The base class for all Signals. More...
| string | GetSignalName () |
| virtual string | GetVisuText () |
| virtual byte[] | GetByteValue () |
| virtual int | GetByteSize () |
| virtual bool | IsInput () |
| virtual void | SetValue (string value) |
| virtual void | SetValue (byte[] value) |
| virtual void | SetStatusConnected (bool status) |
| virtual void | SetValue (object value) |
| void | Unforce () |
| Unforces the signal. | |
| virtual object | GetValue () |
| virtual bool | GetStatusConnected () |
| string | GetTypeString () |
| string | Comment |
| string | OriginDataType |
| SettingsSignal | Settings |
| bool | Autoconnected |
| bool | UpdateEnable |
| SignalMetadata | Metadata |
| new bool | hidename () |
Protected Attributes | |
| string | Visutext |
Events | |
◆ GetInterfaceSignal()
| InterfaceSignal realvirtual.Signal.GetInterfaceSignal | ( | ) |
◆ GetMetadata< T >()
| T realvirtual.Signal.GetMetadata< T > | ( | string | key, |
| T | defaultValue = default(T) |
◆ GetMetadataKeys()
| IEnumerable< string > realvirtual.Signal.GetMetadataKeys | ( | ) |
◆ GetStatusConnected()
virtual |
Reimplemented in realvirtual.PLCInputBool, realvirtual.PLCInputFloat, realvirtual.PLCInputInt, realvirtual.PLCInputText, realvirtual.PLCInputTransform, realvirtual.PLCOutputBool, realvirtual.PLCOutputFloat, realvirtual.PLCOutputInt, realvirtual.PLCOutputText, and realvirtual.PLCOutputTransform.
◆ GetTypeString()
| string realvirtual.Signal.GetTypeString | ( | ) |
◆ GetValue()
virtual |
◆ GetVisuText()
virtual |
◆ HasMetadata()
| bool realvirtual.Signal.HasMetadata | ( | string | key | ) |
◆ IsConnectedToBehavior()
| bool realvirtual.Signal.IsConnectedToBehavior | ( | ) |
◆ IsInput()
virtual |
Reimplemented in realvirtual.PLCInputBool, realvirtual.PLCInputFloat, realvirtual.PLCInputInt, realvirtual.PLCInputText, and realvirtual.PLCInputTransform.
◆ OnInspectedToggleChanged()
| void realvirtual.Signal.OnInspectedToggleChanged | ( | bool | arg0 | ) |
Implements realvirtual.IInspector.
◆ OnInspectValueChanged()
| void realvirtual.Signal.OnInspectValueChanged | ( | ) |
◆ OnObjectDrop()
| bool realvirtual.Signal.OnObjectDrop | ( | Object | reference | ) |
◆ OnToggleHierarchy()
virtual |
Reimplemented in realvirtual.PLCInputBool, and realvirtual.PLCOutputBool.
◆ RemoveMetadata()
| void realvirtual.Signal.RemoveMetadata | ( | string | key | ) |
◆ SetMetadata()
| void realvirtual.Signal.SetMetadata | ( | string | key, |
| object | value | ||
◆ SetStatusConnected()
virtual |
◆ SetValue() [1/2]
virtual |
Reimplemented in realvirtual.PLCInputBool, realvirtual.PLCInputFloat, realvirtual.PLCInputInt, realvirtual.PLCInputText, realvirtual.PLCInputTransform, realvirtual.PLCOutputBool, realvirtual.PLCOutputFloat, realvirtual.PLCOutputInt, and realvirtual.PLCOutputText.
◆ SetValue() [2/2]
virtual |
◆ Unforce()
| void realvirtual.Signal.Unforce | ( | ) |
◆ Metadata
| SignalMetadata realvirtual.Signal.Metadata |
