Source component that generates MUs (Movable Units) during simulation runtime, simulating production systems and material supply points. More...
| void | DeleteAll () |
| Deletes all MU generated by this Source. | |
| void | OnMUDelete (MU mu) |
| Is called when MU is deleted which has been created by this source. | |
| void | DeleteAllImmediate () |
| void | ReturnToPool (MU mu) |
| Returns an MU to the pool for reuse. | |
| void | ReconcilePoolState () |
| Ensures all pooled (inactive) MUs are SetActive(false) and parented to the pool container. | |
| void | ClearPool () |
| Clears the pool and destroys all pooled objects. | |
| void | OnXRInit (GameObject placedobj) |
| Event called on Init in XR Space. | |
| void | OnXRStartPlace (GameObject placedobj) |
| Event when XR is Starting placing. | |
| void | OnXREndPlace (GameObject placedobj) |
| Event when XR is Ending placing. | |
| MU | Generate () |
| Generates an MU. | |
| override void | OnOwnershipChanged (bool isOwner) |
| Self-manages multiuser behavior. | |
Public Member Functions inherited from realvirtual.ISignalInterface | |
| bool | UseAGXPhysics |
| GameObject | ThisObjectAsMU |
| The referenced GameObject used as a prototype for the MU. Defaults to this GameObject if not set. | |
| GameObject | Destination |
| The destination GameObject where the generated MU should be placed. | |
| bool | Enabled |
| If set to true the Source is enabled. | |
| bool | FreezeSourcePosition |
| If set to true the Source itself (the MU template) is fixed to its position. | |
| bool | DontVisualize |
| True if the Source should not be visible during Simulation time. | |
| bool | HideOnStop |
| Hide this source when simulation is stopped / paused;. | |
| float | Mass |
| Mass of the generated MU in kilograms. | |
| bool | SetCenterOfMass |
| Vector3 | CenterOfMass |
| Center of mass position for the generated MU in local coordinates. | |
| string | GenerateOnLayer |
| Layer where the MUs should be generated to - if kept empty no layers are changed. | |
| bool | ChangeDefaultLayer |
| If set to true Layers are automatically changed if default Layer is detected. | |
| List< string > | OnCreateDestroyComponents |
| Destroy these components on MU when MU is created as a copy of the source - is used to delete additional source scripts. | |
| float | StartInterval |
| Start MU creation with the given seconds after simulation start. | |
| float | Interval |
| Interval in seconds between the generation of MUs. Needs to be set to 0 if no interval generation is wished. | |
| bool | AutomaticGeneration |
| Automatic generation of MUs if last MU is above the GenerateIfDistance distance from MU. | |
| float | GenerateIfDistance |
| Distance in millimeters from Source when new MUs should be generated. | |
| bool | RandomDistance |
| If turned on Distance is Random Number with plus / minus Range Distance. | |
| float | RangeDistance |
| Range of the distance in millimeters (plus / minus) if RandomDistance is turned on. | |
| bool | LimitNumber |
| int | MaxNumberMUs |
| int | Created |
| bool | UsePooling |
| Enable object pooling for MU generation. | |
| int | PoolSize |
| Initial size of the object pool. | |
| bool | PrewarmPool |
| Pre-instantiate pool objects at start. | |
| bool | AllowPoolGrowth |
| Allow pool to grow if all objects are in use. | |
| int | PooledCount |
| Current number of objects in the pool. | |
| int | ActiveCount |
| Current number of active pooled objects. | |
| bool | GenerateMU |
| When changing from false to true a new MU is generated. | |
| bool | DeleteAllMU |
| When changing from false to true all MUs generated by this Source are deleted. | |
| PLCOutputBool | SourceGenerate |
| PLCOutputBool | SourceGenerateOnDistance |
| When true MUs are generated on Distance. | |
| realvirtualEventMUCreated | EventMUCreated |
| Event triggered when a new MU is created. | |
| bool | PositionOverwrite |
| Material | overrideMaterial |
Static Public Attributes | |
| static bool | IsDESFastForward |
| Static flag set by DESManager when running in FastForward mode. | |
| void | Reset () |
| void | Start () |
| For Layout Editor mode Start is called when the simulation is started. | |
| override void | OnStopSim () |
| For Layout Editor mode Stop is called when the simulation is stopped. | |
The Source is a fundamental component in realvirtual for creating MUs (products, parts, materials) that flow through the automation system. It acts as the starting point of material flow, simulating everything from raw material feeders to production output points. Sources can generate MUs based on time intervals, distances, PLC signals, or manual triggers.
