realvirtual.PLCInputText Class Reference
PLC BOOL INPUT Signal. More...
Inheritance diagram for realvirtual.PLCInputText:
| Sets the Status connected. | |
| Gets the status connected. | |
| Gets the text for displaying it in the hierarchy view. | |
| override bool | IsInput () |
| True if signal is input. | |
| Sets the Value as a string. | |
| void | SetValue (bool value) |
| Sets the Value as a bool. | |
| void | FixedUpdate () |
| string | GetSignalName () |
| void | Unforce () |
| Unforces the signal. | |
| string | GetTypeString () |
| StatusText | Status |
| Status struct of the bool. | |
| string | Comment |
| string | OriginDataType |
| SettingsSignal | Settings |
| bool | Autoconnected |
| bool | UpdateEnable |
| SignalMetadata | Metadata |
Properties | |
| string | Value [get, set] |
| Sets and gets the value. | |
| new bool | hidename () |
| string | Visutext |
◆ GetByteSize()
virtual |
◆ GetByteValue()
virtual |
◆ GetStatusConnected()
virtual |
◆ GetValue()
virtual |
◆ GetVisuText()
virtual |
◆ IsInput()
virtual |
◆ SetStatusConnected()
virtual |
◆ SetValue() [1/4]
| void realvirtual.PLCInputText.SetValue | ( | bool | value | ) |
◆ SetValue() [2/4]
virtual |
◆ SetValue() [3/4]
virtual |
◆ SetValue() [4/4]
virtual |
◆ Status
| StatusText realvirtual.PLCInputText.Status |
Property Documentation
◆ Value
getset |
