Controls linear and rotational motion of GameObjects with precise position, speed, and acceleration control for industrial automation. More...
| delegate void | DelegateDriveStartInit (Drive drive) |
| value for overwriting speed (transportsurfaces) for replaying recordings or multiplayer | |
| delegate void | OnAtPositionEvent (Drive drive) |
| Delegate function for the Drive reaching the destination position. | |
| delegate void | OnJumpToLowerLimitEvent (Drive drive) |
| Delegate function for when drive jumps to lower limit. | |
| delegate void | OnJumpToUpperLimitEvent (Drive drive) |
| Delegate function for when drive jumps to upper limit. | |
| List< TransportSurface > | GetTransportSurfaces () |
| void | AddSubDrive (Drive drive) |
| void | OnXRInit (GameObject placedobj) |
| Initializes the drive for XR/AR placement operations. | |
| void | OnXRStartPlace (GameObject placedobj) |
| Stops the drive when XR/AR placemesnt begins to prevent movement during positioning. | |
| void | OnXREndPlace (GameObject placedobj) |
| Resumes drive operation after XR/AR placement is completed. | |
| void | Forward () |
| Starts the drive to move forward with the target speed. | |
| void | Backward () |
| void | DriveTo (float Target) |
| Starts the drive to drive to the given Target with the target speed. | |
| void | RedirectDriveTo (float Target) |
| Redirects the drive to a new target position while preserving current speed. | |
| void | DriveTo (float Target, float time) |
| Starts the drive to drive to the given Target with a custom time - acceleration (or Speed on no Acceleration) will be calculated to reach time. | |
| float | GetTimeTo (float Target) |
| Calculates the time to the target. | |
| void | Accelerate () |
| Starts the drive - it will speed up with sinoide if turned on. | |
| void | Decelerate () |
| void | Stop () |
| Stops the drive at the current position. | |
| Vector3 | GetLocalDirection () |
| Gets the axis vector of the drive. | |
| void | OnDestroy () |
| void | StartEditorMoveMode () |
| void | SetPositionEditorMoveMode (float editorposition) |
| void | EndEditorMoveMode () |
| Vector3 | GetStartPos () |
| Gets the start position of the drive in local scale. | |
| Vector3 | GetStartRot () |
| void | SetPositionAndSpeed (float Position, float Speed) |
| bool | SetPosition (float position, float precision=0) |
| Sets the position of the drive and updates the visual position. | |
| Vector3 | GetGlobalDirection () |
| void | CalculateVectors () |
| void | DriveReset () |
| void | CalcFixedUpdate (float deltaTime) |
| IMPLEMENTS ITimeSyncedPhysics::CalcFixedUpdate. | |
| void | CalcFixedUpdate () |
| void | OnEditModeFinished () |
| Cleans up references when Unity Editor exits edit mode. | |
| override void | OnOwnershipChanged (bool isOwner) |
| Self-manages multiuser behavior. | |
| DIRECTION | Direction |
| The direction in local coordinate system of the GameObject where the drive is attached to. | |
| bool | ReverseDirection |
| Set to true if Direction needs to be inverted. | |
| float | Offset |
| Start offset of the drive from zero position in millimeters or degrees. | |
| float | StartPosition |
| Start Position off the Drive. | |
| float | SpeedOverride |
| Factor for locally overriding the speed and acceleration of this drive. | |
| float | SpeedScaleTransportSurface |
| Scale of the Speed for radial transportsurfaces to feed in mm/s on radius. | |
| bool | MoveThisRigidBody |
| If set to true the RigidBodies are moved (use it if moving) part has attached colliders, if false the transforms are moved. | |
| bool | EditorMoveMode |
| bool | UseLimits |
| float | LowerLimit |
| Lower Drive Limit, Upper and Lower = 0 if this should not be used. | |
| float | UpperLimit |
| Upper Drive Limit, Upper and Lower = 0 if this should not be used. | |
| bool | JumpToLowerLimitOnUpperLimit |
| Sensor | LimitRayCast |
| bool | UseAcceleration |
| If set to true the drive uses the acceleration. | |
| bool | SmoothAcceleration |
| if set to true the drive uses smooth acceleration with a sinoide function | |
| float | Acceleration |
| The acceleration in millimeter per second^2. | |
| float | Jerk |
| bool | JogForward |
| A jog bit for jogging forward with the Target Speed. | |
| bool | JogBackward |
| A jog bit for jogging backwards with the Target Speed. | |
| float | TargetPosition |
| The target position of the Drive. | |
| float | TargetSpeed |
| The target speed in millimeter / second of the Drive. | |
| bool | TargetStartMove |
| When changing to true the Drive is starting to move to the TargetPosition. | |
| bool | BlockDestination |
| If Block Drive is true it will not drive to its Target Positon, Jogging is possible. | |
