Blueprint/example interface demonstrating signal handling without external communication. More...
| Opens the interface - called on main thread. | |
| Closes the interface - called on main thread. | |
| void | DeleteSignals () |
| int | LogIntervalCycles |
| Log signal values every N cycles when DebugMode is enabled. | |
| bool | SimulateValueChanges |
| Simulate changing values for output signals. | |
| float | ValueChangeSpeed |
| Speed of simulated value changes. | |
| int | TotalSignalsFound |
| Total number of signals found. | |
| int | InputSignalCount |
| Number of input signals. | |
| int | OutputSignalCount |
| Number of output signals. | |
| int | DataExchangeCycles |
| Number of communication cycles completed. | |
| float | SimulationTime |
| Total simulation time in seconds. | |
| string | State |
| InterfaceState | state |
| new string | ErrorMessage |
| bool | IsReconnecting |
| int | InputSignals |
| int | OutputSignals |
| int | CommCycleMs |
| int | CycleCount |
| int | UpdateCycleMs |
| bool | AutoReconnect |
| bool | DebugMode |
| bool | IsConnected |
| virtual void | OnInterfaceStarting () |
| Called when interface starts - performs initialization on main thread This method is called from OpenInterface() BEFORE the background communication thread starts. | |
| virtual void | OnInterfaceStopping () |
| Called when interface stops - performs cleanup on main thread This method is called from CloseInterface() AFTER the background communication thread has stopped. | |
| override async Task | EstablishConnection (CancellationToken cancellationToken) |
| Establishes connection on background thread This method is called ONCE when starting communication. | |
| Main communication processing on background thread This method is called REPEATEDLY in a loop after connection is established. | |
| Cleanup when closing connection on background thread This method is called when stopping communication or before reconnection. | |
| override void | OnCommunicationStarted () |
| void | Start () |
| new void | OnEnable () |
| new void | OnDisable () |
| void | FixedUpdate () |
| virtual void | CopyPropertiesToThreadSafe () |
| void | OnConnected () |
| void | OnDisconnected () |
| int | privateCycleCount |
| int | privateCommCycleMs |
This interface serves as a template for creating custom interfaces. It demonstrates:
- Signal discovery and metadata handling
- Thread-safe communication patterns
- Proper initialization and cleanup
- Value simulation for testing
To create your own interface:
- Copy this file and rename the class
- Replace the simulated connection in EstablishConnection() with your real connection logic
- Implement your protocol in ProcessCommunication()
- Add any cleanup code in CloseConnection()
Key helper methods available from FastInterface base class:
- this.GetAllSignals() - Get all child signals efficiently
- this.GetSignalComponent("name") - Find a specific signal by name with O(1) lookup
- GetSignalValue<T>("name") - Get signal value directly with fast access
- SetSignalValue<T>("name", value) - Set signal value directly with fast access Note: Additional extension methods may be available from FastSignalManagerHelper for specialized operations like signal creation and batch operations
Thread-safe data exchange (use in ProcessCommunication):
- GetInputsForPLC() - Read all input values safely from background thread
- SetOutputsFromPLC() - Write output values safely from background thread
Signal metadata methods:
- signal.SetMetadata("key", value) - Store custom data with signals
- signal.GetMetadata<T>("key") - Retrieve metadata
- signal.HasMetadata("key") - Check if metadata exists
◆ CloseConnection()
protectedvirtual |
Use this to:
- Close network connections gracefully
- Send disconnect messages to external system
- Dispose of communication resources
- Clean up any background thread resources
IMPORTANT: This runs on a background thread - do NOT access Unity GameObjects! This is called both during normal shutdown and before reconnection attempts.
Available methods:
- ThreadSafeLogger.LogInfo/LogError/LogWarning() - Thread-safe logging
- privateCycleCount - Get total cycles completed for logging
- Connection cleanup methods (Close(), Dispose(), Disconnect())
Example TCP cleanup: stream?.Close(); stream?.Dispose(); tcpClient?.Close();
◆ CloseInterface()
virtual |
Reimplemented from realvirtual.InterfaceBaseClass.
◆ CommunicationLoop()
protectedvirtual |
Use this to:
- Read data from external system
- Process received data and update output signals
- Read input signals and send to external system
- Handle protocol-specific communication
IMPORTANT: This runs on a background thread - do NOT access Unity GameObjects directly! The base class handles the loop timing based on UpdateCycleMs setting. This method should complete quickly to maintain consistent cycle times.
