| AdvancedMode | realvirtual.Grip | |
| AlignRotation | realvirtual.Grip | |
| ConnectToJoint (defined in realvirtual.Grip) | realvirtual.Grip | |
| DeActivate(bool activate) | realvirtual.Grip | |
| DirectlyGrip | realvirtual.Grip | |
| EventMUGrip | realvirtual.Grip | |
| Fix(MU mu) | realvirtual.Grip | |
| GripRange | realvirtual.Grip | |
| GripTargetSearchRadius | realvirtual.Grip | |
| NoPhysicsWhenPlaced | realvirtual.Grip | |
| OneBitControl | realvirtual.Grip | |
| OnMultiplayer(bool isclient, bool isstart) (defined in realvirtual.Grip) | realvirtual.Grip | |
| PartToGrip | realvirtual.Grip | |
| Pick() | realvirtual.Grip | |
| PickAlignWithObject (defined in realvirtual.Grip) | realvirtual.Grip | |
| PickBasedOnCylinder | realvirtual.Grip | |
| PickBasedOnSensor | realvirtual.Grip | |
| PickedMUs (defined in realvirtual.Grip) | realvirtual.Grip | |
| PickObjects | realvirtual.Grip | |
| PickOnCylinderMax | realvirtual.Grip | |
| Place() | realvirtual.Grip | |
| PlaceAlignWithObject | realvirtual.Grip | |
| PlaceLoadOnMU | realvirtual.Grip | |
| PlaceLoadOnMUSensor | realvirtual.Grip | |
| PlaceMode | realvirtual.Grip | |
| PlaceObjects | realvirtual.Grip | |
| RaycastDistance | realvirtual.Grip | |
| ShowGizmo | realvirtual.Grip | |
| SignalPick (defined in realvirtual.Grip) | realvirtual.Grip | |
| SignalPlace (defined in realvirtual.Grip) | realvirtual.Grip | |
| Unfix(MU mu) | realvirtual.Grip | |
