Drive_Simple provides basic bidirectional control for Drive components with PLC integration. More...
| void | CalcFixedUpdate () |
| float | ScaleSpeed |
| Scale factor for the input and output speed and acceleration. | |
| float | CurrentPositionScale |
| Scale factor for the current position feedback. | |
| float | CurrentPositionOffset |
| Offset applied to position feedback in millimeters. | |
| bool | ScaleFeedbackPosition |
| If true, applies scale and offset to position feedback. | |
| PLCOutputFloat | Speed |
| PLCOutput for the speed of the drive in millimeter / second, can be scaled by Scale factor. | |
| PLCOutputFloat | Accelaration |
| PLCOutputBool | Forward |
| Signal to move the drive forward. | |
| PLCOutputBool | Backward |
| Signal to move the drive backward. | |
| PLCInputFloat | IsAtPosition |
| Signal for current position of the drive (in millimeter). | |
| PLCInputFloat | IsAtSpeed |
| Signal for current speed of the drive (in millimeter/s). | |
| PLCInputBool | IsDriving |
| Signal is true if Drive is driving. | |
| is called when simulation starts | |
Enables forward/backward movement control with speed and acceleration settings through PLC signals. Includes position and speed feedback for closed-loop control in automation systems.
◆ CalcFixedUpdate()
| void realvirtual.Drive_Simple.CalcFixedUpdate | ( | ) |
◆ OnStartSim()
protectedvirtual |
◆ Accelaration
| PLCOutputFloat realvirtual.Drive_Simple.Accelaration |
◆ Backward
| PLCOutputBool realvirtual.Drive_Simple.Backward |
◆ CurrentPositionOffset
| float realvirtual.Drive_Simple.CurrentPositionOffset |
◆ CurrentPositionScale
| float realvirtual.Drive_Simple.CurrentPositionScale |
◆ Forward
| PLCOutputBool realvirtual.Drive_Simple.Forward |
◆ IsAtPosition
| PLCInputFloat realvirtual.Drive_Simple.IsAtPosition |
◆ IsAtSpeed
| PLCInputFloat realvirtual.Drive_Simple.IsAtSpeed |
◆ IsDriving
| PLCInputBool realvirtual.Drive_Simple.IsDriving |
◆ ScaleFeedbackPosition
| bool realvirtual.Drive_Simple.ScaleFeedbackPosition |
◆ ScaleSpeed
| float realvirtual.Drive_Simple.ScaleSpeed |
◆ Speed
| PLCOutputFloat realvirtual.Drive_Simple.Speed |
