This object needs to be in every realvirtual scene. It controls main central data (like scale...) and manages main realvirtual settings for the scene. More...
| void | OnEnable () |
| Called when the component is enabled, handles initialization and scene setup. | |
| new void | StopSim () |
| Stops the simulation for all realvirtual behaviors. | |
| new void | StartSim () |
| Starts the simulation for all realvirtual behaviors. | |
| void | Quit () |
| Quits the application. | |
| void | Play () |
| Starts the simulation and sets the time scale. | |
| void | Pause () |
| Pauses the simulation and optionally stops physics. | |
| void | ConnectionButtonToggleOn () |
| Enables connection mode and updates all realvirtual behaviors. | |
| void | ConnectionButtonToggleOff () |
| Disables connection mode and updates all realvirtual behaviors. | |
| void | OnConnectionOpened (GameObject Interface) |
| Called when an interface connection is opened. | |
| void | OnConnectionClosed (GameObject Interface) |
| Called when an interface connection is closed. | |
| new void | ChangeConnectionMode (bool isconnected) |
| void | SetStartView () |
| void | ChangeTimeScale (float scale) |
| void | SetView (int view) |
| void | ActiveateView (int view) |
| void | AddHideGroup (string group) |
| void | RemoveHideGroup (string group) |
| bool | GroupIsHidden (string group) |
| void | ChangeUIEnable () |
| void | MessageBox (string message, bool autoclose, float closeafterseconds) |
| int | GetMUID (GameObject caller) |
| void | BreakTriggeredByStep (rvUIToolbarButton breakbutton) |
| void | ChangedTimeScale () |
| void | OnUIButtonPressed (GameObject Button) |
| void | RemoveMeshGizmo (MeshGizmo lasthovered) |
| void | ResetSelectedMeshes () |
| MeshGizmo | signalGizmoMesh (GameObject obj, float pivotSize, Color meshColor, bool drawpivot, bool drawcenter, bool drawBoundingBox=false, bool drawLabels=false) |
| bool | CheckIfMeshIsHovered (GameObject obj) |
| EditorGizmoOptions | GetGizmoOptions () |
| void | UpdateSignals () |
| void | UpdateConnectionButton () |
| void | OnSceneLoaded () |
| Called when a scene is loaded to perform initialization tasks. | |
Public Member Functions inherited from realvirtual.IBeforeAwake | |
| void | OnBeforeAwake () |
| static void | HideInfo () |
| Hides the info box permanently by saving preference. | |
| static void | DeleteControllerPrefs () |
| Deletes all Unity PlayerPrefs stored data. | |
| static void | TurnOnConnectMode () |
| Enables connection mode and saves the preference. | |
| static void | TurnOffConnectMode () |
| Disables connection mode and saves the preference. | |
| static void | TurnOnDebugMode () |
| Enables debug mode and saves the preference (requires restart to debug from start) | |
| static void | TurnOffDebugMode () |
| Disables debug mode and saves the preference. | |
| static void | RegisterPreFixedUpdateHandler (IPreFixedUpdate handler) |
| Registers a single PreFixedUpdate handler dynamically - optimized with HashSet. | |
| static void | RegisterPostFixedUpdateHandler (IPostFixedUpdate handler) |
| Registers a single PostFixedUpdate handler dynamically - optimized with HashSet. | |
| static void | UnregisterPreFixedUpdateHandler (IPreFixedUpdate handler) |
| Unregisters a PreFixedUpdate handler - optimized with HashSet. | |
| static void | UnregisterPostFixedUpdateHandler (IPostFixedUpdate handler) |
| Unregisters a PostFixedUpdate handler - optimized with HashSet. | |
| static void | RegisterTimeSyncedComponent (ITimeSyncedPhysics component) |
| Registers a component for externally time-synced physics updates. | |
| static void | UnregisterTimeSyncedComponent (ITimeSyncedPhysics component) |
| Unregisters a component from externally time-synced physics updates. | |
| static void | CalcFixedUpdateAll (float deltaTime) |
| Calls CalcFixedUpdate on all registered time-synced components with the given deltaTime. | |
| static bool | IsTimeSyncedPhysicsMode () |
| Returns true if physics is currently being externally time-synced (e.g. by Simit) | |
| static void | BroadcastAll (string fun) |
| bool | Connected |
| Indicates connection status to interfaces for toggling realvirtual components based on active status. | |
