KUKA TCP/IP interface for communication with KUKA robot controllers. More...
| void | CreateStandardSignals () |
| Creates standard robot signals organized in subfolders. | |
| void | CreateDigitalInputs (int count=100) |
| Creates digital input signals using FastInterface helper methods. | |
| void | CreateDigitalOutputs (int count=100) |
| Creates digital output signals using FastInterface helper methods. | |
| void | DeleteSignals () |
| string | ServerIP |
| IP address of the KUKA Y200 server. | |
| int | ServerPort |
| TCP port of the KUKA Y200 server. | |
| int | ConnectionTimeoutMs |
| Connection timeout in milliseconds. | |
| int | MaxDigitalSignals |
| Number of digital signals to use (max 8192) | |
| float[] | CurrentAxisValues |
| Current axis values in degrees. | |
| int | ActiveInputs |
| Number of active input signals | |
| int | ActiveOutputs |
| Number of active output signals. | |
| string | State |
| InterfaceState | state |
| new string | ErrorMessage |
| bool | IsReconnecting |
| int | InputSignals |
| int | OutputSignals |
| int | CommCycleMs |
| int | CycleCount |
| int | UpdateCycleMs |
| bool | AutoReconnect |
| bool | DebugMode |
| bool | IsConnected |
| override void | CopyPropertiesToThreadSafe () |
| override async Task | EstablishConnection (CancellationToken cancellationToken) |
| Establishes connection to the external system. | |
| Main communication loop executed each cycle after connection is established. | |
| Closes the connection to the external system. | |
| void | Start () |
| new void | OnEnable () |
| new void | OnDisable () |
| void | FixedUpdate () |
| void | OnConnected () |
| void | OnDisconnected () |
| int | privateCycleCount |
| int | privateCommCycleMs |
The KukaInterface provides communication with KUKA robot controllers using the Y200 protocol over TCP/IP. It supports exchange of robot axis values as PLCOutputFloat signals and digital I/O as PLCInputBool/PLCOutputBool signals.
Key Features:
- TCP/IP communication with KUKA Y200 Server
- Robot axis values as PLCOutputFloat signals
- Digital I/O signals as PLCInputBool/PLCOutputBool
- Thread-safe implementation
- Automatic reconnection on connection loss
Signal Naming Convention:
- Axis signals: "Axis1" to "Axis6" (PLCOutputFloat) for robot axes
- Digital input signals: "InBool0" to "InBool8191" (PLCInputBool) - maps to $IN[1] to $IN[8192]
- Digital output signals: "OutBool0" to "OutBool8191" (PLCOutputBool) - maps to $OUT[1] to $OUT[8192]
Protocol Details:
- FROM KRC: 1144 bytes (Outputs[1024] + Axes[48] + unused position/tool/base data)
- TO KRC: 1024 bytes (Inputs[1024])
For detailed documentation see: https://doc.realvirtual.io/components-and-scripts/interfaces/kuka-y200
◆ CloseConnection()
protectedvirtual |
◆ CommunicationLoop()
protectedvirtual |
◆ CopyPropertiesToThreadSafe()
protectedvirtual |
◆ CreateDigitalInputs()
| void realvirtual.KukaInterface.CreateDigitalInputs | ( | int | count = 100 | ) |
◆ CreateDigitalOutputs()
| void realvirtual.KukaInterface.CreateDigitalOutputs | ( | int | count = 100 | ) |
◆ CreateStandardSignals()
| void realvirtual.KukaInterface.CreateStandardSignals | ( | ) |
◆ EstablishConnection()
protectedvirtual |
◆ ActiveInputs
| int realvirtual.KukaInterface.ActiveInputs |
◆ ActiveOutputs
| int realvirtual.KukaInterface.ActiveOutputs |
◆ ConnectionTimeoutMs
| int realvirtual.KukaInterface.ConnectionTimeoutMs |
◆ CurrentAxisValues
| float [] realvirtual.KukaInterface.CurrentAxisValues |
◆ MaxDigitalSignals
| int realvirtual.KukaInterface.MaxDigitalSignals |
◆ ServerIP
| string realvirtual.KukaInterface.ServerIP |
◆ ServerPort
| int realvirtual.KukaInterface.ServerPort |
