Grip component for attaching and transporting MUs with moving mechanisms like robots or grippers. More...
| void | DeActivate (bool activate) |
| Deactivates or activates the grip component. | |
| void | OnMultiplayer (bool isclient, bool isstart) |
| void | Fix (MU mu) |
| Fixes (grips) the given MU to this grip. | |
| void | Unfix (MU mu) |
| Releases (ungrips) the given MU. Does NOT trigger AutoPlace — use internal Place() flank for auto-placement. | |
| void | Pick () |
| Picks all MUs: uses sensor (PartToGrip) if assigned, otherwise auto-detects via OverlapSphere. | |
| void | Place () |
| Places all currently gripped MUs. Applies AutoPlace logic if PlaceMode requires it. | |
| bool | AdvancedMode |
| If true all advanced properties are shown in the inspector. | |
| float | GripRange |
| Search radius in millimeters for automatic MU detection when no Sensor is assigned. | |
| Sensor | PartToGrip |
| Identifies the MU to be gripped. When null the OverlapSphere auto-detection uses GripRange. | |
| bool | DirectlyGrip |
| If set to true the MU is directly gripped when Sensor PartToGrip detects a Part. | |
| GameObject | PickAlignWithObject |
| bool | AlignRotation |
| If not null the MUs are aligned with this object before picking. | |
| Sensor | PickBasedOnSensor |
| Picking is started when this sensor is occupied (optional) | |
| Drive_Cylinder | PickBasedOnCylinder |
| Picking is stared when Cylinder is Max or Min (optional) | |
| bool | PickOnCylinderMax |
| Picking is started when Cylinderis Max. | |
| PlaceMode | PlaceMode |
| Controls how MUs are released on Place() | |
| float | GripTargetSearchRadius |
| Search radius in millimeters for finding the nearest GripTarget on Place. | |
| float | RaycastDistance |
| Raycast distance in millimeters for Auto-Place surface detection. | |
| bool | NoPhysicsWhenPlaced |
| Object remains kinematic (no phyisics) when placed. | |
| GameObject | PlaceAlignWithObject |
| If not null the MUs are aligned with this object after placing. Useful for positioning near Fixers that will take over. | |
| bool | PlaceLoadOnMU |
| When placing the components they should be loaded onto an MU as subcomponent. | |
| Sensor | PlaceLoadOnMUSensor |
| Sensor defining the MU where the picked MUs should be loaded to. | |
| UnityEngine.Joint | ConnectToJoint |
| bool | PickObjects |
| true for picking MUs identified by the sensor. | |
| bool | PlaceObjects |
| //!< true for placing the loaded MUs. | |
| bool | OneBitControl |
| If true the grip is controlled by one bit. If false the grip is controlled by two bits. | |
| PLCOutputBool | SignalPick |
| PLCOutputBool | SignalPlace |
| EventMUGrip | EventMUGrip |
| Unity event which is called for MU grip and ungrip. On grip it passes MU and true. On ungrip it passes MU and false. | |
| bool | ShowGizmo |
| If true the grip range gizmo is displayed in the scene view. | |
| List< GameObject > | PickedMUs |
The Grip component is a fundamental part of realvirtual's material handling system, enabling dynamic pick-and-place operations in industrial automation simulations. It provides flexible attachment mechanisms for securely gripping MUs (Material Units) and transporting them through the production system. The component works by detecting MUs through a sensor or automatic OverlapSphere search, fixing them kinematically or with physics joints, and maintaining the attachment while the parent object moves.
