Blueprint interface for manual physics control synchronized with FixedUpdate.
More...
| override void | PreFixedUpdate () |
| | Override PreFixedUpdate to signal whether physics will step this frame.
| override void | PostFixedUpdate () |
| | Override PostFixedUpdate to step physics immediately after all FixedUpdate methods have run.
| | Opens the interface and starts communication thread.
| | Closes the interface and stops communication thread.
| | Enables or disables manual physics control mode.
| | Steps physics simulation forward by a specified time duration.
| | Override PostAllScenesLoaded to prevent base class from opening interface too early.
| | Called by realvirtualController after all scenes are loaded to enable the interface.
| | Creates a new List of InterfaceSignals based on the Components under this Interface GameObject.
| | Create a signal object as sub gameobject.
Signal | AddSignal (InterfaceSignal interfacesignal) |
void | RemoveSignal (InterfaceSignal interfacesignal) |
| | Gets a signal with a name.
void | SetAllSignalStatus (bool connected) |
void | DestroyAllSignals () |
void | DeleteSignals () |
| | Called when network ownership changes.
| | Sets IsNetworkOwner and triggers OnOwnershipChanged callback.
| | Is called by the realvirtualController before the component is started.
| | Is called by the realvirtualController to start or stop the component.
void | StopSim () |
| | Transfers the direction enumeration to a vector.
| | Transfers a vector to the direction enumeration.
float | GetLocalScale (Transform thetransform, DIRECTION direction) |
List< BehaviorInterfaceConnection > | UpdateConnectionInfo () |
List< Signal > | GetConnectedSignals () |
| | Sets the visibility of this object including all subobjects.
List< BehaviorInterfaceConnection > | GetConnections () |
List< Signal > | GetSignals () |
| | Gets a child by name.
| | Gets all child by name.
GameObject | GetChildByNameAlsoHidden (string name) |
List< GameObject > | GetAllMeshesWithGroup (string group) |
List< GameObject > | GetAllWithGroup (string group) |
List< GameObject > | GetAllWithGroups (List< string > groups) |
List< GameObject > | GetAllMeshesWithGroups (List< string > groups) |
List< string > | GetMyGroups () |
List< GameObject > | GetMeshesWithSameGroups () |
List< GameObject > | GetAllWithSameGroups () |
| | Gets the mesh renderers in the childrens.
| | sets the collider in all child objects
| | Displays an error message.
void | ChangeConnectionMode (bool isconnected) |
| | Logs a message.
| | Logs a message with a relation to an object.
| | Logs a warning with a relation to an object.
| | Logs an error with a relation to an object.
| | Logs an error.
| | Displays a gizmo for debugging positions.
| | Freezes all child components to the current poosition.
void | SetRbConstraints (RigidbodyConstraints constraints) |
virtual void | AwakeAlsoDeactivated () |
| string | ManualPhysicsStatus |
| | Current manual physics control status.
| float | SpeedPercentage |
| | Physics simulation speed as percentage (100=real-time, 50=half speed via frame skipping, 25=quarter speed, 0=paused). Simulates external system throttling by skipping physics steps.
| bool | EnableManualControl |
| | Enable manual physics control on start.
| string | State |
| | Current connection status with visual indicator.
| InterfaceState | state |
| | Internal connection state enum.
| new string | ErrorMessage |
| | Last error message if connection failed.
| | Number of reconnection attempts made.
| bool | IsReconnecting |
| | Whether interface is currently attempting to reconnect.
| int | InputSignals |
| | Total number of input signals found.
| int | OutputSignals |
| | Total number of output signals found.
| int | CommCycleMs |
| | Actual communication cycle time in milliseconds.
| int | CycleCount |
| | Total number of communication cycles completed.
| int | UpdateCycleMs |
| | Communication thread update interval in milliseconds.
| | Only send input signals that have changed since last transmission (performance optimization)
| bool | AutoReconnect |
| | Automatically attempt to reconnect on connection loss.
| | Time to wait between reconnection attempts.
| | Maximum reconnection attempts (-1 = unlimited)
bool | DebugMode |
bool | IsConnected |
List< InterfaceSignal > | InterfaceSignals |
Hashtable | SignalNamesOutputs |
Hashtable | SignalNamesInputs |
| | The name of the component if it should be different from the GameObject name.
ActiveOnly | Active |
GameObject | FromTemplate |
realvirtualController | realvirtualController |
bool | HideNonG44Components |
bool | SceneIsAdditive |
bool | ForceStop |
| | True when this component owns its simulation (local authority). Set to false by MultiplayerWEB on remote clients.
| override void | PrepareForBackgroundThread () |
| | Override PrepareForBackgroundThread to initialize manual physics control BEFORE communication starts.
| override void | CleanupAfterBackgroundThread () |
| | Override CleanupAfterBackgroundThread to restore auto physics.
| virtual void | OnApplicationQuit () |
| | Cleanup when application quits or play mode stops.
| override async System.Threading.Tasks.Task | EstablishConnection (System.Threading.CancellationToken cancellationToken) |
| | Override in derived classes to establish connection to external system.
| override async System.Threading.Tasks.Task | CommunicationLoop (System.Threading.CancellationToken cancellationToken) |
| | Override in derived classes for communication loop with external system.
| | Override in derived classes to close connection to external system.
| virtual async Task | EstablishConnection (CancellationToken cancellationToken) |
| | Establishes connection to the external system.
| virtual async Task | CommunicationLoop (CancellationToken cancellationToken) |
| | Main communication loop executed each cycle after connection is established.
| | Handles communication errors and manages reconnection logic.
| | Called when communication thread starts successfully.
| | Called when communication thread stops.
| void | Start () |
| | Unity Start - block base class behavior.
| new void | OnEnable () |
| | Unity OnEnable - opens interface when component is enabled.
new void | OnDisable () |
| | Handles application pause events.
| void | FixedUpdate () |
| | Unity FixedUpdate for main thread operations (signal sync moved to PrePost FixedUpdate)
| | Gets all input signal values to send to PLC from background threads.
| | Gets only changed input signal values to send to PLC from background threads.
| | Resets change detection forcing all inputs to be considered changed on next call.
| | Sets output signal values from PLC data in background threads.
| | Sets single output signal value from PLC data in background threads.
| | Rebuilds the cached signal arrays used by SyncOutputsToUnity/SyncInputsFromUnity.
| | [DEPRECATED] Use GetInputsForPLC() instead for clearer data flow direction
| | [DEPRECATED] Use GetChangedInputsForPLC() instead for clearer data flow direction
| | [DEPRECATED] Use SetOutputsFromPLC() instead for clearer data flow direction
| | [DEPRECATED] Use SetOutputFromPLC() instead for clearer data flow direction
| virtual void | CopyPropertiesToThreadSafe () |
| | Copies MonoBehaviour properties to thread-safe variables before background thread starts.
| | Updates input and output signal counts.
void | OnConnected () |
void | OnDisconnected () |
bool | hidename () |
bool | hideactiveonly () |
virtual void | OnPreStartSim () |
| | Gets the top of an MU component (the first MU script going up in the hierarchy)
| | Initialiates the components and gets the reference to the realvirtualController in the scene.
virtual void | AfterAwake () |
void | Awake () |
Simulates external systems (e.g., FMU co-simulation, hardware interfaces) by controlling physics simulation timing. Physics.Simulate() is called in PostFixedUpdate immediately after all FixedUpdate scripts have run. Useful for testing how realvirtual behaves when physics stepping needs to be externally controlled. Derived classes implement specific communication protocols while inheriting the physics stepping control.
