PartChanger component for dynamically switching between different visual representations of parts. More...
| void | OnSensor (MU mu, bool enter) |
| Unity Event On Sensor Enter end Exit. | |
| void | ChangePart (MU mu) |
| Change the Part mu. | |
| void | ChangePart () |
| Change this Part. | |
| int | PartNumber |
| The number in the list MUAppearances the part should be changed to. | |
| bool | ChangeSensorMU |
| True if a collision with a Sensor should change the part. | |
| Sensor | ChangeOnSensor |
| The connected Sensor. | |
| bool | ChangeThisPart |
| True if this object should be changed (does not needs to be an MU) | |
| List< GameObject > | MUAppearences |
| MUApprearances if this part (not an MU on the Sensor) should be changed. | |
| bool | ConditionSensorIsTouched |
| bool | ConditionPartNumberIsChanging |
| Changes the Part if Sensor is touched. | |
| bool | ConditionPLCSignalChangeNow |
| Changes the Part if Partnumber is changing. | |
| PLCOutputInt | PLCCourrentPartNumber |
| Changes the Part on PLCSignal Change Now. | |
| PLCOutputBool | PLCChangePartNow |
| PLC output for current part number. | |
Enables runtime variation of MU appearances for simulating product variants or configuration changes. Supports sensor-triggered changes and PLC control for automated appearance switching in production simulations.
◆ ChangePart() [1/2]
| void realvirtual.PartChanger.ChangePart | ( | ) |
Change this Part.
◆ ChangePart() [2/2]
| void realvirtual.PartChanger.ChangePart | ( | MU | mu | ) |
Change the Part mu.
◆ OnSensor()
| void realvirtual.PartChanger.OnSensor | ( | MU | mu, |
| bool | enter | ||
◆ ChangeOnSensor
| Sensor realvirtual.PartChanger.ChangeOnSensor |
◆ ChangeSensorMU
| bool realvirtual.PartChanger.ChangeSensorMU |
◆ ChangeThisPart
| bool realvirtual.PartChanger.ChangeThisPart |
◆ ConditionPartNumberIsChanging
| bool realvirtual.PartChanger.ConditionPartNumberIsChanging |
◆ ConditionPLCSignalChangeNow
| bool realvirtual.PartChanger.ConditionPLCSignalChangeNow |
◆ MUAppearences
| List<GameObject> realvirtual.PartChanger.MUAppearences |
◆ PartNumber
| int realvirtual.PartChanger.PartNumber |
◆ PLCChangePartNow
| PLCOutputBool realvirtual.PartChanger.PLCChangePartNow |
◆ PLCCourrentPartNumber
| PLCOutputInt realvirtual.PartChanger.PLCCourrentPartNumber |