| bool | ResetDrive |
| Resets the Drive to the zero position and stops all movements. | |
| bool | _StopDrive |
| Stops the Drive at the current position. | |
| float | CurrentSpeed |
| The current speed of the drive. | |
| float | CurrentPosition |
| float | PositionOverwriteValue |
| float | IsPosition |
| current position, can be overwritten by DriveOverwrite or current position | |
| float | IsSpeed |
| current speed, can be overwritten by SpeedOverwrite or current position | |
| bool | IsStopped |
| Is true if Drive is stopped. | |
| bool | IsRunning |
| Is true if Drive is running. | |
| bool | IsAtTargetSpeed |
| bool | IsAtTarget |
| Is true if Drive is at target position. | |
| bool | IsAtLowerLimit |
| Is true if Drive is jogging and reaching lower Limit. | |
| bool | IsSubDrive |
| bool | IsExternallyControlled |
| If true, skip FixedUpdate calculations (position set externally by IK or other systems) | |
| DriveEvent | OnBeforeDriveCalculation |
| Unity Event before calculating drive. | |
| DriveEvent | OnAfterDriveCalculation |
| Unity Event after calculating drive. | |
| bool | IsAtUpperLimit |
| Is true if Drive is jogging and reaching upper Limit. | |
| bool | HideGizmos |
| float | StandardSpeed |
| float | StandardAcceleration |
| bool | UseInteract |
| bool | IsRotation |
| bool | PositionOverwrite |
| true for overwriting position for replaying recordings or multiplayer | |
| bool | SpeedOverwrite |
| true for overwriting speed (transportsurfaces) for replaying recordings or multiplayer | |
| float | SpeedOverwriteValue |
| DelegateDriveStartInit | AfterDriveStartInit |
| Drive[] | _subdrives |
Events | |
| OnAtPositionEvent | OnAtPosition |
| Event triggered when drive reaches the destination position. | |
| OnJumpToLowerLimitEvent | OnJumpToLowerLimit |
| Event triggered when drive jumps to lower limit. | |
| OnJumpToUpperLimitEvent | OnJumpToUpperLimit |
| Event triggered when drive jumps to upper limit during backward wrap. | |
The Drive is one of the core components in realvirtual for simulating motion in automation systems. It moves components including all sub-components along the local axis of the GameObject. Both rotational and linear movements are possible. A drive can be enhanced by DriveBehaviours which add special behaviors as well as Input and Output signals for PLC integration.
Key Features:
- Precise position and speed control with configurable acceleration and deceleration
- Support for linear movements (X, Y, Z axes) and rotational movements (around X, Y, Z axes)
- Position limits with automatic limit switches and optional cyclic movement
- PLC signal integration for industrial control system connectivity
- Smooth acceleration profiles including S-curve motion for jerk-limited movement
- Speed override capabilities for runtime speed adjustments
- Visual feedback in Unity Editor with gizmos showing movement direction and limits
- Support for both transform-based and physics-based (Rigidbody) movement
Common Applications:
- Conveyor belts and transport systems
- Linear actuators and pneumatic cylinders
- Servo motors and rotational axes
- Robot joints and kinematic chains
- Lifting platforms and elevators
- Sliding doors and gates
The Drive component can be controlled through:
- Direct properties (JogForward, JogBackward, TargetPosition)
- PLC signals via DriveBehavior components
- Unity Events for position reached notifications
- Custom scripts accessing the public API
For detailed documentation see: https://doc.realvirtual.io/components-and-scripts/motion/drive
◆ Accelerate()
| void realvirtual.Drive.Accelerate | ( | ) |
◆ Backward()
| void realvirtual.Drive.Backward | ( | ) |
◆ CalcFixedUpdate()
| void realvirtual.Drive.CalcFixedUpdate | ( | float | deltaTime | ) |
Implements realvirtual.ITimeSyncedPhysics.
◆ DelegateDriveStartInit()
| delegate void realvirtual.Drive.DelegateDriveStartInit | ( | Drive | drive | ) |
◆ DriveTo() [1/2]
| void realvirtual.Drive.DriveTo | ( | float | Target | ) |
◆ DriveTo() [2/2]
| void realvirtual.Drive.DriveTo | ( | float | Target, |
| float | time | ||
◆ Forward()
| void realvirtual.Drive.Forward | ( | ) |
◆ GetLocalDirection()
| Vector3 realvirtual.Drive.GetLocalDirection | ( | ) |
◆ GetStartPos()
| Vector3 realvirtual.Drive.GetStartPos | ( | ) |
◆ GetStartRot()
| Vector3 realvirtual.Drive.GetStartRot | ( | ) |
◆ GetTimeTo()
| float realvirtual.Drive.GetTimeTo | ( | float | Target | ) |
◆ OnAtPositionEvent()
| delegate void realvirtual.Drive.OnAtPositionEvent | ( | Drive | drive | ) |
◆ OnEditModeFinished()
| void realvirtual.Drive.OnEditModeFinished | ( | ) |
IMPLEMENTS IEditModeFinished::OnEditModeFinished
Implements realvirtual.IEditModeFinished.
