| FixedUpdate() (defined in realvirtual.PLCInputText) | realvirtual.PLCInputText | |
| GetByteSize() (defined in realvirtual.PLCInputText) | realvirtual.PLCInputText | virtual |
| GetByteValue() (defined in realvirtual.PLCInputText) | realvirtual.PLCInputText | virtual |
| GetStatusConnected() | realvirtual.PLCInputText | virtual |
| GetValue() | realvirtual.PLCInputText | virtual |
| GetVisuText() | realvirtual.PLCInputText | virtual |
| IsInput() | realvirtual.PLCInputText | virtual |
| SetStatusConnected(bool status) | realvirtual.PLCInputText | virtual |
| SetValue(string value) | realvirtual.PLCInputText | virtual |
| SetValue(byte[] value) (defined in realvirtual.PLCInputText) | realvirtual.PLCInputText | virtual |
| SetValue(object value) | realvirtual.PLCInputText | virtual |
| SetValue(bool value) | realvirtual.PLCInputText | |
| Status | realvirtual.PLCInputText | |
| Value | realvirtual.PLCInputText | |
