| ActiveInputs | realvirtual.KukaInterface | |
| ActiveOutputs | realvirtual.KukaInterface | |
| CloseConnection() | realvirtual.KukaInterface | protectedvirtual |
| CommunicationLoop(CancellationToken cancellationToken) | realvirtual.KukaInterface | protectedvirtual |
| ConnectionTimeoutMs | realvirtual.KukaInterface | |
| CopyPropertiesToThreadSafe() | realvirtual.KukaInterface | protectedvirtual |
| CreateDigitalInputs(int count=100) | realvirtual.KukaInterface | |
| CreateDigitalOutputs(int count=100) | realvirtual.KukaInterface | |
| CreateStandardSignals() | realvirtual.KukaInterface | |
| CurrentAxisValues | realvirtual.KukaInterface | |
| EstablishConnection(CancellationToken cancellationToken) | realvirtual.KukaInterface | protectedvirtual |
| MaxDigitalSignals | realvirtual.KukaInterface | |
| ServerIP | realvirtual.KukaInterface | |
| ServerPort | realvirtual.KukaInterface | |
