| Awake() (defined in realvirtual.MitsubishiMcpXInterface) | realvirtual.MitsubishiMcpXInterface | protected |
| CloseConnection() | realvirtual.MitsubishiMcpXInterface | protectedvirtual |
| CommunicationLoop(CancellationToken cancellationToken) | realvirtual.MitsubishiMcpXInterface | protectedvirtual |
| ConnectionTimeout | realvirtual.MitsubishiMcpXInterface | |
| CopyPropertiesToThreadSafe() | realvirtual.MitsubishiMcpXInterface | protectedvirtual |
| CreateDeviceHierarchy | realvirtual.MitsubishiMcpXInterface | |
| EstablishConnection(CancellationToken cancellationToken) | realvirtual.MitsubishiMcpXInterface | protectedvirtual |
| GXWorks3CsvFile | realvirtual.MitsubishiMcpXInterface | |
| ImportComments | realvirtual.MitsubishiMcpXInterface | |
| ImportCounters | realvirtual.MitsubishiMcpXInterface | |
| ImportDataRegisters | realvirtual.MitsubishiMcpXInterface | |
| ImportDevices() (defined in realvirtual.MitsubishiMcpXInterface) | realvirtual.MitsubishiMcpXInterface | |
| ImportInternalRelays | realvirtual.MitsubishiMcpXInterface | |
| ImportPhysicalInputs | realvirtual.MitsubishiMcpXInterface | |
| ImportPhysicalOutputs | realvirtual.MitsubishiMcpXInterface | |
| ImportSpecialDevices | realvirtual.MitsubishiMcpXInterface | |
| ImportStateRelays | realvirtual.MitsubishiMcpXInterface | |
| ImportTimers | realvirtual.MitsubishiMcpXInterface | |
| IPAddress | realvirtual.MitsubishiMcpXInterface | |
| MaxBatchSizeBits | realvirtual.MitsubishiMcpXInterface | |
| MaxBatchSizeWords | realvirtual.MitsubishiMcpXInterface | |
| MaxGapSize | realvirtual.MitsubishiMcpXInterface | |
| MaxImportDevices | realvirtual.MitsubishiMcpXInterface | |
| MinBatchSize | realvirtual.MitsubishiMcpXInterface | |
| OptimizeBatchReads | realvirtual.MitsubishiMcpXInterface | |
| Port | realvirtual.MitsubishiMcpXInterface | |
| PrepareForBackgroundThread() | realvirtual.MitsubishiMcpXInterface | protectedvirtual |
| UseStandardGXFormat | realvirtual.MitsubishiMcpXInterface | |
| ValidateDeviceAddresses | realvirtual.MitsubishiMcpXInterface | |
