| FixedUpdate() (defined in realvirtual.PLCOutputTransform) | realvirtual.PLCOutputTransform | |
| GetByteSize() (defined in realvirtual.PLCOutputTransform) | realvirtual.PLCOutputTransform | virtual |
| GetByteValue() (defined in realvirtual.PLCOutputTransform) | realvirtual.PLCOutputTransform | virtual |
| GetStatusConnected() | realvirtual.PLCOutputTransform | virtual |
| GetValue() | realvirtual.PLCOutputTransform | virtual |
| GetVisuText() | realvirtual.PLCOutputTransform | virtual |
| IsInput() | realvirtual.Signal | virtual |
| SetStatusConnected(bool status) | realvirtual.PLCOutputTransform | virtual |
| SetTransformFromValue() (defined in realvirtual.PLCOutputTransform) | realvirtual.PLCOutputTransform | |
| SetValue(String value) (defined in realvirtual.PLCOutputTransform) | realvirtual.PLCOutputTransform | |
| SetValue(System.Object value) (defined in realvirtual.PLCOutputTransform) | realvirtual.PLCOutputTransform | |
| SetValue(byte[] value) (defined in realvirtual.PLCOutputTransform) | realvirtual.PLCOutputTransform | virtual |
| SetValue(Pose value) (defined in realvirtual.PLCOutputTransform) | realvirtual.PLCOutputTransform | |
| realvirtual::Signal.SetValue(string value) | realvirtual.Signal | virtual |
| realvirtual::Signal.SetValue(object value) | realvirtual.Signal | virtual |
| SetValueToTransoform() (defined in realvirtual.PLCOutputTransform) | realvirtual.PLCOutputTransform | |
| Status (defined in realvirtual.PLCOutputTransform) | realvirtual.PLCOutputTransform | |
| Value (defined in realvirtual.PLCOutputTransform) | realvirtual.PLCOutputTransform | |
