PLC Boolean Output Signal - Represents a boolean output signal from PLC to simulation. More...
| override void | OnToggleHierarchy () |
| void | SetValue (bool value) |
| void | FixedUpdate () |
| string | GetSignalName () |
| virtual bool | IsInput () |
| void | Unforce () |
| Unforces the signal. | |
| string | GetTypeString () |
| StatusBool | Status |
| bool | ChangedToTrue |
| bool | ChangedToFalse |
| string | Comment |
| string | OriginDataType |
| SettingsSignal | Settings |
| bool | Autoconnected |
| bool | UpdateEnable |
| SignalMetadata | Metadata |
Properties | |
| bool | Value [get, set] |
| new bool | hidename () |
| string | Visutext |
PLCOutputBool is a core signal type for receiving boolean (true/false) data from external PLC systems into the Unity simulation environment. This component acts as a digital output point from the PLC that simulation components can read and monitor to react to PLC control logic.
Key Features:
- Receives boolean values from connected PLC systems through various industrial protocols
- Provides real-time value updates with automatic change detection
- Supports edge detection for state transitions from PLC programs
- Includes override functionality for testing and manual control
- Tracks connection status for reliable communication monitoring
Signal Direction: PLC → Simulation (Output from PLC from PLC perspective) The signal flows from PLC controller to Unity simulation, enabling PLC programs to control simulation behavior through boolean states such as start/stop commands, valve controls, and motor enables.
Common Applications:
- Sending simulated sensor states to PLC (photoelectric sensors, limit switches)
- Providing component status feedback (motor running, valve open/closed)
- Signaling operation completion or error states
- Implementing virtual buttons and switches for HMI functionality
- Transmitting safety-relevant information like emergency stop acknowledgment
Interface Integration: PLCOutputBool supports all major industrial communication protocols:
- OPC UA: Writes to OPC UA boolean nodes with configurable update rates
- S7 TCP/IP: Direct writing to Siemens S7 PLC data blocks
- Modbus TCP/RTU: Updates Modbus coil or holding registers
- TwinCAT ADS: Writes to Beckhoff TwinCAT boolean variables
- MQTT: Publishes to MQTT topics for cloud and IoT connectivity
- Shared Memory: Provides high-performance local data exchange
Update Mechanism: The component monitors value changes in FixedUpdate() for physics-synchronized updates. When values change, the EventSignalChanged event notifies all connected interfaces to transmit the new state to the PLC. This ensures minimal latency between simulation state changes and PLC program reactions, critical for real-time control applications.
Virtual Commissioning: In virtual commissioning scenarios, PLCOutputBool signals replace physical sensors and actuator feedback, allowing complete PLC program testing without hardware. The override feature enables manual manipulation of signals for comprehensive test coverage.
◆ GetByteSize()
virtual |
◆ GetByteValue()
virtual |
◆ GetStatusConnected()
virtual |
◆ GetValue()
virtual |
◆ GetVisuText()
virtual |
◆ OnToggleHierarchy()
virtual |
◆ SetStatusConnected()
virtual |
◆ SetValue() [1/3]
virtual |
◆ SetValue() [2/3]
virtual |
◆ SetValue() [3/3]
virtual |
