Public Types |
Public Member Functions |
Public Attributes |
Protected Member Functions |
List of all members
realvirtual.SEWSimInterface Class Reference
Inheritance diagram for realvirtual.SEWSimInterface:
Public Types | |
| enum | MQTTConnectionStatus { Connecting , Connected , Disconnected } |
| Method to open the interface - ovverride of the base class. | |
| Method to close the interface - ovverride of the base class. | |
| void | DeleteSignals () |
| string | Broker |
| int | Port |
| Address of the MQTT Broker. | |
| bool | UseWString |
| Port number for the MQTT Broker. | |
| string | ReceiveTopicPLCOutputs |
| Use WordString format (Codesys) for MQTT messages - should be turned on for SEW Controllers. | |
| string | SendTopicPLCInputs |
| MQTT topic to receive messages from. | |
| bool | DebugMode |
| MQTT topic to send messages to. | |
| string | SymbolTable |
| Enable or disable debug mode. | |
| string | SplitChar |
| Path to the symbol table CSV file. | |
| int | NumInputs |
| Character used to split values in the CSV file. | |
| int | NumOutputs |
| Number of input signals. | |
Public Attributes inherited from realvirtual.InterfaceThreadedBaseClass | |
| int | MinUpdateCycle |
| int | CommCycleMeasures |
| int | CommCycleNr |
| int | CommTimeMs |
| int | CommTimeMin |
| float | CommTimeMed |
| int | CommTimeMax |
| int | CommCycleMeasureNum |
| int | UpdateCycleMs |
| string | ThreadStatus |
| int | MinUpdateCycle2 |
| int | CommCycleNr2 |
| int | CommTimeMs2 |
| int | CommTimeMin2 |
| float | CommTimeMed2 |
| int | CommTimeMax2 |
| int | CommCycleMeasureNum2 |
| int | UpdateCycleMs2 |
| string | ThreadStatus2 |
| bool | NoThreading |
| bool | TwoThreads |
| bool | IsConnected |
| override void | CommunicationThreadUpdate () |
| Method to update the communication thread - ovverride of the base class. | |
Protected Member Functions inherited from realvirtual.InterfaceThreadedBaseClass | |
| virtual void | CommunicationThreadClose () |
| virtual void | SecondCommunicationThreadUpdate () |
| virtual void | SecondCommunicationThreadClose () |
| void | OnConnected () |
| void | OnDisconnected () |
| void | OnEnable () |
| void | OnDisable () |
◆ CloseInterface()
virtual |
Reimplemented from realvirtual.InterfaceThreadedBaseClass.
◆ CommunicationThreadUpdate()
protectedvirtual |
◆ OpenInterface()
virtual |
◆ DebugMode
| bool realvirtual.SEWSimInterface.DebugMode |
◆ NumInputs
| int realvirtual.SEWSimInterface.NumInputs |
◆ NumOutputs
| int realvirtual.SEWSimInterface.NumOutputs |
◆ Port
| int realvirtual.SEWSimInterface.Port |
◆ ReceiveTopicPLCOutputs
| string realvirtual.SEWSimInterface.ReceiveTopicPLCOutputs |
◆ SendTopicPLCInputs
| string realvirtual.SEWSimInterface.SendTopicPLCInputs |
◆ SplitChar
| string realvirtual.SEWSimInterface.SplitChar |
◆ SymbolTable
| string realvirtual.SEWSimInterface.SymbolTable |
◆ UseWString
| bool realvirtual.SEWSimInterface.UseWString |
Public Types inherited from
