PLC Float Output Signal - Represents a floating-point output signal from simulation to PLC. More...
| void | SetValue (float value) |
| Sets the value as a float. | |
| void | Update () |
| string | GetSignalName () |
| virtual bool | IsInput () |
| void | Unforce () |
| Unforces the signal. | |
| string | GetTypeString () |
| StatusFloat | Status |
| string | Comment |
| string | OriginDataType |
| SettingsSignal | Settings |
| bool | Autoconnected |
| bool | UpdateEnable |
| SignalMetadata | Metadata |
Properties | |
| float | Value [get, set] |
| new bool | hidename () |
| string | Visutext |
PLCOutputFloat is a critical signal type for sending analog and continuous numerical data from the Unity simulation to external PLC systems. This component transmits 32-bit floating-point values representing measured values, calculated results, and analog feedback from the simulation.
Key Features:
- Sends 32-bit IEEE 754 floating-point values to PLC systems
- Provides real-time value updates with automatic change notification
- Supports high-precision analog signal transmission
- Includes override functionality for testing and calibration
- Tracks connection status for reliable communication
- Handles culture-invariant number formatting for international compatibility
Signal Direction: PLC → Simulation (Output from PLC from PLC perspective) The signal flows from PLC controllers to Unity simulation, providing analog control values such as setpoints, speed commands, and position targets that simulation components use for operation.
Common Applications:
- Sending simulated analog sensor readings (temperature, pressure, level)
- Providing actual speed feedback from motors and drives
- Transmitting position data from encoders and measuring systems
- Reporting calculated values (flow rates, power consumption, efficiency)
- Sending distance measurements from ultrasonic or laser sensors
- Providing weight and force measurements from load cells
Interface Integration: PLCOutputFloat supports all major industrial protocols:
- OPC UA: Writes to OPC UA Float/Double nodes with engineering units
- S7 TCP/IP: Direct writing to Siemens S7 REAL data blocks
- Modbus TCP/RTU: Updates holding registers (2 registers for float)
- TwinCAT ADS: Writes to Beckhoff REAL variables
- MQTT: Publishes JSON payloads with float values
- Shared Memory: High-performance float array updates
Data Format and Conversion: The component handles various data type conversions:
- Automatic conversion from double to float when needed
- Culture-invariant string parsing for consistent decimal notation
- Byte array conversion for protocol-specific transmission
- NaN and Infinity handling for error state communication
Update Mechanism: Value changes are detected in Update() for smooth visual updates. The EventSignalChanged event ensures immediate transmission to connected interfaces. The system maintains previous values for change detection, minimizing unnecessary network traffic while ensuring timely updates for control-critical applications.
Virtual Commissioning: PLCOutputFloat signals are essential for hardware-in-the-loop testing, replacing physical analog sensors with simulated values. This enables complete validation of PLC analog processing, scaling, and control algorithms without physical equipment.
◆ GetByteSize()
virtual |
◆ GetByteValue()
virtual |
◆ GetStatusConnected()
virtual |
◆ GetValue()
virtual |
◆ GetVisuText()
virtual |
◆ SetStatusConnected()
virtual |
◆ SetValue() [1/4]
virtual |
◆ SetValue() [2/4]
| void realvirtual.PLCOutputFloat.SetValue | ( | float | value | ) |
◆ SetValue() [3/4]
virtual |
◆ SetValue() [4/4]
virtual |