Key Features:
- Sensor-based MU detection OR automatic OverlapSphere pick (no sensor required)
- Kinematic attachment for stable, physics-free transportation
- Optional physics joint connection for dynamic simulations
- Auto-Place Raycast: GripTarget → LoadMu on MU → Physics on TransportSurface → Kinematic
- GripTarget marker support for precise pick placement
- Alignment control for precise positioning during pick and place operations
- Direct gripping mode for immediate attachment on sensor detection
- Support for loading MUs as subcomponents onto other MUs
- Single-bit or dual-bit PLC control modes
- Unity events for grip and ungrip notifications
Common Applications:
- Robotic end effectors and tool changers
- Conveyor transfer mechanisms
- AGV loading/unloading systems
- Palletizing and depalletizing operations
- Assembly line pick-and-place stations
- Material sorting and distribution systems
Integration Points: The Grip component integrates seamlessly with other realvirtual components through the sensor system for MU detection, the MU system for material tracking, and Drive_Cylinder for automated gripping based on cylinder positions. It can be controlled through PLC signals (PLCOutputBool) for industrial control system integration or directly through Unity Inspector properties for simulation control.
Performance Considerations: The component uses kinematic attachment by default, which is more performant than physics-based joints. OverlapSphere and Raycast are called only once per Pick/Place event (not per frame). Pre-allocated Collider buffer avoids GC allocations in the pick/place code path.
Events and Signals: The EventMUGrip Unity event provides real-time notifications of grip operations, passing the MU reference and grip state (true for grip, false for ungrip). This enables custom logic execution during material handling operations, such as updating production tracking systems or triggering dependent automation sequences.
For detailed documentation and examples, visit: https://doc.realvirtual.io/components-and-scripts/grip
◆ DeActivate()
| void realvirtual.Grip.DeActivate | ( | bool | activate | ) |
Implements realvirtual.IFix.
◆ Fix()
| void realvirtual.Grip.Fix | ( | MU | mu | ) |
◆ OnMultiplayer()
| void realvirtual.Grip.OnMultiplayer | ( | bool | isclient, |
| bool | isstart | ||
Implements realvirtual.IMultiPlayer.
◆ Pick()
| void realvirtual.Grip.Pick | ( | ) |
◆ Place()
| void realvirtual.Grip.Place | ( | ) |
◆ Unfix()
| void realvirtual.Grip.Unfix | ( | MU | mu | ) |
◆ AdvancedMode
| bool realvirtual.Grip.AdvancedMode |
◆ AlignRotation
| bool realvirtual.Grip.AlignRotation |
◆ DirectlyGrip
| bool realvirtual.Grip.DirectlyGrip |
◆ EventMUGrip
| EventMUGrip realvirtual.Grip.EventMUGrip |
◆ GripRange
| float realvirtual.Grip.GripRange |
◆ GripTargetSearchRadius
| float realvirtual.Grip.GripTargetSearchRadius |
◆ NoPhysicsWhenPlaced
| bool realvirtual.Grip.NoPhysicsWhenPlaced |
◆ OneBitControl
| bool realvirtual.Grip.OneBitControl |
◆ PartToGrip
| Sensor realvirtual.Grip.PartToGrip |
◆ PickBasedOnCylinder
| Drive_Cylinder realvirtual.Grip.PickBasedOnCylinder |
◆ PickBasedOnSensor
| Sensor realvirtual.Grip.PickBasedOnSensor |
◆ PickObjects
| bool realvirtual.Grip.PickObjects |
◆ PickOnCylinderMax
| bool realvirtual.Grip.PickOnCylinderMax |
◆ PlaceAlignWithObject
| GameObject realvirtual.Grip.PlaceAlignWithObject |
◆ PlaceLoadOnMU
| bool realvirtual.Grip.PlaceLoadOnMU |
◆ PlaceLoadOnMUSensor
| Sensor realvirtual.Grip.PlaceLoadOnMUSensor |
◆ PlaceMode
| PlaceMode realvirtual.Grip.PlaceMode |
◆ PlaceObjects
| bool realvirtual.Grip.PlaceObjects |
◆ RaycastDistance
| float realvirtual.Grip.RaycastDistance |
◆ ShowGizmo
| bool realvirtual.Grip.ShowGizmo |
