realvirtual.BlueprintFastInterfaceSimple Class Reference
Minimal template for creating custom fast interfaces Copy this file and replace the connection and communication logic with your protocol. More...
Inheritance diagram for realvirtual.BlueprintFastInterfaceSimple:
| override async Task | EstablishConnection (CancellationToken cancellationToken) |
| Establish connection to external system (runs on background thread) | |
| Main communication loop (runs repeatedly on background thread) | |
| Clean up connection (runs on background thread) | |
| void | Start () |
| new void | OnEnable () |
| new void | OnDisable () |
| void | FixedUpdate () |
| virtual void | CopyPropertiesToThreadSafe () |
| void | OnConnected () |
| void | OnDisconnected () |
| void | DeleteSignals () |
| string | State |
| InterfaceState | state |
| new string | ErrorMessage |
| bool | IsReconnecting |
| int | InputSignals |
| int | OutputSignals |
| int | CommCycleMs |
| int | CycleCount |
| int | UpdateCycleMs |
| bool | AutoReconnect |
| bool | DebugMode |
| bool | IsConnected |
| int | privateCycleCount |
| int | privateCommCycleMs |
◆ CloseConnection()
protectedvirtual |
◆ CommunicationLoop()
protectedvirtual |
◆ EstablishConnection()
protectedvirtual |
