PLC Integer Input Signal - Represents a 32-bit integer input signal to PLC from simulation. More...
| override bool | IsInput () |
| void | SetValue (int value) |
| Sets the value as an int. | |
| void | FixedUpdate () |
| string | GetSignalName () |
| void | Unforce () |
| Unforces the signal. | |
| string | GetTypeString () |
| StatusInt | Status |
| string | Comment |
| string | OriginDataType |
| SettingsSignal | Settings |
| bool | Autoconnected |
| bool | UpdateEnable |
| SignalMetadata | Metadata |
Properties | |
| int | Value [get, set] |
| new bool | hidename () |
| string | Visutext |
PLCInputInt is a fundamental signal type for sending integer data from Unity simulation to external PLC systems. This component handles 32-bit signed integer values, essential for providing sensor readings, counters, and status codes to PLC control logic.
Key Features:
- Sends 32-bit signed integer values (-2,147,483,648 to 2,147,483,647) to PLC
- Provides real-time value transmission with change detection
- Supports discrete state representation and counting operations
- Includes override capability for testing and debugging
- Maintains connection status for communication reliability
- Automatic type conversion from various numeric formats
Signal Direction: Simulation → PLC (Input to PLC from PLC perspective) The signal transfers integer values from Unity simulation to PLC controllers, enabling simulation to provide sensor readings, counters, position values, and status codes to PLC programs.
Common Applications:
- Receiving production counters and batch quantities
- Reading state machine codes and operation modes
- Transferring array indices and recipe numbers
- Implementing discrete position values (encoder counts)
- Receiving error codes and diagnostic information
- Reading timer and counter values from PLC
- Transferring part types and product identifiers
Interface Integration: PLCInputInt integrates with all major industrial protocols:
- OPC UA: Maps to OPC UA Int32 nodes with proper data typing
- S7 TCP/IP: Direct reading from Siemens S7 DINT data types
- Modbus TCP/RTU: Maps to holding/input registers (2 registers for 32-bit)
- TwinCAT ADS: Connects to Beckhoff DINT variables
- MQTT: Subscribes to integer values in JSON payloads
- Shared Memory: Direct integer array access for high-speed transfer
Data Range and Precision: Supports full 32-bit signed integer range:
- Minimum: -2,147,483,648
- Maximum: 2,147,483,647
- No decimal places (whole numbers only)
- Ideal for counters, indices, and discrete values
Update Mechanism: The component uses FixedUpdate() for physics-synchronized value monitoring, ensuring consistent timing with Unity's simulation cycle. Value changes trigger EventSignalChanged events, allowing dependent components to react to new integer values immediately. This is particularly important for state machines and sequence control logic.
Type Conversion: Automatically handles conversion from various sources:
- String parsing for text-based protocols
- Byte array conversion for binary protocols
- Object casting with proper type checking
- Safe conversion from floating-point values when needed
◆ GetByteSize()
virtual |
◆ GetByteValue()
virtual |
◆ GetStatusConnected()
virtual |
◆ GetValue()
virtual |
◆ GetVisuText()
virtual |
◆ IsInput()
virtual |
◆ SetStatusConnected()
virtual |
◆ SetValue() [1/4]
virtual |
◆ SetValue() [2/4]
| void realvirtual.PLCInputInt.SetValue | ( | int | value | ) |
◆ SetValue() [3/4]
virtual |
◆ SetValue() [4/4]
virtual |
