PLC Integer Output Signal - Represents a 32-bit integer output signal from PLC to simulation. More...
| void | SetValue (int value) |
| Sets the value as an int. | |
| void | Update () |
| string | GetSignalName () |
| virtual bool | IsInput () |
| void | Unforce () |
| Unforces the signal. | |
| string | GetTypeString () |
| StatusInt | Status |
| string | Comment |
| string | OriginDataType |
| SettingsSignal | Settings |
| bool | Autoconnected |
| bool | UpdateEnable |
| SignalMetadata | Metadata |
Properties | |
| int | Value [get, set] |
| new bool | hidename () |
| string | Visutext |
PLCOutputInt is an essential signal type for receiving integer data from external PLC systems into the Unity simulation environment. This component receives 32-bit signed integer values, allowing PLC programs to control simulation behavior through setpoints, commands, and parameter values.
Key Features:
- Receives 32-bit signed integer values from connected PLC systems
- Provides automatic change detection and event notification
- Supports discrete state and parameter value reception
- Includes override functionality for testing and manual control
- Maintains connection status for communication monitoring
- Robust type conversion with error handling
Signal Direction: PLC → Simulation (Output from PLC from PLC perspective) The signal flows from PLC controllers to Unity simulation, enabling PLC programs to control simulation behavior through integer commands such as speed setpoints, recipe numbers, and operation modes.
Common Applications:
- Sending simulated encoder positions and pulse counts
- Providing part counting and production statistics
- Transmitting state machine status codes
- Reporting error codes and diagnostic information
- Sending calculated integer results (total counts, averages)
- Providing array indices and selection values
- Transmitting quality codes and inspection results
Interface Integration: PLCOutputInt supports all major industrial communication protocols:
- OPC UA: Writes to OPC UA Int32 nodes with proper typing
- S7 TCP/IP: Direct writing to Siemens S7 DINT data blocks
- Modbus TCP/RTU: Updates holding registers (2 registers for 32-bit)
- TwinCAT ADS: Writes to Beckhoff DINT variables
- MQTT: Publishes integer values in JSON format
- Shared Memory: High-speed integer array updates
Data Integrity and Conversion: The component ensures reliable data transmission:
- Safe conversion from various numeric types (float, double, long)
- Overflow protection with Convert.ToInt32()
- Null value handling to prevent exceptions
- Byte array conversion for binary protocols
- String formatting for text-based communication
Update Mechanism: Value changes are monitored in Update() for responsive updates. When the value changes, EventSignalChanged is invoked to notify all connected interfaces. This ensures that PLC programs receive timely updates for counter values, state changes, and other discrete information critical for sequence control and decision making.
Virtual Commissioning: In virtual commissioning scenarios, PLCOutputInt signals simulate discrete sensors, encoders, and counting devices. This allows complete testing of PLC counting logic, state machines, and discrete control algorithms without physical hardware. The override feature enables manual value injection for comprehensive test coverage.
Performance Considerations: Integer signals are highly efficient for discrete value transmission, using only 4 bytes per value. They are ideal for high-frequency updates like encoder feedback and counter values, providing optimal network bandwidth usage compared to float types.
◆ GetByteSize()
virtual |
◆ GetByteValue()
virtual |
◆ GetStatusConnected()
virtual |
◆ GetValue()
virtual |
◆ GetVisuText()
virtual |
◆ SetStatusConnected()
virtual |
◆ SetValue() [1/4]
virtual |
◆ SetValue() [2/4]
| void realvirtual.PLCOutputInt.SetValue | ( | int | value | ) |
◆ SetValue() [3/4]
virtual |
◆ SetValue() [4/4]
virtual |