| bool | UseDESMode |
| Enable DES mode if DES package is available. | |
| bool | _desPackageWarning |
| bool | _desManagerWarning |
| bool | _desModeDisabledInfo |
| bool | ModelCheckerEnabled |
| Performs model check before starting simulation. | |
| bool | ValidationOnComponentsAdded |
| Enables validation when components are added to GameObjects. | |
| bool | ValidateBeforeStart |
| Enables validation before entering play mode. | |
| bool | StopPhysicsWhenPaused |
| Stops physics when scene is paused. | |
| float | Scale |
| Global scale factor in millimeters for size adjustment. | |
| bool | DebugMode |
| Enables debug mode for development. | |
| float | SpeedOverride |
| Speed override factor for custom speed adjustment. | |
| float | TimeScale |
| Time scale factor affecting animations and physics. | |
| List< string > | HideGroups |
| List of groups to hide from UI. | |
| bool | Restart |
| Enables automatic scene restart. | |
| float | RestartSceneAfterSeconds |
| Restart delay in seconds. | |
| bool | AdditiveLoadScenes |
| Enables additive scene loading in editor. | |
| List< string > | AdditiveScenes |
| Scenes to load additively. | |
| bool | EnablePositionDebug |
| Enables position debugging. | |
| int | DebugLayer |
| Debug rendering layer. | |
| float | HierarchyUpdateCycle |
| Hierarchy update frequency in seconds. | |
| bool | ShowHierarchyIcons |
| Shows icons in hierarchy view. | |
| float | WidthGroupName |
| Width of group names in hierarchy. | |
| bool | ShowComponents |
| Shows component icons in hierarchy. | |
| float | ScaleHandles |
| Editor handle scale factor. | |
| GameObject | StandardSource |
| Standard source object for hotkey operations. | |
| EditorGizmoOptions | EditorGizmoSettings |
| Editor gizmo display settings. | |
| bool | EnableHotkeys |
| Enables editor hotkeys. | |
| KeyCode | HotkeyQuickEdit |
| Quick edit overlay hotkey. | |
| KeyCode | HotkeySource |
| Insert standard source hotkey. | |
| KeyCode | HotkeyDelete |
| Delete all MUs hotkey. | |
| KeyCode | HotkeyCreateOnSource |
| Create on source hotkey. | |
| KeyCode | HotKeyFocus |
| Focus selected object or center all. | |
| KeyCode | HotKeyResetView |
| Reset view to center all. | |
| KeyCode | HotKeyDeselect |
| Deselect all objects. | |
| KeyCode | HotKeyTopView |
| Switch to top view. | |
| KeyCode | HotKeyFrontView |
| Switch to front view. | |
| KeyCode | HotKeyBackView |
| Switch to back view. | |
| KeyCode | HotKeyLeftView |
| Switch to left view. | |
| KeyCode | HotKeyRightView |
| Switch to right view. | |
| KeyCode | HotKeyOrthoViews |
| Toggle orthogonal views. | |
| KeyCode | HotKeyOrhtoBigger |
| Increase orthogonal view size. | |
| KeyCode | HotKeyOrhtoSmaller |
| Decrease orthogonal view size. | |
| KeyCode | HoteKeyOrthoDirection |
| Change orthogonal view direction. | |
| bool | UIEnabledOnStart |
| Enables UI at runtime start. | |
| bool | RuntimeInspectorEnabled |
| Enables runtime inspector. | |
| bool | ObjectSelectionEnabled |
| Enables runtime object selection. | |
| bool | HideInfoBox |
| Hides runtime info box. | |
| GameObject | RuntimeApplicationUI |
| Runtime application UI reference. | |
| GameObject | RuntimeAutomationUI |
| Runtime automation UI reference. | |
| List< GameObject > | LockedObjects |
| List< string > | HiddenGroups |
| List< GameObject > | ConnectionsActive |
| InspectorController | InspectorController |
| new bool | hideactiveonly () |
◆ CalcFixedUpdateAll()
static |
◆ ConnectionButtonToggleOff()
| void realvirtual.realvirtualController.ConnectionButtonToggleOff | ( | ) |
◆ ConnectionButtonToggleOn()
| void realvirtual.realvirtualController.ConnectionButtonToggleOn | ( | ) |
◆ DeleteControllerPrefs()
static |
◆ HideInfo()
static |
◆ IsTimeSyncedPhysicsMode()
static |
◆ OnConnectionClosed()
| void realvirtual.realvirtualController.OnConnectionClosed | ( | GameObject | Interface | ) |
◆ OnConnectionOpened()
| void realvirtual.realvirtualController.OnConnectionOpened | ( | GameObject | Interface | ) |
◆ OnEnable()
| void realvirtual.realvirtualController.OnEnable | ( | ) |
◆ OnSceneLoaded()
| void realvirtual.realvirtualController.OnSceneLoaded | ( | ) |
IMPLEMENTS ISceneLoaded::OnSceneLoaded
Implements realvirtual.ISceneLoaded.
