Drive_Cylinder simulates pneumatic or hydraulic cylinder behavior for Drive components. More...
| delegate void | OnMinDelegate () |
| Delegate function which is called when cylinder is at Min. | |
| delegate void | OnMaxDelegate () |
| Delegate function which is called when cylinder is at Max. | |
| void | CalcFixedUpdate () |
| bool | OneBitCylinder |
| if set to true only one bit is needed to controll the cylinder. If Out=false the cylinder moves in | |
| bool | InvertOutputLogic |
| When true, inverts the Out/In signal logic. Out=false extends, Out=true retracts. | |
| float | MinPos |
| Minimum position in millimeters of the cylinder. | |
| float | MaxPos |
| Maximumposition in millimeters of the cylinder. | |
| float | TimeOut |
| Time for moving out from minimum position to maximum position in seconds. | |
| float | TimeIn |
| Time for moving in from maximum position to minimum position in seconds. | |
| Sensor | StopWhenDrivingToMin |
| Sensor for stopping the cylinder before reaching the min position (optional) | |
| Sensor | StopWhenDrivingToMax |
| Sensor for stopping the cylinder before reaching the max position (optional) | |
| bool | _out |
| true for moving the cylinder out. | |
| bool | _in |
| true for moving the cylinder in. | |
| bool | _isOut |
| is true when cylinder is out or stopped by Max sensor. | |
| bool | _isIn |
| is true when cylinder is in or stopped by Min sensor. | |
| bool | _movingOut |
| is true when cylinder is currently moving out | |
| bool | _movingIn |
| is true when cylinder is currently moving in | |
| bool | _isMax |
| is true when cylinder is at maximum position. | |
| bool | _isMin |
| is true when cylinder is at minimum position. | |
| PLCOutputBool | Out |
| Signal for moving the cylinder out. | |
| PLCOutputBool | In |
| Signal for moving the cylinder in. | |
| PLCInputBool | IsOut |
| Signal when the cylinder is out or stopped by Max sensor. | |
| PLCInputBool | IsIn |
| Signal when the cylinder is in or stopped by Max sensor. | |
| PLCInputBool | IsMax |
| Signal is true when the cylinder is at Max position. | |
| PLCInputBool | IsMin |
| Signal is true when the cylinder is at Min position. | |
| PLCInputBool | IsMovingOut |
| Signals is true when the cylinder is moving in. | |
| PLCInputBool | IsMovingIn |
| Signal is true when the cylinder is moving out. | |
Events | |
| OnMinDelegate | EventOnMin |
| OnMaxDelegate | EventOnMax |
Provides two-position actuation with configurable extension/retraction times and stroke limits. Supports both single-bit and dual-bit control modes with position feedback and optional sensor-based stopping.
◆ CalcFixedUpdate()
| void realvirtual.Drive_Cylinder.CalcFixedUpdate | ( | ) |
◆ OnMaxDelegate()
| delegate void realvirtual.Drive_Cylinder.OnMaxDelegate | ( | ) |
◆ OnMinDelegate()
| delegate void realvirtual.Drive_Cylinder.OnMinDelegate | ( | ) |
◆ OnStartSim()
protectedvirtual |
◆ _in
| bool realvirtual.Drive_Cylinder._in |
◆ _isIn
| bool realvirtual.Drive_Cylinder._isIn |
◆ _isMax
| bool realvirtual.Drive_Cylinder._isMax |
◆ _isMin
| bool realvirtual.Drive_Cylinder._isMin |
◆ _isOut
| bool realvirtual.Drive_Cylinder._isOut |
◆ _movingIn
| bool realvirtual.Drive_Cylinder._movingIn |
◆ _movingOut
| bool realvirtual.Drive_Cylinder._movingOut |
◆ _out
| bool realvirtual.Drive_Cylinder._out |
◆ In
| PLCOutputBool realvirtual.Drive_Cylinder.In |
◆ InvertOutputLogic
| bool realvirtual.Drive_Cylinder.InvertOutputLogic |
◆ IsIn
| PLCInputBool realvirtual.Drive_Cylinder.IsIn |
◆ IsMax
| PLCInputBool realvirtual.Drive_Cylinder.IsMax |
◆ IsMin
| PLCInputBool realvirtual.Drive_Cylinder.IsMin |
◆ IsMovingIn
| PLCInputBool realvirtual.Drive_Cylinder.IsMovingIn |
◆ IsMovingOut
| PLCInputBool realvirtual.Drive_Cylinder.IsMovingOut |
◆ IsOut
| PLCInputBool realvirtual.Drive_Cylinder.IsOut |
◆ MaxPos
| float realvirtual.Drive_Cylinder.MaxPos |
◆ MinPos
| float realvirtual.Drive_Cylinder.MinPos |
◆ OneBitCylinder
| bool realvirtual.Drive_Cylinder.OneBitCylinder |
◆ Out
| PLCOutputBool realvirtual.Drive_Cylinder.Out |
◆ StopWhenDrivingToMax
| Sensor realvirtual.Drive_Cylinder.StopWhenDrivingToMax |
◆ StopWhenDrivingToMin
| Sensor realvirtual.Drive_Cylinder.StopWhenDrivingToMin |
◆ TimeIn
| float realvirtual.Drive_Cylinder.TimeIn |
◆ TimeOut
| float realvirtual.Drive_Cylinder.TimeOut |
