TwinCAT ADS interface for communication with Beckhoff automation systems using the ADS (Automation Device Specification) protocol. More...
Public Types | |
| enum | updatemode { Cyclic , OnChange , CyclicSumCommand } |
| Opens a connection to TwinCAT ADS Client and initializes the stream readers and Router and ADS Notifications. | |
| Closes the connection to TwinCAT ADS Client. | |
| void | ImportSignals (bool simstart) |
| Imports all signal objects under the interface gameobject. | |
| void | DeleteSignals () |
| string | NetId |
| The TwinCAT NetID of the PLC to communicate with. | |
| int | Port |
| The TwinCAT Port of the PLC to communicate with. | |
| updatemode | UpdateMode |
| int | PLCOutputsMinUpdateCycleMs |
| Specifies if the event should be fired cyclically or only if the variable has changed. | |
| int | PLCOutputsMaxUpdateDelay |
| The ADS server checks whether the variable has changed after this time interval. Unit is in ms. | |
| int | MaxNumberADSSubCommands |
| bool | ReadAllOutputsOnStart |
| bool | WriteAllInputsOnStart |
| bool | DebugMode |
| string | ConnectionStatus |
| The connection Status to the PLC - Connected if everything is ok (ReadOnly) | |
| string | RouterStatus |
| The Status to the Router -. | |
| string | PLCStatus |
| int | NumberInputs |
| The number of Inputs in the interface (ReadOnly) | |
| int | NumberOutputs |
| The number of Outputs in the interface (ReadOnly) | |
| int | StreamLength |
| List< string > | RegExImportSignals |
| List< string > | RegExSkipSignals |
| Regex to limit the imported signals to certain symbols. If nothing is in this list every symbol is imported. | |
| List< string > | RegExSymbolIsPLCInput |
| Regex to limit the imported signals to certain symbols. All Signals which are matchting these Regexs are not imported;. | |
| bool | CreateSubFolders |
| Regex to define which variables are PLCInputs. For some variables like globals which are not linked directly to an input or output it can not be detected automatically. | |
| bool | ReadSignalValuesOnImport |
| Create Subfolders for the Symbols with "." separating the name. | |
Public Attributes inherited from realvirtual.InterfaceThreadedBaseClass | |
| int | MinUpdateCycle |
| int | CommCycleMeasures |
| int | CommCycleNr |
| int | CommTimeMs |
| int | CommTimeMin |
| float | CommTimeMed |
| int | CommTimeMax |
| int | CommCycleMeasureNum |
| int | UpdateCycleMs |
| string | ThreadStatus |
| int | MinUpdateCycle2 |
| int | CommCycleNr2 |
| int | CommTimeMs2 |
| int | CommTimeMin2 |
| float | CommTimeMed2 |
| int | CommTimeMax2 |
| int | CommCycleMeasureNum2 |
| int | UpdateCycleMs2 |
| string | ThreadStatus2 |
| bool | NoThreading |
| bool | TwoThreads |
| bool | IsConnected |
| override void | CommunicationThreadUpdate () |
Protected Member Functions inherited from realvirtual.InterfaceThreadedBaseClass | |
| virtual void | CommunicationThreadClose () |
| virtual void | SecondCommunicationThreadUpdate () |
| virtual void | SecondCommunicationThreadClose () |
| void | OnConnected () |
| void | OnDisconnected () |
| void | OnEnable () |
| void | OnDisable () |
Connects to TwinCAT 2/3 runtime systems including real Beckhoff PLCs (CX, C6, EL series) and TwinCAT soft PLCs on Windows. Supports cyclic and on-change data exchange modes with automatic variable synchronization and sum command optimization. Ideal for virtual commissioning with TwinCAT XAE (Engineering) and testing automation logic before deployment. Configure the AMS NetID and port to match your TwinCAT system configuration (typically port 851 for PLC runtime 1).
◆ CloseInterface()
virtual |
Reimplemented from realvirtual.InterfaceThreadedBaseClass.
◆ CommunicationThreadUpdate()
protectedvirtual |
Block Read
◆ ImportSignals()
| void realvirtual.TwinCatAdsInterface.ImportSignals | ( | bool | simstart | ) |
Create Signals Object if not existing
◆ OpenInterface()
virtual |
Starts Multithreading
◆ ConnectionStatus
| string realvirtual.TwinCatAdsInterface.ConnectionStatus |
◆ CreateSubFolders
| bool realvirtual.TwinCatAdsInterface.CreateSubFolders |
◆ NetId
| string realvirtual.TwinCatAdsInterface.NetId |
◆ NumberInputs
| int realvirtual.TwinCatAdsInterface.NumberInputs |
◆ NumberOutputs
| int realvirtual.TwinCatAdsInterface.NumberOutputs |
◆ PLCOutputsMaxUpdateDelay
| int realvirtual.TwinCatAdsInterface.PLCOutputsMaxUpdateDelay |
◆ PLCOutputsMinUpdateCycleMs
| int realvirtual.TwinCatAdsInterface.PLCOutputsMinUpdateCycleMs |
◆ Port
| int realvirtual.TwinCatAdsInterface.Port |
◆ ReadSignalValuesOnImport
| bool realvirtual.TwinCatAdsInterface.ReadSignalValuesOnImport |
◆ RegExSkipSignals
| List<string> realvirtual.TwinCatAdsInterface.RegExSkipSignals |
◆ RegExSymbolIsPLCInput
| List<string> realvirtual.TwinCatAdsInterface.RegExSymbolIsPLCInput |
◆ RouterStatus
| string realvirtual.TwinCatAdsInterface.RouterStatus |
◆ StreamLength
| int realvirtual.TwinCatAdsInterface.StreamLength |
Public Types inherited from
