Sink component for removing MUs from the simulation, representing endpoints in material flow systems. More...
| void | DeleteMUs () |
| Deletes all MUs currently in the sink area. | |
| override void | OnOwnershipChanged (bool isOwner) |
| Self-manages multiuser behavior. | |
| bool | UseAGXPhysics |
| bool | DeleteMus |
| Delete MUs. | |
| bool | Dissolve |
| Dissolve MUs. | |
| string | DeleteOnlyTag |
| Delete only MUs with defined Tag. | |
| float | DestroyFadeTime |
| Time in seconds to fade out MU. | |
| PLCOutputBool | Delete |
| PLC output for deleting MUs. | |
| float | SumDestroyed |
| Sum of destroyed objects. | |
| float | DestroyedPerHour |
| Sum of destroyed objects per Hour. | |
| List< GameObject > | CollidingObjects |
| Currently colliding objects. | |
| SinkEventOnDestroy | OnMUDelete |
| Event triggered when an MU is deleted by the sink. | |
| override void | OnStopSim () |
The Sink is a fundamental component in realvirtual that acts as the termination point for MUs in the automation system. It simulates various endpoints such as shipping areas, quality control rejection points, recycling stations, or any location where products exit the simulated system. Sinks automatically detect and remove MUs that enter their trigger area.
Key Features:
- Automatic detection and removal of MUs entering the sink area
- Optional visual dissolve effect for smooth MU disappearance
- Selective deletion based on MU tags for filtering specific products
- Production statistics tracking (total destroyed, rate per hour)
- PLC signal integration for controlled deletion
- Collision-based detection using Unity trigger colliders
- Support for both immediate and delayed destruction
- Event system for tracking destroyed MUs
Common Applications:
- End of production lines where finished products exit
- Quality control stations removing defective items
- Shipping and dispatch areas
- Recycling and waste collection points
- Buffer overflow handling
- Testing and validation endpoints
- Order fulfillment completion points
- Rework station exits
Operation Modes:
- Automatic Mode: MUs are destroyed immediately upon entering
- PLC Controlled: Deletion triggered by PLC signals
- Selective Mode: Only specific tagged MUs are destroyed
- Statistical Mode: Tracks throughput without deletion
Visual Effects:
- Dissolve Effect: Smooth fade-out using shader-based dissolution
- Configurable fade duration for visual feedback
- Compatible with standard and custom shaders
- Optional immediate destruction without effects
Statistics and Monitoring:
- SumDestroyed: Total count of destroyed MUs
- DestroyedPerHour: Current throughput rate calculation
- CollidingObjects: Real-time list of MUs in sink area
- Event notifications for external tracking systems
PLC Integration:
- Delete Signal: Triggers deletion of all MUs currently in sink
- Can be integrated with production control systems
- Supports batch processing scenarios
Performance Considerations:
- Efficient trigger-based detection
- Automatic cleanup of destroyed objects
- Optimized for high-throughput scenarios
- Minimal impact on simulation performance
Events:
- OnMUDelete: Fired when an MU is destroyed
- Provides destroyed MU reference for logging or statistics
Setup Requirements:
- Requires BoxCollider component set as trigger
- Automatically configured on component addition
- Size determines the detection area
For detailed documentation see: https://doc.realvirtual.io/components-and-scripts/sink
◆ DeleteMUs()
| void realvirtual.Sink.DeleteMUs | ( | ) |
◆ OnOwnershipChanged()
virtual |
When not owner, disables MU deletion so that MU lifecycle is controlled by the server.
◆ OnStartSim()
protectedvirtual |
◆ OnStopSim()
protectedvirtual |
◆ CollidingObjects
| List<GameObject> realvirtual.Sink.CollidingObjects |
◆ Delete
| PLCOutputBool realvirtual.Sink.Delete |
◆ DeleteMus
| bool realvirtual.Sink.DeleteMus |
Delete MUs.
◆ DeleteOnlyTag
| string realvirtual.Sink.DeleteOnlyTag |
◆ DestroyedPerHour
| float realvirtual.Sink.DestroyedPerHour |
◆ DestroyFadeTime
| float realvirtual.Sink.DestroyFadeTime |
◆ Dissolve
| bool realvirtual.Sink.Dissolve |
Dissolve MUs.
◆ OnMUDelete
| SinkEventOnDestroy realvirtual.Sink.OnMUDelete |
◆ SumDestroyed
| float realvirtual.Sink.SumDestroyed |