Available methods for signal data exchange:
- GetInputsForPLC(OnlyTransmitChangedInputs) - Get input signal values as Dictionary<string, object>
- SetOutputsFromPLC(Dictionary<string, object>) - Update output signal values
Available helper properties/fields:
- threadSafeDebugMode - Thread-safe copy of DebugMode property
- threadSafeUpdateCycleMs - Thread-safe copy of UpdateCycleMs
- threadSafeOnlyTransmitChangedInputs - Thread-safe copy of OnlyTransmitChangedInputs
- privateCycleCount - Current cycle number (use for statistics)
Available methods for logging and communication:
- ThreadSafeLogger.LogInfoIf(condition, message, source) - Conditional logging
- Network read/write methods on your connection objects
- Protocol-specific encoding/decoding methods
Example TCP pattern: byte[] buffer = new byte[1024]; int bytesRead = await stream.ReadAsync(buffer, 0, buffer.Length); await stream.WriteAsync(data, 0, data.Length);
◆ EstablishConnection()
protectedvirtual |
Use this to:
- Open network connections (TCP, UDP, WebSocket, etc.)
- Authenticate with external systems
- Perform handshaking protocols
- Initialize communication libraries
IMPORTANT: This runs on a background thread - do NOT access Unity GameObjects! If connection fails, throw an exception. The base class will handle reconnection automatically.
Available methods:
- Task.Delay(milliseconds) - Async delays
- Standard .NET networking classes (TcpClient, UdpClient, HttpClient, ClientWebSocket)
- throw new Exception("message") - To indicate connection failure
Example TCP implementation: tcpClient = new TcpClient(); await tcpClient.ConnectAsync(ip, port); stream = tcpClient.GetStream();
◆ OnCommunicationStarted()
protectedvirtual |
◆ OnInterfaceStarting()
protectedvirtual |
The signal manager is already initialized by the base class before this method is called. Use this to:
- Discover and configure signals
- Set up any data structures needed for communication
- Add metadata to signals
- Initialize hardware or libraries (main thread only operations)
IMPORTANT: This runs on the Unity main thread, so you can safely access GameObjects IMPORTANT: Signal manager is pre-initialized - you can immediately use all helper methods
Available methods from FastInterface base class:
- this.GetAllSignals() - Get all child signals as IEnumerable<Signal>
- this.GetSignalComponent("signalName") - Find specific signal by name (O(1) lookup)
- GetSignalValue<T>("signalName") - Get signal value directly
- SetSignalValue<T>("signalName", value) - Set signal value directly
Available extension methods from FastSignalManagerHelper (for Editor operations):
- this.CreateOrUpdateSignal("name", SignalType.Bool, SignalDirection.Input, metadata)
- signal.SetMetadata("key", value) - Add metadata to existing signals
- signal.GetMetadata<T>("key", defaultValue) - Read signal metadata
- this.GetAllSignals().Where(s => s.HasMetadata("key")) - Find signals by metadata
- this.HasSignal("signalName") - Check if signal exists
- this.GetInputSignals() / this.GetOutputSignals() - Get signals by direction
- this.CountSignals(direction, signalType) - Count signals by criteria
NEW: Comprehensive Signal Management with CreateOrUpdateSignal:
- this.CreateOrUpdateSignal("name", SignalType.Bool, SignalDirection.Input, metadata) → Creates new signal if doesn't exist → Updates metadata if signal exists with same direction → Replaces signal component if direction changed (keeps GameObject)
Example usage for dynamic signal import: var metadata = new Dictionary<string, object> { ["Source"] = "PLC", ["Address"] = "DB100.DBX0.0" }; var signal = this.CreateOrUpdateSignal("Motor1_Running", SignalType.Bool, SignalDirection.Output, metadata);
Signal direction change handling: // If Motor1_Running was previously an Input, it will be replaced with Output component // The GameObject is preserved, only the component changes signal = this.CreateOrUpdateSignal("Motor1_Running", SignalType.Bool, SignalDirection.Output, metadata, allowDirectionChange: true);
◆ OnInterfaceStopping()
protectedvirtual |
Use this to:
- Log final statistics
- Clean up any resources created in OnInterfaceStarting
- Save any persistent data
IMPORTANT: This runs on the Unity main thread after communication has fully stopped
Available methods:
- this.GetAllSignals() - Access all signals for final state logging
- this.GetSignalValue<T>("signalName") - Read final signal values
- Debug.Log() - Safe to use Unity logging
◆ OpenInterface()
virtual |
◆ DataExchangeCycles
| int realvirtual.BlueprintFastInterface.DataExchangeCycles |
◆ InputSignalCount
| int realvirtual.BlueprintFastInterface.InputSignalCount |
◆ LogIntervalCycles
| int realvirtual.BlueprintFastInterface.LogIntervalCycles |
◆ OutputSignalCount
| int realvirtual.BlueprintFastInterface.OutputSignalCount |
◆ SimulateValueChanges
| bool realvirtual.BlueprintFastInterface.SimulateValueChanges |
◆ SimulationTime
| float realvirtual.BlueprintFastInterface.SimulationTime |
◆ TotalSignalsFound
| int realvirtual.BlueprintFastInterface.TotalSignalsFound |
◆ ValueChangeSpeed
| float realvirtual.BlueprintFastInterface.ValueChangeSpeed |
