TransportSurface simulates conveyor belts and transport systems for moving objects through industrial automation processes. More...
| delegate void | OnEnterExitDelegate (Collision collission, TransportSurface surface) |
| Delegate for collision enter/exit events. | |
| bool | IsSurfaceGuided () |
| Checks if the transport surface is following a guide path. | |
| Drive | GetDrive () |
| Gets the drive component controlling this transport surface. | |
| void | OnXRInit (GameObject placedobj) |
| Initializes the transport surface for XR/AR placement. | |
| void | OnXRStartPlace (GameObject placedobj) |
| Handles the start of XR/AR placement mode. | |
| void | OnXREndPlace (GameObject placedobj) |
| Handles the end of XR/AR placement mode. | |
| Vector3 | GetClosestDirection (Vector3 position) |
| Gets the transport direction at the closest point to the given position in global coordinates. | |
| Vector3 | GetClosestPoint (Vector3 position) |
| Gets the closest point on the transport surface to the given position. | |
| Bounds | GetTransportSurfaceBounds () |
| Gets the bounds of the transport surface including kinematic groups. | |
| Vector3 | GetMiddleTopPoint () |
| Gets the center point on top of the transport surface for object placement. | |
| void | OnEnterSurface (Collision other) |
| Triggers the OnEnter event when an object collides with the transport surface. | |
| void | OnExitSurface (Collision other) |
| Triggers the OnExit event when an object leaves the transport surface. | |
| void | SetDrive (Drive newDrive) |
| void | CalcFixedUpdate (float deltaTime) |
| Called with external deltaTime for time-synced physics (e.g. | |
| bool | UseAGXPhysics |
| Vector3 | TransportDirection |
| Transport direction in local coordinates, automatically set by the Drive component. | |
| bool | AnimateSurface |
| Enables texture animation to visualize surface movement. | |
| bool | AdvancedSurface |
| Enables advanced conveyor belt visualization with detailed geometry. | |
| float | TextureScale |
| Texture animation speed multiplier in texture units per meter. | |
| bool | ChangeConstraintsOnEnter |
| Modifies rigidbody 2constraints when objects enter the surface. | |
| RigidbodyConstraints | ConstraintsEnter |
| Rigidbody constraints applied when objects enter. | |
| bool | ChangeConstraintsOnExit |
| Modifies rigidbody constraints when objects leave the surface. | |
| RigidbodyConstraints | ConstraintsExit |
| Rigidbody constraints applied when objects exit. | |
| bool | Radial |
| Enables radial/rotational transport mode for turntables and curved conveyors. | |
| Drive | DriveReference |
| Optional drive reference for special cases - normally leave null to use auto-detected parent drive. | |
| float | speed |
| Current transport speed in millimeters per second. | |
| float | SpeedScaleTransportSurface |
| Speed scaling factor applied to the transport surface. | |
| bool | IsGuided |
| Indicates if surface follows a guide path system. | |
| string | Layer |
| Physics layer for transport surface collision detection. | |
| bool | UseMeshCollider |
| Uses mesh collider for precise collision, box collider for better performance. | |
| bool | DebugMode |
| Enables visual debugging information during runtime. | |
| Drive | ParentDrive |
| Parent drive for hierarchical movement systems, transport surface moves relative to parent. | |
| Vector3 | parentposbefore |
| List< Rigidbody > | LoadedPart |
| List of rigidbodies currently on the transport surface. | |
| Vector3 | StartGlobalTransportDirection |
| Initial global transport direction stored at start. | |
| new void | Awake () |
Properties | |
| Drive | Drive [get, set] |
| Gets or sets the Drive component controlling this transport surface. | |
Events | |
| OnEnterExitDelegate | OnEnter |
| Event triggered when objects enter the transport surface. | |
| OnEnterExitDelegate | OnExit |
| Event triggered when objects leave the transport surface. | |
The TransportSurface component is the core element for creating material flow simulation in realvirtual. It provides physics-based movement of objects along defined transport paths, supporting both linear conveyors and rotational systems like turntables. The surface works by applying forces or velocity changes to objects that come into contact with it, simulating real conveyor belt behavior.
Key features:
- Physics-based transport using Unity's physics engine or optional AGX physics
- Support for both linear (straight conveyors) and radial (turntables, rotary tables) movement
- Texture animation synchronized with transport speed for visual feedback
- Automatic speed and direction inheritance from connected Drive components
- Constraint management for stabilizing objects during transport
- Guide path support for complex curved conveyor systems
- Parent drive support for nested transport systems (e.g., conveyors on moving platforms)
- Advanced surface visualization with optional detailed belt geometry
- XR/AR placement support for interactive factory layout planning
Common applications in industrial automation:
- Assembly line conveyors for product transport
- Sorting and distribution systems with multiple branches
- Accumulation conveyors with zone control
- Transfer stations between different transport levels
- Turntables and rotary indexing tables for orientation changes
- Pallet transport systems in warehouses and production
- Material handling in packaging and palletizing systems
Integration with other components:
- Connects to Drive components for speed and direction control
- Works with Sensor components for object detection
- Integrates with TransportGuides for curved path following
- Compatible with MU (Material Unit) components for tracked objects
- Supports Kinematic groups for complex geometry handling
- Can be controlled via PLC signals through Drive behaviors
Performance considerations:
- Use box colliders instead of mesh colliders for better performance
- Enable texture animation only when visual feedback is needed
- Consider using simplified collision meshes for complex conveyor geometry
- Group multiple conveyor sections under single TransportSurface when possible
- Use the rvTransport layer for optimized physics calculations
- For high-speed conveyors, ensure adequate fixed timestep settings
The TransportSurface automatically handles coordination with the Drive component's movement, ensuring synchronized transport speed and direction. It supports both editor-time preview and runtime simulation, making it ideal for virtual commissioning scenarios.
