Detects MUs and GameObjects using collider or raycast methods with PLC signal integration for industrial automation. More...
| delegate void | OnEnterDelegate (GameObject obj) |
| Delegate function for GameObjects entering the Sensor. | |
| delegate void | OnExitDelegate (GameObject obj) |
| Delegate function for GameObjects leaving the Sensor. | |
| void | SetNetworkControlled () |
| Sets the sensor to be controlled by network synchronization. | |
| void | SetOccupied (bool value) |
| Manually sets the occupied state of the sensor. | |
| void | DeleteMUs () |
| Delete all MUs in Sensor Area. | |
| void | OnXRInit (GameObject placedobj) |
| Event called on Init in XR Space. | |
| void | OnXRStartPlace (GameObject placedobj) |
| Called when placing in XR / AR scene is started. | |
| void | OnXREndPlace (GameObject placedobj) |
| Called when placing in XR / AR scene is ended. | |
| void | OnMUPartsDestroyed (GameObject obj) |
| void | OnMUDelete (MU muobj) |
Public Member Functions inherited from realvirtual.ISignalInterface | |
| bool | DisplayStatus |
| string | LimitSensorToTag |
| Limits the function of the sensor to a certain MU tag - also MU names are working. | |
| bool | UseRaycast |
| Vector3 | RayCastDirection |
| float | RayCastLength |
| Raycast length in millimeters. | |
| float | RayCastDisplayWidth |
| Raycast display line width in Unity units. | |
| List< string > | AdditionalRayCastLayers |
| bool | ShowSensorLinerenderer |
| Material | MaterialOccupied |
| Material for displaying the occupied status. | |
| Material | MaterialNotOccupied |
| Material for displaying the not occupied status. | |
| bool | PauseOnSensor |
| Pause simulation if sensor is getting high - can be used for debuging. | |
| PLCInputBool | SensorOccupied |
| Boolean PLC input for the Sensor signal - is true if the Sensor is occuied.. | |
| PLCInputBool | SensorNotOccupied |
| Boolen PLC input for the Sensor - is true if the Sensor is NOT occuied. | |
| Game4AutomationEventMUSensor | EventMUSensor |
| Unity event which is called for MU enter and exit. On enter it passes MU and true. On exit it passes MU and false. | |
| Game4AutomationEventGameobjectSensor | EventNonMUGameObjectSensor |
| Unity event which is called for non MU objects enter and exit. On enter it passes gameobject (on which the collider was detected) and true. On exit it passes gameobject and false. | |
| bool | Occupied |
| True if sensor is occupied. | |
| GameObject | LastTriggeredBy |
| Last MU which has triggered the sensor. | |
| float | RayCastDistance |
| Last RayCast Distance in millimeters if Raycast is used. | |
| int | LastTriggeredID |
| Last MUID which has triggered the sensor. | |
| int | LastTriggeredGlobalID |
| Last GloabalID which has triggerd the sensor. | |
| int | Counter |
| int | ColliderCounter |
| List< MU > | CollidingMus |
| List< GameObject > | CollidingObjects |
Events | |
| OnEnterDelegate | EventEnter |
| Event triggered when a GameObject enters the sensor. | |
| OnExitDelegate | EventExit |
| Event triggered when a GameObject exits the sensor. | |
The Sensor is a fundamental component in realvirtual for implementing detection and presence sensing in automation systems. It simulates various types of industrial sensors including proximity sensors, photoelectric sensors, and vision sensors. The sensor can detect MUs entering or leaving its detection area and communicate this information to control systems.
Key Features:
- Two detection modes: Collider-based (volume detection) or Raycast-based (beam detection)
- Configurable detection filtering by MU tags or names for selective sensing
- Visual feedback through material changes showing occupied/not occupied states
- PLC signal integration with both normally open (SensorOccupied) and normally closed (SensorNotOccupied) outputs
- Unity Events for custom scripting integration (EventEnter and EventExit)
- Support for detecting both MUs and standard GameObjects
- Real-time visualization of sensor state in Unity Editor and runtime
- Debugging features including pause-on-detection and status display
Detection Modes:
- Collider Mode: Uses Unity trigger colliders for volumetric detection areas
- Raycast Mode: Simulates beam-type sensors with configurable direction and length
Common Applications:
- Conveyor belt position detection
- Part presence verification at workstations
- Safety light curtains and barriers
- End position detection for drives and cylinders
- Counting and tracking of products
- Collision avoidance for AGVs and robots
- Quality control and inspection stations
The Sensor component integrates with:
- PLC systems through PLCInputBool signals
- Drive components for limit switch functionality
- Transport surfaces for product tracking
- Grip and Fixer components for part detection
- Custom control logic through Unity Events
Performance Considerations:
- Use layer filtering to optimize raycast performance
- Consider using tag filtering to reduce unnecessary detections
- Disable visual feedback (DisplayStatus) in production builds for better performance
For detailed documentation see: https://doc.realvirtual.io/components-and-scripts/sensor
◆ DeleteMUs()
| void realvirtual.Sensor.DeleteMUs | ( | ) |
◆ OnEnterDelegate()
| delegate void realvirtual.Sensor.OnEnterDelegate | ( | GameObject | obj | ) |
◆ OnExitDelegate()
| delegate void realvirtual.Sensor.OnExitDelegate | ( | GameObject | obj | ) |
◆ OnXREndPlace()
| void realvirtual.Sensor.OnXREndPlace | ( | GameObject | placedobj | ) |
◆ OnXRInit()
| void realvirtual.Sensor.OnXRInit | ( | GameObject | placedobj | ) |
◆ OnXRStartPlace()
| void realvirtual.Sensor.OnXRStartPlace | ( | GameObject | placedobj | ) |
◆ SetNetworkControlled()
| void realvirtual.Sensor.SetNetworkControlled | ( | ) |
◆ SetOccupied()
| void realvirtual.Sensor.SetOccupied | ( | bool | value | ) |
◆ EventMUSensor
| Game4AutomationEventMUSensor realvirtual.Sensor.EventMUSensor |
◆ EventNonMUGameObjectSensor
| Game4AutomationEventGameobjectSensor realvirtual.Sensor.EventNonMUGameObjectSensor |
◆ LastTriggeredBy
| GameObject realvirtual.Sensor.LastTriggeredBy |
◆ LastTriggeredGlobalID
| int realvirtual.Sensor.LastTriggeredGlobalID |
◆ LastTriggeredID
| int realvirtual.Sensor.LastTriggeredID |
◆ LimitSensorToTag
| string realvirtual.Sensor.LimitSensorToTag |
◆ MaterialNotOccupied
| Material realvirtual.Sensor.MaterialNotOccupied |
◆ MaterialOccupied
| Material realvirtual.Sensor.MaterialOccupied |
◆ Occupied
| bool realvirtual.Sensor.Occupied |
◆ PauseOnSensor
| bool realvirtual.Sensor.PauseOnSensor |
◆ RayCastDisplayWidth
| float realvirtual.Sensor.RayCastDisplayWidth |
◆ RayCastDistance
| float realvirtual.Sensor.RayCastDistance |
◆ RayCastLength
| float realvirtual.Sensor.RayCastLength |
◆ SensorNotOccupied
| PLCInputBool realvirtual.Sensor.SensorNotOccupied |
◆ SensorOccupied
| PLCInputBool realvirtual.Sensor.SensorOccupied |
Event Documentation
◆ EventEnter
| OnEnterDelegate realvirtual.Sensor.EventEnter |
◆ EventExit
| OnExitDelegate realvirtual.Sensor.EventExit |