Key Features:
- Template-based MU generation using any GameObject as a prototype
- Multiple generation modes: interval-based, distance-based, signal-based, or manual
- Automatic generation when previous MU reaches a specified distance
- PLC signal integration for controlled generation (PLCGenerate signal)
- Configurable physics properties including mass and center of mass
- Support for random variations in generation timing and positioning
- Batch generation capabilities for creating multiple MUs simultaneously
- Layer management for proper collision detection setup
- Component cleanup to remove unnecessary scripts from generated MUs
Generation Modes:
- Interval Generation: Creates MUs at fixed time intervals
- Distance-Based: Generates new MU when last one reaches specified distance
- PLC Controlled: Generation triggered by PLC signals
- Manual: Direct creation through Generate() method calls
- Batch Mode: Creates multiple MUs at once with configurable spacing
Common Applications:
- Raw material feeders in production lines
- Product generation at machine outputs
- Box/container suppliers for packaging systems
- Pallet dispensers in warehouse automation
- Part feeders for assembly stations
- Test object generation for simulation scenarios
- Order-based production simulation
- Buffer replenishment systems
Advanced Features:
- Random distance variations for realistic material flow
- Maximum MU limits to prevent overflow
- Automatic ID assignment for tracking and traceability
- Support for multiple visual appearances (with PartChanger)
- Configurable spawn positions and destinations
- Automatic hiding of template object during simulation
- Integration with AGX physics engine (Professional version)
PLC Integration:
- PLCGenerate: Input signal to trigger MU generation
- PLCIsGenerated: Output signal confirming MU creation
- PLCNumGenerated: Integer output with total count of generated MUs
- Signal-based control for Industry 4.0 scenarios
Performance Considerations:
- Efficient GameObject pooling for high-frequency generation
- Automatic component cleanup reduces memory overhead
- Layer-based collision optimization
- Configurable physics settings for performance tuning
Events:
- EventMUCreated: Triggered when MU is successfully created
- Provides created MU reference for custom logic integration
For detailed documentation see: https://doc.realvirtual.io/components-and-scripts/source
◆ ClearPool()
| void realvirtual.Source.ClearPool | ( | ) |
◆ DeleteAll()
| void realvirtual.Source.DeleteAll | ( | ) |
◆ DeleteAllImmediate()
| void realvirtual.Source.DeleteAllImmediate | ( | ) |
◆ Generate()
| MU realvirtual.Source.Generate | ( | ) |
Generates an MU.
Check if still default layer – if yes then set box collider to g4a MU
◆ OnMUDelete()
| void realvirtual.Source.OnMUDelete | ( | MU | mu | ) |
◆ OnOwnershipChanged()
virtual |
When not owner, disables MU generation so that MUs are only created by the server and synced to clients.
◆ OnStartSim()
protectedvirtual |
◆ OnStopSim()
protectedvirtual |
◆ OnXREndPlace()
| void realvirtual.Source.OnXREndPlace | ( | GameObject | placedobj | ) |
IMPLEMENTS IXRPlaceable::OnXREndPlace
◆ OnXRInit()
| void realvirtual.Source.OnXRInit | ( | GameObject | placedobj | ) |
IMPLEMENTS IXRPlaceable::OnXRInit
◆ OnXRStartPlace()
| void realvirtual.Source.OnXRStartPlace | ( | GameObject | placedobj | ) |
IMPLEMENTS IXRPlaceable::OnXRStartPlace
◆ ReconcilePoolState()
| void realvirtual.Source.ReconcilePoolState | ( | ) |
Called by DESManager.ReconcileAllMUs() after leaving FastForward mode to restore pool state.
◆ ReturnToPool()
| void realvirtual.Source.ReturnToPool | ( | MU | mu | ) |
◆ ActiveCount
| int realvirtual.Source.ActiveCount |
◆ AllowPoolGrowth
| bool realvirtual.Source.AllowPoolGrowth |
◆ AutomaticGeneration
| bool realvirtual.Source.AutomaticGeneration |
◆ CenterOfMass
| Vector3 realvirtual.Source.CenterOfMass |
◆ ChangeDefaultLayer
| bool realvirtual.Source.ChangeDefaultLayer |
◆ DeleteAllMU
| bool realvirtual.Source.DeleteAllMU |
◆ Destination
| GameObject realvirtual.Source.Destination |
◆ DontVisualize
| bool realvirtual.Source.DontVisualize |
◆ Enabled
| bool realvirtual.Source.Enabled |
◆ EventMUCreated
| realvirtualEventMUCreated realvirtual.Source.EventMUCreated |
◆ FreezeSourcePosition
| bool realvirtual.Source.FreezeSourcePosition |
◆ GenerateIfDistance
| float realvirtual.Source.GenerateIfDistance |
◆ GenerateMU
| bool realvirtual.Source.GenerateMU |
◆ GenerateOnLayer
| string realvirtual.Source.GenerateOnLayer |
◆ HideOnStop
| bool realvirtual.Source.HideOnStop |
◆ Interval
| float realvirtual.Source.Interval |
◆ IsDESFastForward
static |
Allows Source.cs (in the starter package) to skip visual ops without a direct dependency on DESManager. DESManager sets this to true in DisableRenderingAndAudio() and false in EnableRenderingAndAudio().
◆ Mass
| float realvirtual.Source.Mass |
◆ OnCreateDestroyComponents
| List<string> realvirtual.Source.OnCreateDestroyComponents |
◆ PooledCount
| int realvirtual.Source.PooledCount |
◆ PoolSize
| int realvirtual.Source.PoolSize |
◆ PrewarmPool
| bool realvirtual.Source.PrewarmPool |
◆ RandomDistance
| bool realvirtual.Source.RandomDistance |
◆ RangeDistance
| float realvirtual.Source.RangeDistance |
◆ SourceGenerate
| PLCOutputBool realvirtual.Source.SourceGenerate |
◆ SourceGenerateOnDistance
| PLCOutputBool realvirtual.Source.SourceGenerateOnDistance |
◆ StartInterval
| float realvirtual.Source.StartInterval |
◆ ThisObjectAsMU
| GameObject realvirtual.Source.ThisObjectAsMU |
◆ UsePooling
| bool realvirtual.Source.UsePooling |
