realvirtual.PLCOutputTransform Class Reference
Inheritance diagram for realvirtual.PLCOutputTransform:
| override void | SetValue (String value) |
| override void | SetValue (System.Object value) |
| void | SetValue (Pose value) |
| void | Update () |
| void | SetValueToTransoform () |
| void | SetTransformFromValue () |
| void | FixedUpdate () |
| string | GetSignalName () |
| virtual bool | IsInput () |
| virtual void | SetValue (string value) |
| virtual void | SetValue (object value) |
| void | Unforce () |
| Unforces the signal. | |
| string | GetTypeString () |
| StatusTransform | Status |
| string | Comment |
| string | OriginDataType |
| SettingsSignal | Settings |
| bool | Autoconnected |
| bool | UpdateEnable |
| SignalMetadata | Metadata |
Properties | |
| Pose | Value [get, set] |
| new bool | hidename () |
| string | Visutext |
◆ GetByteSize()
virtual |
◆ GetByteValue()
virtual |
◆ GetStatusConnected()
virtual |
◆ GetValue()
virtual |
◆ GetVisuText()
virtual |
◆ SetStatusConnected()
virtual |
◆ SetValue()
virtual |