◆ Pause()
| void realvirtual.realvirtualController.Pause | ( | ) |
◆ Play()
| void realvirtual.realvirtualController.Play | ( | ) |
◆ Quit()
| void realvirtual.realvirtualController.Quit | ( | ) |
◆ RegisterPostFixedUpdateHandler()
static |
◆ RegisterPreFixedUpdateHandler()
static |
◆ RegisterTimeSyncedComponent()
static |
◆ StartSim()
| new void realvirtual.realvirtualController.StartSim | ( | ) |
◆ StopSim()
| new void realvirtual.realvirtualController.StopSim | ( | ) |
◆ TurnOffConnectMode()
static |
◆ TurnOffDebugMode()
static |
◆ TurnOnConnectMode()
static |
◆ TurnOnDebugMode()
static |
◆ UnregisterPostFixedUpdateHandler()
static |
◆ UnregisterPreFixedUpdateHandler()
static |
◆ UnregisterTimeSyncedComponent()
static |
◆ UpdateSignals()
| void realvirtual.realvirtualController.UpdateSignals | ( | ) |
Clear Info on all Signals
get all Behavior models
◆ AdditiveLoadScenes
| bool realvirtual.realvirtualController.AdditiveLoadScenes |
◆ AdditiveScenes
| List<string> realvirtual.realvirtualController.AdditiveScenes |
◆ Connected
| bool realvirtual.realvirtualController.Connected |
◆ DebugLayer
| int realvirtual.realvirtualController.DebugLayer |
◆ DebugMode
| bool realvirtual.realvirtualController.DebugMode |
◆ EditorGizmoSettings
| EditorGizmoOptions realvirtual.realvirtualController.EditorGizmoSettings |
◆ EnableHotkeys
| bool realvirtual.realvirtualController.EnableHotkeys |
◆ EnablePositionDebug
| bool realvirtual.realvirtualController.EnablePositionDebug |
◆ HideGroups
| List<string> realvirtual.realvirtualController.HideGroups |
◆ HideInfoBox
| bool realvirtual.realvirtualController.HideInfoBox |
◆ HierarchyUpdateCycle
| float realvirtual.realvirtualController.HierarchyUpdateCycle |
◆ HoteKeyOrthoDirection
| KeyCode realvirtual.realvirtualController.HoteKeyOrthoDirection |
◆ HotKeyBackView
| KeyCode realvirtual.realvirtualController.HotKeyBackView |
◆ HotkeyCreateOnSource
| KeyCode realvirtual.realvirtualController.HotkeyCreateOnSource |
◆ HotkeyDelete
| KeyCode realvirtual.realvirtualController.HotkeyDelete |
◆ HotKeyDeselect
| KeyCode realvirtual.realvirtualController.HotKeyDeselect |
◆ HotKeyFocus
| KeyCode realvirtual.realvirtualController.HotKeyFocus |
◆ HotKeyFrontView
| KeyCode realvirtual.realvirtualController.HotKeyFrontView |
◆ HotKeyLeftView
| KeyCode realvirtual.realvirtualController.HotKeyLeftView |
◆ HotKeyOrhtoBigger
| KeyCode realvirtual.realvirtualController.HotKeyOrhtoBigger |
◆ HotKeyOrhtoSmaller
| KeyCode realvirtual.realvirtualController.HotKeyOrhtoSmaller |
◆ HotKeyOrthoViews
| KeyCode realvirtual.realvirtualController.HotKeyOrthoViews |
◆ HotkeyQuickEdit
| KeyCode realvirtual.realvirtualController.HotkeyQuickEdit |
◆ HotKeyResetView
| KeyCode realvirtual.realvirtualController.HotKeyResetView |
◆ HotKeyRightView
| KeyCode realvirtual.realvirtualController.HotKeyRightView |
◆ HotkeySource
| KeyCode realvirtual.realvirtualController.HotkeySource |
◆ HotKeyTopView
| KeyCode realvirtual.realvirtualController.HotKeyTopView |
Switch to top view.
◆ ModelCheckerEnabled
| bool realvirtual.realvirtualController.ModelCheckerEnabled |
◆ ObjectSelectionEnabled
| bool realvirtual.realvirtualController.ObjectSelectionEnabled |
◆ Restart
| bool realvirtual.realvirtualController.Restart |
◆ RestartSceneAfterSeconds
| float realvirtual.realvirtualController.RestartSceneAfterSeconds |
◆ RuntimeApplicationUI
| GameObject realvirtual.realvirtualController.RuntimeApplicationUI |
◆ RuntimeAutomationUI
| GameObject realvirtual.realvirtualController.RuntimeAutomationUI |
◆ RuntimeInspectorEnabled
| bool realvirtual.realvirtualController.RuntimeInspectorEnabled |
◆ Scale
| float realvirtual.realvirtualController.Scale |
◆ ScaleHandles
| float realvirtual.realvirtualController.ScaleHandles |
◆ ShowComponents
| bool realvirtual.realvirtualController.ShowComponents |
◆ ShowHierarchyIcons
| bool realvirtual.realvirtualController.ShowHierarchyIcons |
◆ SpeedOverride
| float realvirtual.realvirtualController.SpeedOverride |
◆ StandardSource
| GameObject realvirtual.realvirtualController.StandardSource |
◆ StopPhysicsWhenPaused
| bool realvirtual.realvirtualController.StopPhysicsWhenPaused |
◆ TimeScale
| float realvirtual.realvirtualController.TimeScale |
◆ UIEnabledOnStart
| bool realvirtual.realvirtualController.UIEnabledOnStart |
◆ UseDESMode
| bool realvirtual.realvirtualController.UseDESMode |
◆ ValidateBeforeStart
| bool realvirtual.realvirtualController.ValidateBeforeStart |
◆ ValidationOnComponentsAdded
| bool realvirtual.realvirtualController.ValidationOnComponentsAdded |
◆ WidthGroupName
| float realvirtual.realvirtualController.WidthGroupName |
