| CloseConnection() | realvirtual.FastInterfaceBase | protectedvirtual |
| CommunicationLoop(CancellationToken cancellationToken) | realvirtual.FastInterfaceBase | protectedvirtual |
| CopyPropertiesToThreadSafe() | realvirtual.FastInterfaceBase | protectedvirtual |
| EstablishConnection(CancellationToken cancellationToken) | realvirtual.FastInterfaceBase | protectedvirtual |
