realvirtual.PLCOutputText Class Reference
PLC INT Output Signal. More...
Inheritance diagram for realvirtual.PLCOutputText:
| void | Update () |
| string | GetSignalName () |
| virtual bool | IsInput () |
| void | Unforce () |
| Unforces the signal. | |
| string | GetTypeString () |
| StatusText | Status |
| string | Comment |
| string | OriginDataType |
| SettingsSignal | Settings |
| bool | Autoconnected |
| bool | UpdateEnable |
| SignalMetadata | Metadata |
Properties | |
| string | Value [get, set] |
| new bool | hidename () |
| string | Visutext |
◆ GetByteSize()
virtual |
◆ GetByteValue()
virtual |
◆ GetStatusConnected()
virtual |
◆ GetValue()
virtual |
◆ GetVisuText()
virtual |
◆ SetStatusConnected()
virtual |
◆ SetValue() [1/3]
virtual |
◆ SetValue() [2/3]
virtual |
◆ SetValue() [3/3]
virtual |
