| GetByteSize() (defined in realvirtual.PLCOutputInt) | realvirtual.PLCOutputInt | virtual |
| GetByteValue() (defined in realvirtual.PLCOutputInt) | realvirtual.PLCOutputInt | virtual |
| GetStatusConnected() | realvirtual.PLCOutputInt | virtual |
| GetValue() | realvirtual.PLCOutputInt | virtual |
| GetVisuText() | realvirtual.PLCOutputInt | virtual |
| IsInput() | realvirtual.Signal | virtual |
| SetStatusConnected(bool status) | realvirtual.PLCOutputInt | virtual |
| SetValue(string value) | realvirtual.PLCOutputInt | virtual |
| SetValue(int value) | realvirtual.PLCOutputInt | |
| SetValue(object value) | realvirtual.PLCOutputInt | virtual |
| SetValue(byte[] value) (defined in realvirtual.PLCOutputInt) | realvirtual.PLCOutputInt | virtual |
| Status (defined in realvirtual.PLCOutputInt) | realvirtual.PLCOutputInt | |
| Update() (defined in realvirtual.PLCOutputInt) | realvirtual.PLCOutputInt | |
| Value (defined in realvirtual.PLCOutputInt) | realvirtual.PLCOutputInt | |
