| CloseInterface() | realvirtual.TwinCatAdsInterface | virtual |
| CommCycleMeasureNum (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommCycleMeasureNum2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommCycleMeasures (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommCycleNr (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommCycleNr2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMax (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMax2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMed (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMed2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMin (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMin2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMs (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMs2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommunicationThreadClose() (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | protectedvirtual |
| CommunicationThreadUpdate() | realvirtual.TwinCatAdsInterface | protectedvirtual |
| ConnectionStatus | realvirtual.TwinCatAdsInterface | |
| CreateSubFolders | realvirtual.TwinCatAdsInterface | |
| DebugMode (defined in realvirtual.TwinCatAdsInterface) | realvirtual.TwinCatAdsInterface | |
| ImportSignals(bool simstart) | realvirtual.TwinCatAdsInterface | |
| MaxNumberADSSubCommands (defined in realvirtual.TwinCatAdsInterface) | realvirtual.TwinCatAdsInterface | |
| MinUpdateCycle (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| MinUpdateCycle2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| NetId | realvirtual.TwinCatAdsInterface | |
| NoThreading (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| NumberInputs | realvirtual.TwinCatAdsInterface | |
| NumberOutputs | realvirtual.TwinCatAdsInterface | |
| OpenInterface() | realvirtual.TwinCatAdsInterface | virtual |
| PLCOutputsMaxUpdateDelay | realvirtual.TwinCatAdsInterface | |
| PLCOutputsMinUpdateCycleMs | realvirtual.TwinCatAdsInterface | |
| PLCStatus (defined in realvirtual.TwinCatAdsInterface) | realvirtual.TwinCatAdsInterface | |
| Port | realvirtual.TwinCatAdsInterface | |
| ReadAllOutputsOnStart (defined in realvirtual.TwinCatAdsInterface) | realvirtual.TwinCatAdsInterface | |
| ReadSignalValuesOnImport | realvirtual.TwinCatAdsInterface | |
| RegExImportSignals (defined in realvirtual.TwinCatAdsInterface) | realvirtual.TwinCatAdsInterface | |
| RegExSkipSignals | realvirtual.TwinCatAdsInterface | |
| RegExSymbolIsPLCInput | realvirtual.TwinCatAdsInterface | |
| RouterStatus | realvirtual.TwinCatAdsInterface | |
| SecondCommunicationThreadClose() (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | protectedvirtual |
| SecondCommunicationThreadUpdate() (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | protectedvirtual |
| StreamLength | realvirtual.TwinCatAdsInterface | |
| ThreadStatus (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| ThreadStatus2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| TwoThreads (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| UpdateCycleMs (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| UpdateCycleMs2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| updatemode enum name (defined in realvirtual.TwinCatAdsInterface) | realvirtual.TwinCatAdsInterface | |
| UpdateMode (defined in realvirtual.TwinCatAdsInterface) | realvirtual.TwinCatAdsInterface | |
| WriteAllInputsOnStart (defined in realvirtual.TwinCatAdsInterface) | realvirtual.TwinCatAdsInterface | |
