Base class for all realvirtual communication interfaces providing common functionality for PLC and system connections.
More...
| | Creates a new List of InterfaceSignals based on the Components under this Interface GameObject.
| | Create a signal object as sub gameobject.
Signal | AddSignal (InterfaceSignal interfacesignal) |
void | RemoveSignal (InterfaceSignal interfacesignal) |
| | Gets a signal with a name.
| virtual void | OpenInterface () |
| virtual void | CloseInterface () |
void | SetAllSignalStatus (bool connected) |
void | DestroyAllSignals () |
void | DeleteSignals () |
| | Called when network ownership changes.
| | Sets IsNetworkOwner and triggers OnOwnershipChanged callback.
| | Is called by the realvirtualController before the component is started.
| | Is called by the realvirtualController to start or stop the component.
void | StopSim () |
| | Transfers the direction enumeration to a vector.
| | Transfers a vector to the direction enumeration.
float | GetLocalScale (Transform thetransform, DIRECTION direction) |
List< BehaviorInterfaceConnection > | UpdateConnectionInfo () |
List< Signal > | GetConnectedSignals () |
| | Sets the visibility of this object including all subobjects.
List< BehaviorInterfaceConnection > | GetConnections () |
List< Signal > | GetSignals () |
| | Gets a child by name.
| | Gets all child by name.
GameObject | GetChildByNameAlsoHidden (string name) |
List< GameObject > | GetAllMeshesWithGroup (string group) |
List< GameObject > | GetAllWithGroup (string group) |
List< GameObject > | GetAllWithGroups (List< string > groups) |
List< GameObject > | GetAllMeshesWithGroups (List< string > groups) |
List< string > | GetMyGroups () |
List< GameObject > | GetMeshesWithSameGroups () |
List< GameObject > | GetAllWithSameGroups () |
| | Gets the mesh renderers in the childrens.
| | sets the collider in all child objects
| | Displays an error message.
void | ChangeConnectionMode (bool isconnected) |
| | Logs a message.
| | Logs a message with a relation to an object.
| | Logs a warning with a relation to an object.
| | Logs an error with a relation to an object.
| | Logs an error.
| | Displays a gizmo for debugging positions.
| | Freezes all child components to the current poosition.
void | SetRbConstraints (RigidbodyConstraints constraints) |
virtual void | AwakeAlsoDeactivated () |
Manages signal collection, initialization, and lifecycle for derived interface implementations. Automatically discovers and manages all child signal objects (PLCInput/PLCOutput) for data exchange. This abstract base class provides the foundation for creating custom interfaces to connect with external systems. Derive from this class to implement new communication protocols or integrate with proprietary automation systems.
