| Broker (defined in realvirtual.SEWSimInterface) | realvirtual.SEWSimInterface | |
| CloseInterface() | realvirtual.SEWSimInterface | virtual |
| CommCycleMeasureNum (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommCycleMeasureNum2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommCycleMeasures (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommCycleNr (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommCycleNr2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMax (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMax2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMed (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMed2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMin (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMin2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMs (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMs2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommunicationThreadClose() (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | protectedvirtual |
| CommunicationThreadUpdate() | realvirtual.SEWSimInterface | protectedvirtual |
| DebugMode | realvirtual.SEWSimInterface | |
| MinUpdateCycle (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| MinUpdateCycle2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| MQTTConnectionStatus enum name (defined in realvirtual.SEWSimInterface) | realvirtual.SEWSimInterface | |
| NoThreading (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| NumInputs | realvirtual.SEWSimInterface | |
| NumOutputs | realvirtual.SEWSimInterface | |
| OpenInterface() | realvirtual.SEWSimInterface | virtual |
| Port | realvirtual.SEWSimInterface | |
| ReceiveTopicPLCOutputs | realvirtual.SEWSimInterface | |
| SecondCommunicationThreadClose() (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | protectedvirtual |
| SecondCommunicationThreadUpdate() (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | protectedvirtual |
| SendTopicPLCInputs | realvirtual.SEWSimInterface | |
| SplitChar | realvirtual.SEWSimInterface | |
| SymbolTable | realvirtual.SEWSimInterface | |
| ThreadStatus (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| ThreadStatus2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| TwoThreads (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| UpdateCycleMs (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| UpdateCycleMs2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| UseWString | realvirtual.SEWSimInterface | |
