| Adress | realvirtual.S7Interface | |
| AreaReadWriteMode | realvirtual.S7Interface | |
| CheckConnection() | realvirtual.S7Interface | |
| CloseInterface() (defined in realvirtual.S7Interface) | realvirtual.S7Interface | virtual |
| CommCycleMeasureNum (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommCycleMeasureNum2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommCycleMeasures (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommCycleNr (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommCycleNr2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMax (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMax2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMed (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMed2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMin (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMin2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMs (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMs2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommunicationThreadClose() (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | protectedvirtual |
| CommunicationThreadUpdate() | realvirtual.S7Interface | protectedvirtual |
| ConnectionStatus | realvirtual.S7Interface | |
| ConnectionTimeout | realvirtual.S7Interface | |
| DBInputs | realvirtual.S7Interface | |
| DBOutputs | realvirtual.S7Interface | |
| GetSignal(string name) | realvirtual.S7Interface | virtual |
| MaxAreaDBInput | realvirtual.S7Interface | |
| MaxAreaDBOutput | realvirtual.S7Interface | |
| MaxAreaMInput | realvirtual.S7Interface | |
| MaxAreaMOutput | realvirtual.S7Interface | |
| MinAreaDBInput | realvirtual.S7Interface | |
| MinAreaDBOutput | realvirtual.S7Interface | |
| MinAreaMInput | realvirtual.S7Interface | |
| MinAreaMOutput | realvirtual.S7Interface | |
| MinUpdateCycle (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| MinUpdateCycle2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| NegotiatedPduLenght | realvirtual.S7Interface | |
| NoThreading (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| NumberInputs | realvirtual.S7Interface | |
| NumberOutputs | realvirtual.S7Interface | |
| OnlyWriteToPlcChangedSignals | realvirtual.S7Interface | |
| OpenInterface() (defined in realvirtual.S7Interface) | realvirtual.S7Interface | virtual |
| PLCStatus | realvirtual.S7Interface | |
| Rack | realvirtual.S7Interface | |
| ReadSignalFile() | realvirtual.S7Interface | |
| ReconnectingTime | realvirtual.S7Interface | |
| ReduceMaxPduLenth | realvirtual.S7Interface | |
| RequestedPduLength | realvirtual.S7Interface | |
| ReverseHighLowBytes | realvirtual.S7Interface | |
| SecondCommunicationThreadClose() (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | protectedvirtual |
| SecondCommunicationThreadUpdate() (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | protectedvirtual |
| Slot | realvirtual.S7Interface | |
| SymbolTable | realvirtual.S7Interface | |
| ThreadCycleNum | realvirtual.S7Interface | |
| ThreadStatus (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| ThreadStatus2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| TwoThreads (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| UpdateCycleMs (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| UpdateCycleMs2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
