PLC Boolean Input Signal - Represents a boolean input signal to PLC from simulation. More...
| override void | OnToggleHierarchy () |
| Sets the Status connected. | |
| Gets the status connected. | |
| Gets the text for displaying it in the hierarchy view. | |
| override bool | IsInput () |
| True if signal is input. | |
| Sets the Value as a string. | |
| void | SetValue (bool value) |
| Sets the Value as a bool. | |
| void | FixedUpdate () |
| string | GetSignalName () |
| void | Unforce () |
| Unforces the signal. | |
| string | GetTypeString () |
| StatusBool | Status |
| Status struct of the bool. | |
| bool | ChangedToTrue |
| bool | ChangedToFalse |
| string | Comment |
| string | OriginDataType |
| SettingsSignal | Settings |
| bool | Autoconnected |
| bool | UpdateEnable |
| SignalMetadata | Metadata |
Properties | |
| bool | Value [get, set] |
| Sets and gets the value. | |
| new bool | hidename () |
| string | Visutext |
PLCInputBool is a fundamental signal type for sending boolean (true/false) data from Unity simulation to external PLC systems. This component serves as a digital input point for the PLC that simulation components can write to, providing sensor states and feedback to PLC control logic.
Key Features:
- Sends boolean values to connected PLC systems via various industrial protocols
- Supports real-time value changes with automatic change detection
- Provides edge detection for rising (false to true) and falling (true to false) transitions
- Implements override capability for manual testing and debugging without PLC connection
- Maintains connection status to indicate communication health with PLC
Signal Direction: Simulation → PLC (Input to PLC from PLC perspective) The signal flows from Unity simulation to the PLC controller, allowing simulation to provide sensor readings and status information to PLC programs such as proximity sensors, limit switches, or status flags.
Common Applications:
- Receiving start/stop commands from PLC programs
- Reading digital sensor states (proximity sensors, light barriers, limit switches)
- Monitoring PLC status flags and operation modes
- Triggering simulation events based on PLC conditions
- Implementing safety interlocks and emergency stop signals
Interface Integration: PLCInputBool seamlessly integrates with multiple industrial communication protocols including:
- OPC UA: Maps to OPC UA boolean nodes for standardized communication
- S7 TCP/IP: Direct integration with Siemens S7 PLCs via TCP/IP
- Modbus TCP/RTU: Maps to Modbus coil or discrete input registers
- TwinCAT ADS: Connects to Beckhoff TwinCAT boolean variables
- MQTT: Subscribes to MQTT topics for IoT integration
- Shared Memory: High-speed local communication for virtual commissioning
Update Mechanism: The signal value is updated in FixedUpdate() to ensure consistent timing with Unity's physics system. Value changes trigger the EventSignalChanged event, allowing other components to react immediately. Edge detection (ChangedToTrue/ChangedToFalse) provides single-frame flags for transition handling, essential for implementing one-shot logic and state machines in automation sequences.
◆ GetByteSize()
virtual |
◆ GetByteValue()
virtual |
◆ GetStatusConnected()
virtual |
◆ GetValue()
virtual |
◆ GetVisuText()
virtual |
◆ IsInput()
virtual |
◆ OnToggleHierarchy()
virtual |
◆ SetStatusConnected()
virtual |
◆ SetValue() [1/4]
| void realvirtual.PLCInputBool.SetValue | ( | bool | value | ) |
◆ SetValue() [2/4]
virtual |
◆ SetValue() [3/4]
virtual |
◆ SetValue() [4/4]
virtual |
◆ Status
| StatusBool realvirtual.PLCInputBool.Status |
Property Documentation
◆ Value
getset |
