| CloseConnection() | realvirtual.BlueprintFastInterface | protectedvirtual |
| CloseInterface() | realvirtual.BlueprintFastInterface | virtual |
| CommunicationLoop(CancellationToken cancellationToken) | realvirtual.BlueprintFastInterface | protectedvirtual |
| CopyPropertiesToThreadSafe() | realvirtual.FastInterfaceBase | protectedvirtual |
| DataExchangeCycles | realvirtual.BlueprintFastInterface | |
| EstablishConnection(CancellationToken cancellationToken) | realvirtual.BlueprintFastInterface | protectedvirtual |
| InputSignalCount | realvirtual.BlueprintFastInterface | |
| LogIntervalCycles | realvirtual.BlueprintFastInterface | |
| OnCommunicationStarted() | realvirtual.BlueprintFastInterface | protectedvirtual |
| OnInterfaceStarting() | realvirtual.BlueprintFastInterface | protectedvirtual |
| OnInterfaceStopping() | realvirtual.BlueprintFastInterface | protectedvirtual |
| OpenInterface() | realvirtual.BlueprintFastInterface | virtual |
| OutputSignalCount | realvirtual.BlueprintFastInterface | |
| SimulateValueChanges | realvirtual.BlueprintFastInterface | |
| SimulationTime | realvirtual.BlueprintFastInterface | |
| TotalSignalsFound | realvirtual.BlueprintFastInterface | |
| ValueChangeSpeed | realvirtual.BlueprintFastInterface | |
