| CleanupAfterBackgroundThread() | realvirtual.FestoInterface | protectedvirtual |
| CloseConnection() | realvirtual.FestoInterface | protectedvirtual |
| CommunicationLoop(CancellationToken cancellationToken) | realvirtual.FestoInterface | protectedvirtual |
| ConnectionTimeoutSeconds | realvirtual.FestoInterface | |
| CopyPropertiesToThreadSafe() | realvirtual.FestoInterface | protectedvirtual |
| EstablishConnection(CancellationToken cancellationToken) | realvirtual.FestoInterface | protectedvirtual |
| Host | realvirtual.FestoInterface | |
| OnCommunicationStarted() | realvirtual.FestoInterface | protectedvirtual |
| OpenInterface() | realvirtual.FestoInterface | virtual |
| Password | realvirtual.FestoInterface | |
| Port | realvirtual.FestoInterface | |
| PrepareForBackgroundThread() | realvirtual.FestoInterface | protectedvirtual |
| SubscriptionCycleMs | realvirtual.FestoInterface | |
| Username | realvirtual.FestoInterface | |
| UseSubscription | realvirtual.FestoInterface | |
| UseTLS | realvirtual.FestoInterface | |
| ValidateCertificate | realvirtual.FestoInterface | |