For detailed documentation and examples, see: https://doc.realvirtual.io/components-and-scripts/motion/transportsurface
◆ CalcFixedUpdate()
| void realvirtual.TransportSurface.CalcFixedUpdate | ( | float | deltaTime | ) |
Simit) IMPLEMENTS ITimeSyncedPhysics::CalcFixedUpdate
Implements realvirtual.ITimeSyncedPhysics.
◆ GetClosestDirection()
| Vector3 realvirtual.TransportSurface.GetClosestDirection | ( | Vector3 | position | ) |
Implements realvirtual.IGuidedSurface.
◆ GetClosestPoint()
| Vector3 realvirtual.TransportSurface.GetClosestPoint | ( | Vector3 | position | ) |
◆ GetDrive()
| Drive realvirtual.TransportSurface.GetDrive | ( | ) |
◆ GetMiddleTopPoint()
| Vector3 realvirtual.TransportSurface.GetMiddleTopPoint | ( | ) |
◆ GetTransportSurfaceBounds()
| Bounds realvirtual.TransportSurface.GetTransportSurfaceBounds | ( | ) |
◆ IsSurfaceGuided()
| bool realvirtual.TransportSurface.IsSurfaceGuided | ( | ) |
◆ OnEnterExitDelegate()
| delegate void realvirtual.TransportSurface.OnEnterExitDelegate | ( | Collision | collission, |
| TransportSurface | surface | ||
◆ OnEnterSurface()
| void realvirtual.TransportSurface.OnEnterSurface | ( | Collision | other | ) |
◆ OnExitSurface()
| void realvirtual.TransportSurface.OnExitSurface | ( | Collision | other | ) |
◆ OnXREndPlace()
| void realvirtual.TransportSurface.OnXREndPlace | ( | GameObject | placedobj | ) |
◆ OnXRInit()
| void realvirtual.TransportSurface.OnXRInit | ( | GameObject | placedobj | ) |
◆ OnXRStartPlace()
| void realvirtual.TransportSurface.OnXRStartPlace | ( | GameObject | placedobj | ) |
◆ AdvancedSurface
| bool realvirtual.TransportSurface.AdvancedSurface |
◆ AnimateSurface
| bool realvirtual.TransportSurface.AnimateSurface |
◆ ChangeConstraintsOnEnter
| bool realvirtual.TransportSurface.ChangeConstraintsOnEnter |
◆ ChangeConstraintsOnExit
| bool realvirtual.TransportSurface.ChangeConstraintsOnExit |
◆ ConstraintsEnter
| RigidbodyConstraints realvirtual.TransportSurface.ConstraintsEnter |
◆ ConstraintsExit
| RigidbodyConstraints realvirtual.TransportSurface.ConstraintsExit |
◆ DebugMode
| bool realvirtual.TransportSurface.DebugMode |
◆ DriveReference
| Drive realvirtual.TransportSurface.DriveReference |
◆ IsGuided
| bool realvirtual.TransportSurface.IsGuided |
◆ Layer
| string realvirtual.TransportSurface.Layer |
◆ LoadedPart
| List<Rigidbody> realvirtual.TransportSurface.LoadedPart |
◆ ParentDrive
| Drive realvirtual.TransportSurface.ParentDrive |
◆ Radial
| bool realvirtual.TransportSurface.Radial |
◆ speed
| float realvirtual.TransportSurface.speed |
◆ SpeedScaleTransportSurface
| float realvirtual.TransportSurface.SpeedScaleTransportSurface |
◆ StartGlobalTransportDirection
| Vector3 realvirtual.TransportSurface.StartGlobalTransportDirection |
◆ TextureScale
| float realvirtual.TransportSurface.TextureScale |
◆ TransportDirection
| Vector3 realvirtual.TransportSurface.TransportDirection |
◆ UseMeshCollider
| bool realvirtual.TransportSurface.UseMeshCollider |
Property Documentation
◆ Drive
getset |
Event Documentation
◆ OnEnter
| OnEnterExitDelegate realvirtual.TransportSurface.OnEnter |
◆ OnExit
| OnEnterExitDelegate realvirtual.TransportSurface.OnExit |
