MU (Movable Unit) represents physical objects that move through automation systems as products, parts, or assemblies. More...
| void | ResetForPool () |
| Resets MU state for reuse from pool. Called when MU is retrieved from pool. | |
| void | ReturnToPool () |
| Deactivates MU and returns it to pool. Called instead of Destroy when pooled. | |
| void | PlaceMUOnTopOfPosition (Vector3 position) |
| Places the MU with its bottom on top of the defined position. | |
| void | LoadMu (MU mu) |
| Loads the specified MU onto this MU as a child component. If the MU is currently loaded on another MU, it will be unloaded from the previous parent first. | |
| void | EventMUEnterSensor (Sensor sensor) |
| Event that this called when MU enters sensor. | |
| void | EventMUExitSensor (Sensor sensor) |
| void | EventMUPlacedOnTarget (GripTarget target) |
| Called when this MU is placed on a GripTarget. | |
| void | EventMURemovedFromTarget (GripTarget target) |
| Called when this MU is removed from a GripTarget. | |
| void | EventMULoad () |
| Event called when this MU is loaded onto another MU. | |
| void | EventMUUnLoad () |
| Event that this MU is unloaded from another. | |
| void | InitMu (string muname, int localid, int globalid) |
| void | EventMuEnterPathSimulation () |
| Event that this MU is on Path. | |
| void | EventMUExitPathSimulation () |
| Event that this MU is unloaded from Path. | |
| void | Fix (GameObject fixto) |
| void | Unfix () |
| Public method for unfixing MU to a gameobject, parent changes are done based on parent before fix. | |
| void | PhysicsOff () |
| Public method for turning Physics off. | |
| void | PhysicsOn () |
| Public method for turning Physics on. | |
| void | UnloadOneMu (MU mu) |
| Unloads one of the MUs which are loaded on this MU. | |
| void | UnloadAllMUs () |
| Unloads all of the MUs which are loaded on this MU. | |
| void | Dissolve (float duration) |
| Slowly dissolves MU and destroys it. | |
| void | Appear (float duration) |
| void | FixedUpdate () |
| bool | DebugMode |
| Enables debug logging for all MU lifecycle events (Fix, Unfix, Load, Sensor, etc.) | |
| int | ID |
| ID of this MU (increases on each creation on the MU source. | |
| int | GlobalID |
| Global ID, increases for each MU independent on the source. | |
| List< GameObject > | MUAppearences |
| List of MU appearances for PartChanger. | |
| GameObject | FixedBy |
| Current Gripper which is picking the part. | |
| GameObject | LastFixedBy |
| Last Gripper which has been picking the part. | |
| MU | LoadedOn |
| Current MU this MU is loaded on. | |
| GameObject | StandardParent |
| The standard parent Gameobject of the MU. | |
| GameObject | ParentBeforeFix |
| The parent of the MU before the last Grip. | |
| List< Sensor > | CollidedWithSensors |
| The current Sensors the Part is colliding with. | |
| List< MU > | LoadedMus |
| List of MUs which are loaded on this MU. | |
| Source | CreatedBy |
| Source which created this MU. | |
| float | SurfaceAlignSmoothment |
| Smoothing factor for surface alignment. | |
| bool | UnfixSpeedInterpolate |
| When unfixing an MU the interpolated speed of the kinematic Rigidbody will be transferred to the MU. | |
| int | NumInterpolations |
| Number of interpolations - specially needed when speed is not constant like when connected to external robot controllers. | |
| float | FixerLastDistance |
| Last distance to fixer in millimeters. | |
| Rigidbody | Rigidbody |
| List< TransportSurface > | AlignWithSurface |
