PLC Float Input Signal - Represents a floating-point input signal from PLC to simulation. More...
| override bool | IsInput () |
| void | SetValue (int value) |
| Sets the value as an int. | |
| void | SetValue (float value) |
| Sets the value as a float. | |
| void | Update () |
| string | GetSignalName () |
| void | Unforce () |
| Unforces the signal. | |
| string | GetTypeString () |
| StatusFloat | Status |
| string | Comment |
| string | OriginDataType |
| SettingsSignal | Settings |
| bool | Autoconnected |
| bool | UpdateEnable |
| SignalMetadata | Metadata |
Properties | |
| float | Value [get, set] |
| new bool | hidename () |
| string | Visutext |
PLCInputFloat is an essential signal type for receiving analog and continuous numerical data from external PLC systems into the Unity simulation. This component handles 32-bit floating-point values, enabling precise communication of analog measurements, setpoints, and control parameters.
Key Features:
- Receives 32-bit IEEE 754 floating-point values from PLC systems
- Supports real-time value monitoring with change detection
- Provides high precision for analog signal representation
- Includes override capability for testing without PLC connection
- Maintains connection status for communication health monitoring
- Automatic byte-order conversion for cross-platform compatibility
Signal Direction: Simulation → PLC (Input to PLC from PLC perspective) The signal transfers analog values from Unity simulation to PLC controllers, allowing simulation to provide sensor readings and feedback such as speeds, positions, temperatures, and pressures.
Common Applications:
- Receiving speed setpoints for motors and drives (rpm, m/s)
- Reading analog sensor values (pressure, temperature, flow rate)
- Transferring position commands for servo axes
- Implementing PID controller outputs and control values
- Receiving scaling factors and calibration parameters
- Transmitting measurement data from PLC calculations
Interface Integration: PLCInputFloat seamlessly integrates with industrial protocols:
- OPC UA: Maps to OPC UA Float/Double nodes with engineering units
- S7 TCP/IP: Direct reading from Siemens S7 REAL data types
- Modbus TCP/RTU: Maps to holding registers (2 registers for 32-bit float)
- TwinCAT ADS: Connects to Beckhoff REAL variables
- MQTT: Subscribes to JSON payloads with float values
- Shared Memory: High-speed float array exchange
Data Precision and Range: Uses standard 32-bit float representation providing:
- Range: ±3.4 × 10^38
- Precision: ~7 significant digits
- Special values: NaN, Infinity support for error states
Update Mechanism: Values are monitored in Update() for smooth animation compatibility. Changes trigger EventSignalChanged events for reactive component behavior. The system automatically handles byte-order conversion when receiving data from different PLC architectures, ensuring consistent value interpretation across platforms.
◆ GetByteSize()
virtual |
◆ GetByteValue()
virtual |
◆ GetStatusConnected()
virtual |
◆ GetValue()
virtual |
◆ GetVisuText()
virtual |
◆ IsInput()
virtual |
◆ SetStatusConnected()
virtual |
◆ SetValue() [1/5]
virtual |
◆ SetValue() [2/5]
| void realvirtual.PLCInputFloat.SetValue | ( | float | value | ) |
◆ SetValue() [3/5]
| void realvirtual.PLCInputFloat.SetValue | ( | int | value | ) |
◆ SetValue() [4/5]
virtual |
◆ SetValue() [5/5]
virtual |
