| CloseConnection() | realvirtual.TestFastInterface | protectedvirtual |
| CommunicationLoop(CancellationToken cancellationToken) | realvirtual.TestFastInterface | protectedvirtual |
| CopyPropertiesToThreadSafe() | realvirtual.FastInterfaceBase | protectedvirtual |
| ErrorAfterCycles | realvirtual.TestFastInterface | |
| EstablishConnection(CancellationToken cancellationToken) | realvirtual.FastInterfaceBase | protectedvirtual |
| SimulateError | realvirtual.TestFastInterface | |