| List< TransportSurface > | TransportSurfaces |
| float | DissolveDuration |
| Duration in seconds for dissolve effect. | |
| float | MaxDissolveValue |
| Maximum dissolve shader value. | |
| float | Velocity |
| Current velocity in millimeters per second. | |
| bool | IsPooled |
| True if this MU is managed by a pool. | |
| Source | PoolOwner |
| Reference to the Source that owns this MU's pool. | |
| Game4AutomationEventMUDelete | EventMUDeleted |
| Event is called when MU is Deleted / Destroyed. | |
| Game4AutomationEventMU | EventMUIsLoaded |
| Event is called when MU is loaded onto another. | |
| Game4AutomationEventMU | EventMUGetsLoad |
| Event is called when MU gets a MU loaded onto itself. | |
| Game4AutomationEventMUSensor | EventMUSensor |
| Event is called when MU collides with a Sensor. | |
| Game4AutomationEventMUFix | EventMUFix |
| Event is called when MU is fixed or unfixed. | |
| Game4AutomationEventMU | EventMUActivated |
| Event is called when MU is activated or deactivated (true=activated, false=deactivated) | |
| Game4AutomationEventMU | EventMUGripTarget |
| Event is called when MU is placed on (true) or removed from (false) a GripTarget. | |
| override void | OnStopSim () |
The MU is the central component in realvirtual for representing any movable object in the automation simulation. It can be anything from raw materials, work-in-progress items, finished products, containers, pallets, or any other object that needs to be transported, processed, or handled within the automation system.
Key Features:
- Physics-based movement with automatic Rigidbody configuration
- Seamless transport on conveyor belts and other transport surfaces
- Can be gripped, fixed, and released by robots and handling devices
- Hierarchical loading system (MUs can be loaded onto other MUs, like parts on pallets)
- Unique identification with both local and global IDs for tracking
- Collision detection and sensor interaction
- Multiple visual appearances support for product variants
- Automatic alignment to transport surfaces with configurable smoothing
- Speed interpolation for smooth transitions when released from grippers
- Full lifecycle management from creation at sources to destruction at sinks
Transport and Handling:
- Automatically moves on TransportSurface components based on surface speed and direction
- Can be fixed to grippers and other handling devices while maintaining parent-child relationships
- Supports complex material flow with multiple transport surfaces simultaneously
- Maintains velocity information for smooth transitions between transport elements
Common Applications:
- Products on assembly lines
- Boxes and packages in logistics systems
- Pallets in warehouse automation
- Parts in manufacturing processes
- Containers in filling and packaging lines
- Workpiece carriers in production systems
- AGV-transported goods
Integration Points:
- Sources: Created by Source components with configurable intervals
- Sinks: Destroyed by Sink components at process endpoints
- Sensors: Detected by Sensor components for position tracking
- Grippers: Can be picked and placed by Grip and Fixer components
- Transport: Moved by TransportSurface and TransportGuided components
- PLCs: Tracked and controlled through various signal interfaces
Performance Optimization:
- Rigidbody sleep mode for stationary MUs
- Efficient collision layer management
- Optimized parent-child relationship handling
