realvirtual.TestFastInterface Class Reference
Inheritance diagram for realvirtual.TestFastInterface:
| bool | SimulateError |
| Simulate communication error for testing. | |
| int | ErrorAfterCycles |
| Trigger error after this many cycles. | |
| string | State |
| InterfaceState | state |
| new string | ErrorMessage |
| bool | IsReconnecting |
| int | InputSignals |
| int | OutputSignals |
| int | CommCycleMs |
| int | CycleCount |
| int | UpdateCycleMs |
| bool | AutoReconnect |
| bool | DebugMode |
| bool | IsConnected |
| Main communication loop executed each cycle after connection is established. | |
| Closes the connection to the external system. | |
| virtual async Task | EstablishConnection (CancellationToken cancellationToken) |
| Establishes connection to the external system. | |
| void | Start () |
| new void | OnEnable () |
| new void | OnDisable () |
| void | FixedUpdate () |
| virtual void | CopyPropertiesToThreadSafe () |
| void | OnConnected () |
| void | OnDisconnected () |
| void | DeleteSignals () |
| int | privateCycleCount |
| int | privateCommCycleMs |
◆ CloseConnection()
protectedvirtual |
◆ CommunicationLoop()
protectedvirtual |
◆ ErrorAfterCycles
| int realvirtual.TestFastInterface.ErrorAfterCycles |
◆ SimulateError
| bool realvirtual.TestFastInterface.SimulateError |
