconnect |
| bool | DebugMode |
| bool | IsConnected |
| new void | Awake () |
| override void | CopyPropertiesToThreadSafe () |
| override void | PrepareForBackgroundThread () |
| Prepares Unity GameObject data before background thread starts. | |
| override async Task | EstablishConnection (CancellationToken cancellationToken) |
| Establishes connection to Mitsubishi PLC. | |
| Main communication loop for cyclic data exchange. | |
| Closes connection to PLC. | |
| void | Start () |
| new void | OnEnable () |
| new void | OnDisable () |
| void | FixedUpdate () |
| void | OnConnected () |
| void | OnDisconnected () |
| int | privateCycleCount |
| int | privateCommCycleMs |
Provides real-time bidirectional data exchange between Unity simulations and Mitsubishi Q, L, R, iQ-R, and iQ-F series PLCs. Utilizes the MC Protocol (MELSEC Communication Protocol) with 3E/4E frame formats for robust industrial communication. Features intelligent batch read optimization that automatically groups signals into efficient read operations, reducing network traffic and improving throughput by up to 30x compared to individual signal reads.
Key Features:
- Automatic address range optimization for minimal PLC communication operations
- Support for all major Mitsubishi device types (X, Y, M, D, T, C, S, SM, SD, W, R)
- GX Works3 CSV import for device comment integration
- Thread-safe background communication with FastInterface architecture
- Automatic reconnection and error recovery
- Batch read/write operations up to 960 bits or 120 words
Common Applications:
- Virtual commissioning with Mitsubishi PLCs
- Digital twin creation for Mitsubishi-controlled systems
- PLC logic testing without physical hardware
- Industry 4.0 integration with existing Mitsubishi infrastructure
Integration Points:
- Works with GX Works3 device comment exports for signal documentation
- Compatible with realvirtual signal system for seamless simulation
- Supports both Editor mode and Play mode signal import
For detailed documentation see: https://doc.realvirtual.io/components-and-scripts/interfaces/mitsubishi-mcpx
◆ CloseConnection()
protectedvirtual |
◆ CommunicationLoop()
protectedvirtual |
◆ CopyPropertiesToThreadSafe()
protectedvirtual |
◆ EstablishConnection()
protectedvirtual |
◆ PrepareForBackgroundThread()
protectedvirtual |
◆ ConnectionTimeout
| int realvirtual.MitsubishiMcpXInterface.ConnectionTimeout |
◆ CreateDeviceHierarchy
| bool realvirtual.MitsubishiMcpXInterface.CreateDeviceHierarchy |
Create hierarchy.
◆ GXWorks3CsvFile
| string realvirtual.MitsubishiMcpXInterface.GXWorks3CsvFile |
◆ ImportComments
| bool realvirtual.MitsubishiMcpXInterface.ImportComments |
Import comments.
◆ ImportCounters
| bool realvirtual.MitsubishiMcpXInterface.ImportCounters |
Import C devices.
◆ ImportDataRegisters
| bool realvirtual.MitsubishiMcpXInterface.ImportDataRegisters |
Import D devices.
◆ ImportInternalRelays
| bool realvirtual.MitsubishiMcpXInterface.ImportInternalRelays |
Import M devices.
◆ ImportPhysicalInputs
| bool realvirtual.MitsubishiMcpXInterface.ImportPhysicalInputs |
Import X devices.
◆ ImportPhysicalOutputs
| bool realvirtual.MitsubishiMcpXInterface.ImportPhysicalOutputs |
Import Y devices.
◆ ImportSpecialDevices
| bool realvirtual.MitsubishiMcpXInterface.ImportSpecialDevices |
◆ ImportStateRelays
| bool realvirtual.MitsubishiMcpXInterface.ImportStateRelays |
Import S devices.
◆ ImportTimers
| bool realvirtual.MitsubishiMcpXInterface.ImportTimers |
Import T devices.
◆ IPAddress
| string realvirtual.MitsubishiMcpXInterface.IPAddress |
PLC IP address.
◆ MaxBatchSizeBits
| int realvirtual.MitsubishiMcpXInterface.MaxBatchSizeBits |
Max batch for bits.
◆ MaxBatchSizeWords
| int realvirtual.MitsubishiMcpXInterface.MaxBatchSizeWords |
◆ MaxGapSize
| int realvirtual.MitsubishiMcpXInterface.MaxGapSize |
◆ MaxImportDevices
| int realvirtual.MitsubishiMcpXInterface.MaxImportDevices |
Max import limit.
◆ MinBatchSize
| int realvirtual.MitsubishiMcpXInterface.MinBatchSize |
Minimum batch size.
◆ OptimizeBatchReads
| bool realvirtual.MitsubishiMcpXInterface.OptimizeBatchReads |
◆ Port
| int realvirtual.MitsubishiMcpXInterface.Port |
MC Protocol port.
◆ UseStandardGXFormat
| bool realvirtual.MitsubishiMcpXInterface.UseStandardGXFormat |
Standard GX format.
◆ ValidateDeviceAddresses
| bool realvirtual.MitsubishiMcpXInterface.ValidateDeviceAddresses |
Validate addresses.
