Interface for Festo PLCnext controllers using the RSC (Remote Service Call) data access API. More...
| Opens the interface: refreshes the signal manager, builds caches, then starts communication. | |
| void | DeleteSignals () |
| string | Host |
| IP address or hostname of the PLCnext controller. | |
| int | Port |
| RSC service port (default 41100) | |
| bool | UseTLS |
| Enable TLS encryption for the RSC connection. | |
| bool | ValidateCertificate |
| Validate TLS certificate (disable for self-signed certs) | |
| string | Username |
| RSC authentication username. | |
| string | Password |
| RSC authentication password. | |
| float | ConnectionTimeoutSeconds |
| Connection and read/write timeout in seconds. | |
| bool | UseSubscription |
| Use real-time subscription instead of polling for output signals. | |
| int | SubscriptionCycleMs |
| Subscription sample rate in milliseconds (default 100 ms) | |
| string | State |
| InterfaceState | state |
| new string | ErrorMessage |
| bool | IsReconnecting |
| int | InputSignals |
| int | OutputSignals |
| int | CommCycleMs |
| int | CycleCount |
| int | UpdateCycleMs |
| bool | AutoReconnect |
| bool | DebugMode |
| bool | IsConnected |
| override void | CopyPropertiesToThreadSafe () |
| Copies Unity-thread Inspector properties to thread-safe fields before communication starts. | |
| override void | PrepareForBackgroundThread () |
| Builds address caches on the main thread so the background communication thread can read them without touching Unity GameObjects. | |
| override void | CleanupAfterBackgroundThread () |
| Cleans up address caches when the background thread stops. | |
| override async Task | EstablishConnection (CancellationToken cancellationToken) |
| Establishes the RSC connection to the PLCnext controller on the background thread. | |
| Closes the RSC connection and releases all protocol resources. | |
| override void | OnCommunicationStarted () |
| Called when background communication starts successfully. | |
| Cyclic communication: reads outputs from PLCnext, writes inputs to PLCnext. | |
| void | Start () |
| new void | OnEnable () |
| new void | OnDisable () |
| void | FixedUpdate () |
| void | OnConnected () |
| void | OnDisconnected () |
| int | privateCycleCount |
| int | privateCommCycleMs |
Connects realvirtual signals to Festo PLCnext variables via the RSC library (TCP port 41100). Both polling and subscription modes are supported. In subscription mode the PLCnext controller pushes real-time values at a configurable sample rate; in polling mode every communication cycle performs a batched read of all output-signal variables.
Signal direction convention follows the standard realvirtual PLC convention:
- PLC Output signals (PLCnext→Unity) map to PLCnext variables that the PLC writes.
- PLC Input signals (Unity→PLC) map to PLCnext variables that Unity writes to the PLC.
Key Features:
- Subscription mode for low-latency, push-based data exchange
- Polling mode as fallback or for PLCnext firmware that does not support subscriptions
- Batched write for all changed input signals each cycle
- Signal metadata key "Address" stores the full PLCnext variable path, e.g. "Arp.Plc.Eclr/MainInstance.Motor1_Running"
- Editor button to import variables from the PLC and create signals automatically
- Automatic reconnection via the FastInterfaceBase reconnect cycle
Variable path format: "ComponentName/ProgramName.VariableName" Arrays: "Component/Program.Array[0]" or "Component/Program.Array[0:9]" Structs: "Component/Program.Struct.Element.Leaf"
For detailed documentation see: https://doc.realvirtual.io/components-and-scripts/interfaces/festo-plcnext
◆ CleanupAfterBackgroundThread()
protectedvirtual |
IMPLEMENTS FastInterfaceBase::CleanupAfterBackgroundThread
◆ CloseConnection()
protectedvirtual |
IMPLEMENTS FastInterfaceBase::CloseConnection
◆ CommunicationLoop()
protectedvirtual |
IMPLEMENTS FastInterfaceBase::CommunicationLoop
◆ CopyPropertiesToThreadSafe()
protectedvirtual |
IMPLEMENTS FastInterfaceBase::CopyPropertiesToThreadSafe
◆ EstablishConnection()
protectedvirtual |
Throws on failure so FastInterfaceBase can trigger the auto-reconnect cycle. IMPLEMENTS FastInterfaceBase::EstablishConnection
◆ OnCommunicationStarted()
protectedvirtual |
IMPLEMENTS FastInterfaceBase::OnCommunicationStarted
◆ OpenInterface()
virtual |
IMPLEMENTS FastInterfaceBase::OpenInterface
◆ PrepareForBackgroundThread()
protectedvirtual |
IMPLEMENTS FastInterfaceBase::PrepareForBackgroundThread
◆ ConnectionTimeoutSeconds
| float realvirtual.FestoInterface.ConnectionTimeoutSeconds |
◆ Host
| string realvirtual.FestoInterface.Host |
◆ Password
| string realvirtual.FestoInterface.Password |
◆ Port
| int realvirtual.FestoInterface.Port |
◆ SubscriptionCycleMs
| int realvirtual.FestoInterface.SubscriptionCycleMs |
◆ Username
| string realvirtual.FestoInterface.Username |
◆ UseSubscription
| bool realvirtual.FestoInterface.UseSubscription |
◆ UseTLS
| bool realvirtual.FestoInterface.UseTLS |
◆ ValidateCertificate
| bool realvirtual.FestoInterface.ValidateCertificate |
