High-performance EtherNet/IP interface for communication with Allen-Bradley/Rockwell Automation PLCs. More...
| void | ImportSignals () |
| Discovers available tags from the connected PLC. | |
| void | ReadSignalFile () |
| Imports signals from a CSV file. | |
| void | TestConnection () |
| Tests connection to the PLC. | |
| void | DeleteSignals () |
| string | Gateway |
| IP address of the Allen-Bradley PLC gateway. | |
| string | Path |
| Path to the PLC processor in the rack. | |
| PlcType | PLCType |
| Type of Allen-Bradley PLC (ControlLogix, CompactLogix, etc.) | |
| Protocol | Protocol |
| Communication protocol (typically ab_eip for EtherNet/IP) | |
| int | Timeout |
| Communication timeout in milliseconds. | |
| DebugLevel | LibPlcTagDebugLevel |
| Debug level for libplctag library output. | |
| string | PLCSignalTable |
| Path to CSV file containing PLC signal definitions. | |
| ulong | UpdateCycle |
| Number of update cycles completed. | |
| int | ActiveTags |
| Number of active tags in communication. | |
| int | FailedTags |
| Number of tags with communication errors. | |
| string | State |
| InterfaceState | state |
| new string | ErrorMessage |
| bool | IsReconnecting |
| int | InputSignals |
| int | OutputSignals |
| int | CommCycleMs |
| int | CycleCount |
| int | UpdateCycleMs |
| bool | AutoReconnect |
| bool | DebugMode |
| bool | IsConnected |
| override void | CopyPropertiesToThreadSafe () |
| Copies MonoBehaviour properties to thread-safe variables for background thread access. | |
| override async Task | EstablishConnection (CancellationToken cancellationToken) |
| Establishes connection to the Allen-Bradley PLC. | |
| Main communication loop for cyclic data exchange with PLC using FastSignalManager and metadata. | |
| Closes connection and cleans up resources. | |
| new void | Awake () |
| Called when the component is first initialized. | |
| new void | FixedUpdate () |
| Updates statistics display in the Unity Editor. | |
| void | OnDestroy () |
| Cleanup when component is destroyed. | |
| void | Start () |
| new void | OnEnable () |
| new void | OnDisable () |
| void | OnConnected () |
| void | OnDisconnected () |
| int | privateCycleCount |
| int | privateCommCycleMs |
This interface provides robust, thread-safe communication with ControlLogix, CompactLogix, MicroLogix, and other EtherNet/IP compatible controllers. It supports tag-based data access for seamless integration with RSLogix/Studio 5000 projects and Factory Talk applications.
Key Features:
- Thread-safe background communication using FastInterface architecture
- Support for REAL, BOOL, SINT, INT, DINT data types
- Automatic reconnection on network failuresye
- CSV-based signal table import for bulk signal configuration
- Tag discovery from connected PLC
- Metadata-based tag mapping for flexible signal routing
Common Applications:
- Virtual commissioning with Rockwell Automation systems
- Integration with Factory Talk applications
- Real-time data exchange with Allen-Bradley PLCs
- Industrial simulation with actual PLC hardware
Integration Points:
- Works with realvirtual signal system (PLCInputBool, PLCOutputFloat, etc.)
- Compatible with FastSignalManager for high-performance signal access
- Integrates with Unity's component lifecycle for proper resource management
Performance Considerations:
- Uses async/await patterns for non-blocking communication
- Batch operations for efficient tag reading/writing
- OnlyTransmitChangedInputs option for bandwidth optimization
- Configurable update cycle for balancing responsiveness and CPU usage
For detailed documentation see: https://doc.realvirtual.io/components-and-scripts/interfaces/ethernetip
◆ Awake()
protected |
◆ CloseConnection()
protectedvirtual |
◆ CommunicationLoop()
protectedvirtual |
◆ CopyPropertiesToThreadSafe()
protectedvirtual |
◆ EstablishConnection()
protectedvirtual |
◆ FixedUpdate()
protected |
◆ ImportSignals()
| void realvirtual.EthernetIPInterface.ImportSignals | ( | ) |
◆ OnDestroy()
protected |
◆ ReadSignalFile()
| void realvirtual.EthernetIPInterface.ReadSignalFile | ( | ) |
◆ TestConnection()
| void realvirtual.EthernetIPInterface.TestConnection | ( | ) |
◆ ActiveTags
| int realvirtual.EthernetIPInterface.ActiveTags |
◆ FailedTags
| int realvirtual.EthernetIPInterface.FailedTags |
◆ Gateway
| string realvirtual.EthernetIPInterface.Gateway |
◆ LibPlcTagDebugLevel
| DebugLevel realvirtual.EthernetIPInterface.LibPlcTagDebugLevel |
◆ Path
| string realvirtual.EthernetIPInterface.Path |
◆ PLCSignalTable
| string realvirtual.EthernetIPInterface.PLCSignalTable |
◆ PLCType
| PlcType realvirtual.EthernetIPInterface.PLCType |
◆ Protocol
| Protocol realvirtual.EthernetIPInterface.Protocol |
◆ Timeout
| int realvirtual.EthernetIPInterface.Timeout |
◆ UpdateCycle
| ulong realvirtual.EthernetIPInterface.UpdateCycle |
