This is the base class for all Game4Automation objects. This base clase is providing some additional scripts and properties for all components. More...
Public Types | |
◆ DebugPosition()
| GameObject realvirtual.realvirtualBehavior.DebugPosition | ( | string | debugname, |
| Vector3 | position, | ||
| Quaternion | quaternation, | ||
| float | scale | ||
Displays a gizmo for debugging positions.
◆ DirectionIsLinear()
static |
Gets back if the direction is linear or a rotation.
◆ DirectionToVector()
| Vector3 realvirtual.realvirtualBehavior.DirectionToVector | ( | DIRECTION | direction | ) |
Transfers the direction enumeration to a vector.
◆ Error() [1/2]
| void realvirtual.realvirtualBehavior.Error | ( | string | message | ) |
Logs an error.
◆ Error() [2/2]
| void realvirtual.realvirtualBehavior.Error | ( | string | message, |
| object | obj | ||
Logs an error with a relation to an object.
◆ ErrorMessage()
| void realvirtual.realvirtualBehavior.ErrorMessage | ( | string | message | ) |
Displays an error message.
◆ GetChildByName()
| GameObject realvirtual.realvirtualBehavior.GetChildByName | ( | string | name | ) |
Gets a child by name.
◆ GetChildsByName()
| List< GameObject > realvirtual.realvirtualBehavior.GetChildsByName | ( | string | name | ) |
Gets all child by name.
◆ GetMeshRenderer()
| MeshRenderer realvirtual.realvirtualBehavior.GetMeshRenderer | ( | ) |
Gets the mesh renderers in the childrens.
◆ GetTopOfMu()
protected |
Gets the top of an MU component (the first MU script going up in the hierarchy)
◆ InitGame4Automation()
protected |
Initialiates the components and gets the reference to the realvirtualController in the scene.
◆ Log() [1/2]
| void realvirtual.realvirtualBehavior.Log | ( | string | message | ) |
Logs a message.
◆ Log() [2/2]
| void realvirtual.realvirtualBehavior.Log | ( | string | message, |
| object | obj | ||
Logs a message with a relation to an object.
◆ OnOwnershipChanged()
virtual |
Called when network ownership changes.
Override to self-manage multiuser behavior. Use SetNetworkOwner() to change ownership — it sets IsNetworkOwner and calls this.
Reimplemented in realvirtual.Drive, realvirtual.Sink, and realvirtual.Source.
◆ OnStartSim()
protectedvirtual |
Reimplemented in realvirtual.Drive_PositionSwitch, realvirtual.Drive_Simple, and realvirtual.Source.
◆ OnStopSim()
protectedvirtual |
Reimplemented in realvirtual.Source.
◆ PreStartSim()
| void realvirtual.realvirtualBehavior.PreStartSim | ( | ) |
Is called by the realvirtualController before the component is started.
◆ SetCollider()
| void realvirtual.realvirtualBehavior.SetCollider | ( | bool | enabled, |
| bool | includeTriggers = true |
sets the collider in all child objects
◆ SetFreezePosition()
| void realvirtual.realvirtualBehavior.SetFreezePosition | ( | bool | enabled | ) |
Freezes all child components to the current poosition.
◆ SetNetworkOwner()
| void realvirtual.realvirtualBehavior.SetNetworkOwner | ( | bool | isOwner | ) |
Sets IsNetworkOwner and triggers OnOwnershipChanged callback.
◆ SetVisibility()
| void realvirtual.realvirtualBehavior.SetVisibility | ( | bool | visibility | ) |
Sets the visibility of this object including all subobjects.
◆ StartSim()
| void realvirtual.realvirtualBehavior.StartSim | ( | ) |
Is called by the realvirtualController to start or stop the component.
◆ VectorToDirection()
| DIRECTION realvirtual.realvirtualBehavior.VectorToDirection | ( | bool | torotatoin, |
| Vector3 | vector | ||
Transfers a vector to the direction enumeration.
◆ Warning()
| void realvirtual.realvirtualBehavior.Warning | ( | string | message, |
| object | obj | ||
Logs a warning with a relation to an object.
◆ IsNetworkOwner
| bool realvirtual.realvirtualBehavior.IsNetworkOwner |
True when this component owns its simulation (local authority). Set to false by MultiplayerWEB on remote clients.
◆ Name
| string realvirtual.realvirtualBehavior.Name |
The name of the component if it should be different from the GameObject name.