◆ OnJumpToLowerLimitEvent()
| delegate void realvirtual.Drive.OnJumpToLowerLimitEvent | ( | Drive | drive | ) |
◆ OnJumpToUpperLimitEvent()
| delegate void realvirtual.Drive.OnJumpToUpperLimitEvent | ( | Drive | drive | ) |
◆ OnOwnershipChanged()
virtual |
When not owner, enables PositionOverwrite and ForceStop to accept externally synced position/speed without internal motion calculations.
◆ OnStartSim()
protectedvirtual |
◆ OnXREndPlace()
| void realvirtual.Drive.OnXREndPlace | ( | GameObject | placedobj | ) |
IMPLEMENTS IXRPlaceable::OnXREndPlace
◆ OnXRInit()
| void realvirtual.Drive.OnXRInit | ( | GameObject | placedobj | ) |
IMPLEMENTS IXRPlaceable::OnXRInit
◆ OnXRStartPlace()
| void realvirtual.Drive.OnXRStartPlace | ( | GameObject | placedobj | ) |
IMPLEMENTS IXRPlaceable::OnXRStartPlace
◆ RedirectDriveTo()
| void realvirtual.Drive.RedirectDriveTo | ( | float | Target | ) |
Used during blending to avoid speed discontinuity. Clears both acceleration flags so the stoppos-based direction logic in CalcFixedUpdate correctly determines whether to accelerate or brake based on destination vs. stopping position. For SmoothAcceleration drives, these flags are unused - InitSmoothDriveTo handles velocity preservation automatically via SetInitialVelocity(CurrentSpeed).
◆ SetPosition()
| bool realvirtual.Drive.SetPosition | ( | float | position, |
| float | precision = 0 |
When precision > 0, skips update if position change is smaller than precision (optimization for high-frequency updates like IK). Returns true if position was updated, false if skipped due to precision threshold.
◆ Stop()
| void realvirtual.Drive.Stop | ( | ) |
◆ _StopDrive
| bool realvirtual.Drive._StopDrive |
◆ Acceleration
| float realvirtual.Drive.Acceleration |
◆ BlockDestination
| bool realvirtual.Drive.BlockDestination |
◆ CurrentSpeed
| float realvirtual.Drive.CurrentSpeed |
◆ Direction
| DIRECTION realvirtual.Drive.Direction |
◆ IsAtLowerLimit
| bool realvirtual.Drive.IsAtLowerLimit |
◆ IsAtTarget
| bool realvirtual.Drive.IsAtTarget |
◆ IsAtTargetSpeed
| bool realvirtual.Drive.IsAtTargetSpeed |
◆ IsAtUpperLimit
| bool realvirtual.Drive.IsAtUpperLimit |
◆ IsExternallyControlled
| bool realvirtual.Drive.IsExternallyControlled |
◆ IsPosition
| float realvirtual.Drive.IsPosition |
◆ IsRunning
| bool realvirtual.Drive.IsRunning |
◆ IsSpeed
| float realvirtual.Drive.IsSpeed |
The current position of the drive
◆ IsStopped
| bool realvirtual.Drive.IsStopped |
◆ JogBackward
| bool realvirtual.Drive.JogBackward |
◆ JogForward
| bool realvirtual.Drive.JogForward |
◆ LowerLimit
| float realvirtual.Drive.LowerLimit |
◆ MoveThisRigidBody
| bool realvirtual.Drive.MoveThisRigidBody |
◆ Offset
| float realvirtual.Drive.Offset |
◆ OnAfterDriveCalculation
| DriveEvent realvirtual.Drive.OnAfterDriveCalculation |
◆ OnBeforeDriveCalculation
| DriveEvent realvirtual.Drive.OnBeforeDriveCalculation |
◆ PositionOverwrite
| bool realvirtual.Drive.PositionOverwrite |
◆ ResetDrive
| bool realvirtual.Drive.ResetDrive |
◆ ReverseDirection
| bool realvirtual.Drive.ReverseDirection |
◆ SmoothAcceleration
| bool realvirtual.Drive.SmoothAcceleration |
◆ SpeedOverride
| float realvirtual.Drive.SpeedOverride |
◆ SpeedOverwrite
| bool realvirtual.Drive.SpeedOverwrite |
◆ SpeedScaleTransportSurface
| float realvirtual.Drive.SpeedScaleTransportSurface |
◆ StartPosition
| float realvirtual.Drive.StartPosition |
◆ TargetPosition
| float realvirtual.Drive.TargetPosition |
◆ TargetSpeed
| float realvirtual.Drive.TargetSpeed |
◆ TargetStartMove
| bool realvirtual.Drive.TargetStartMove |
◆ UpperLimit
| float realvirtual.Drive.UpperLimit |
◆ UseAcceleration
| bool realvirtual.Drive.UseAcceleration |
Event Documentation
◆ OnAtPosition
| OnAtPositionEvent realvirtual.Drive.OnAtPosition |
| OnJumpToLowerLimitEvent realvirtual.Drive.OnJumpToLowerLimit |
| OnJumpToUpperLimitEvent realvirtual.Drive.OnJumpToUpperLimit |