- Smart surface alignment algorithms
Events and Tracking:
- EventMUSensor: Triggered when entering/exiting sensor areas
- EventMUDelete: Triggered when MU is destroyed
- EventMUFix: Triggered when MU is fixed or unfixed
- Full tracking of creation source, current fixtures, and transport surfaces
For detailed documentation see: https://doc.realvirtual.io/components-and-scripts/mu-movable-unit
◆ Dissolve()
| void realvirtual.MU.Dissolve | ( | float | duration | ) |
◆ EventMuEnterPathSimulation()
| void realvirtual.MU.EventMuEnterPathSimulation | ( | ) |
◆ EventMUEnterSensor()
| void realvirtual.MU.EventMUEnterSensor | ( | Sensor | sensor | ) |
◆ EventMUExitPathSimulation()
| void realvirtual.MU.EventMUExitPathSimulation | ( | ) |
◆ EventMUExitSensor()
| void realvirtual.MU.EventMUExitSensor | ( | Sensor | sensor | ) |
◆ EventMULoad()
| void realvirtual.MU.EventMULoad | ( | ) |
◆ EventMUPlacedOnTarget()
| void realvirtual.MU.EventMUPlacedOnTarget | ( | GripTarget | target | ) |
◆ EventMURemovedFromTarget()
| void realvirtual.MU.EventMURemovedFromTarget | ( | GripTarget | target | ) |
◆ EventMUUnLoad()
| void realvirtual.MU.EventMUUnLoad | ( | ) |
◆ LoadMu()
| void realvirtual.MU.LoadMu | ( | MU | mu | ) |
◆ OnStartSim()
protectedvirtual |
◆ OnStopSim()
protectedvirtual |
◆ PhysicsOff()
| void realvirtual.MU.PhysicsOff | ( | ) |
◆ PhysicsOn()
| void realvirtual.MU.PhysicsOn | ( | ) |
◆ PlaceMUOnTopOfPosition()
| void realvirtual.MU.PlaceMUOnTopOfPosition | ( | Vector3 | position | ) |
◆ ResetForPool()
| void realvirtual.MU.ResetForPool | ( | ) |
◆ ReturnToPool()
| void realvirtual.MU.ReturnToPool | ( | ) |
◆ Unfix()
| void realvirtual.MU.Unfix | ( | ) |
◆ UnloadAllMUs()
| void realvirtual.MU.UnloadAllMUs | ( | ) |
◆ UnloadOneMu()
| void realvirtual.MU.UnloadOneMu | ( | MU | mu | ) |
◆ CollidedWithSensors
| List<Sensor> realvirtual.MU.CollidedWithSensors |
◆ CreatedBy
| Source realvirtual.MU.CreatedBy |
◆ DebugMode
| bool realvirtual.MU.DebugMode |
◆ DissolveDuration
| float realvirtual.MU.DissolveDuration |
◆ EventMUActivated
| Game4AutomationEventMU realvirtual.MU.EventMUActivated |
◆ EventMUDeleted
| Game4AutomationEventMUDelete realvirtual.MU.EventMUDeleted |
◆ EventMUFix
| Game4AutomationEventMUFix realvirtual.MU.EventMUFix |
◆ EventMUGetsLoad
| Game4AutomationEventMU realvirtual.MU.EventMUGetsLoad |
◆ EventMUGripTarget
| Game4AutomationEventMU realvirtual.MU.EventMUGripTarget |
◆ EventMUIsLoaded
| Game4AutomationEventMU realvirtual.MU.EventMUIsLoaded |
◆ EventMUSensor
| Game4AutomationEventMUSensor realvirtual.MU.EventMUSensor |
◆ FixedBy
| GameObject realvirtual.MU.FixedBy |
◆ FixerLastDistance
| float realvirtual.MU.FixerLastDistance |
◆ GlobalID
| int realvirtual.MU.GlobalID |
◆ ID
| int realvirtual.MU.ID |
◆ IsPooled
| bool realvirtual.MU.IsPooled |
◆ LastFixedBy
| GameObject realvirtual.MU.LastFixedBy |
◆ LoadedMus
| List<MU> realvirtual.MU.LoadedMus |
◆ LoadedOn
| MU realvirtual.MU.LoadedOn |
◆ MaxDissolveValue
| float realvirtual.MU.MaxDissolveValue |
◆ MUAppearences
| List<GameObject> realvirtual.MU.MUAppearences |
◆ NumInterpolations
| int realvirtual.MU.NumInterpolations |
◆ ParentBeforeFix
| GameObject realvirtual.MU.ParentBeforeFix |
◆ PoolOwner
| Source realvirtual.MU.PoolOwner |
◆ StandardParent
| GameObject realvirtual.MU.StandardParent |
◆ SurfaceAlignSmoothment
| float realvirtual.MU.SurfaceAlignSmoothment |
◆ UnfixSpeedInterpolate
| bool realvirtual.MU.UnfixSpeedInterpolate |
◆ Velocity
| float realvirtual.MU.Velocity |
