S7 TCP/IP interface for direct communication with Siemens SIMATIC S7 PLCs (S7-300, S7-400, S7-1200, S7-1500). More...
| override GameObject | GetSignal (string name) |
| Gets a signal based on its name. | |
| void | ReadSignalFile () |
| Imports the symbol table and creates the signal objects under this S7interface object. | |
| void | CheckConnection () |
| Connects to the S7 and checks the connection. | |
| void | DeleteSignals () |
| string | Adress |
| The IP address of the PLC. | |
| int | Rack |
| The rack number of the PLC. | |
| int | Slot |
| The slot number of the PLC. | |
| bool | ReverseHighLowBytes |
| Reverses high and low bytes for multi-byte data types (WORD, DWORD, INT, DINT, REAL) | |
| string | SymbolTable |
| The path to the symbol table of the PLC (*.sdf text file) | |
| int | ReduceMaxPduLenth |
| Reduces the maximum PDU length by this value in bytes to avoid communication errors. | |
| float | ReconnectingTime |
| Time in seconds for reconnecting if connection fails. | |
| float | ConnectionTimeout |
| Maximum time in seconds to wait for PLC connection before timeout (prevents Unity freezing) | |
| bool | OnlyWriteToPlcChangedSignals |
| Only writes signals to PLC when their values have changed to reduce network traffic. | |
| bool | AreaReadWriteMode |
| Enables area-based read/write mode for reading and writing continuous memory blocks instead of individual signals. | |
| int | MinAreaMOutput |
| Minimum memory address for M area outputs in bytes. | |
| int | MaxAreaMOutput |
| Maximum memory address for M area outputs in bytes. | |
| int | MinAreaMInput |
| Minimum memory address for M area inputs in bytes. | |
| int | MaxAreaMInput |
| Maximum memory address for M area inputs in bytes. | |
| int | DBOutputs |
| Data block number for outputs. | |
| int | MinAreaDBOutput |
| Minimum byte address within the output data block. | |
| int | MaxAreaDBOutput |
| Maximum byte address within the output data block. | |
| int | DBInputs |
| Data block number for inputs. | |
| int | MinAreaDBInput |
| Minimum byte address within the input data block. | |
| int | MaxAreaDBInput |
| Maximum byte address within the input data block. | |
| string | ConnectionStatus |
| The connection status to the PLC - OK if everything is ok (ReadOnly) | |
| string | PLCStatus |
| The status of the PLC - Running if PLC is running (ReadOnly) | |
| int | RequestedPduLength |
| The requested PDU length in bytes (ReadOnly) | |
| int | NegotiatedPduLenght |
| The negotiated PDU length in bytes (ReadOnly) | |
| int | NumberInputs |
| The number of input signals in the interface (ReadOnly) | |
| int | NumberOutputs |
| The number of output signals in the interface (ReadOnly) | |
| ulong | ThreadCycleNum |
| The current communication thread cycle number (ReadOnly) | |
Public Attributes inherited from realvirtual.InterfaceThreadedBaseClass | |
| int | MinUpdateCycle |
| int | CommCycleMeasures |
| int | CommCycleNr |
| int | CommTimeMs |
| int | CommTimeMin |
| float | CommTimeMed |
| int | CommTimeMax |
| int | CommCycleMeasureNum |
| int | UpdateCycleMs |
| string | ThreadStatus |
| int | MinUpdateCycle2 |
| int | CommCycleNr2 |
| int | CommTimeMs2 |
| int | CommTimeMin2 |
| float | CommTimeMed2 |
| int | CommTimeMax2 |
| int | CommCycleMeasureNum2 |
| int | UpdateCycleMs2 |
| string | ThreadStatus2 |
| bool | NoThreading |
| bool | TwoThreads |
| bool | IsConnected |
| override void | CommunicationThreadUpdate () |
| Updates all signals in the parallel communication thread. | |
Protected Member Functions inherited from realvirtual.InterfaceThreadedBaseClass | |
| virtual void | CommunicationThreadClose () |
| virtual void | SecondCommunicationThreadUpdate () |
| virtual void | SecondCommunicationThreadClose () |
| void | OnConnected () |
| void | OnDisconnected () |
| void | OnEnable () |
| void | OnDisable () |
Establishes native S7 protocol connections over Ethernet without requiring additional OPC servers or middleware. Supports reading and writing data blocks (DB), memory areas (M), inputs (I), and outputs (Q) directly from the PLC. This interface is ideal for virtual commissioning with Siemens TIA Portal projects and PLCSIM Advanced simulations. Configure the PLC's IP address, rack and slot numbers to match your hardware configuration or PLCSIM setup.
◆ CheckConnection()
| void realvirtual.S7Interface.CheckConnection | ( | ) |
◆ CloseInterface()
virtual |
Reimplemented from realvirtual.InterfaceThreadedBaseClass.
◆ CommunicationThreadUpdate()
protectedvirtual |
◆ GetSignal()
virtual |
Reimplemented from realvirtual.InterfaceBaseClass.
◆ OpenInterface()
virtual |
◆ ReadSignalFile()
| void realvirtual.S7Interface.ReadSignalFile | ( | ) |
◆ Adress
| string realvirtual.S7Interface.Adress |
◆ AreaReadWriteMode
| bool realvirtual.S7Interface.AreaReadWriteMode |
◆ ConnectionStatus
| string realvirtual.S7Interface.ConnectionStatus |
◆ ConnectionTimeout
| float realvirtual.S7Interface.ConnectionTimeout |
◆ DBInputs
| int realvirtual.S7Interface.DBInputs |
◆ DBOutputs
| int realvirtual.S7Interface.DBOutputs |
◆ MaxAreaDBInput
| int realvirtual.S7Interface.MaxAreaDBInput |
◆ MaxAreaDBOutput
| int realvirtual.S7Interface.MaxAreaDBOutput |
◆ MaxAreaMInput
| int realvirtual.S7Interface.MaxAreaMInput |
◆ MaxAreaMOutput
| int realvirtual.S7Interface.MaxAreaMOutput |
◆ MinAreaDBInput
| int realvirtual.S7Interface.MinAreaDBInput |
◆ MinAreaDBOutput
| int realvirtual.S7Interface.MinAreaDBOutput |
◆ MinAreaMInput
| int realvirtual.S7Interface.MinAreaMInput |
◆ MinAreaMOutput
| int realvirtual.S7Interface.MinAreaMOutput |
◆ NegotiatedPduLenght
| int realvirtual.S7Interface.NegotiatedPduLenght |
◆ NumberInputs
| int realvirtual.S7Interface.NumberInputs |
◆ NumberOutputs
| int realvirtual.S7Interface.NumberOutputs |
◆ OnlyWriteToPlcChangedSignals
| bool realvirtual.S7Interface.OnlyWriteToPlcChangedSignals |
◆ PLCStatus
| string realvirtual.S7Interface.PLCStatus |
◆ Rack
| int realvirtual.S7Interface.Rack |
◆ ReconnectingTime
| float realvirtual.S7Interface.ReconnectingTime |
◆ ReduceMaxPduLenth
| int realvirtual.S7Interface.ReduceMaxPduLenth |
◆ RequestedPduLength
| int realvirtual.S7Interface.RequestedPduLength |
◆ ReverseHighLowBytes
| bool realvirtual.S7Interface.ReverseHighLowBytes |
◆ Slot
| int realvirtual.S7Interface.Slot |
◆ SymbolTable
| string realvirtual.S7Interface.SymbolTable |
◆ ThreadCycleNum
| ulong realvirtual.S7Interface.ThreadCycleNum |
