CAM for moving drives based on CAM profiles. More...
Classes | |
| class | campoint |
| void | ImportCam () |
| void | StartTimeCAM () |
| static float | GetFloat (string value, float defaultValue) |
| float | CAMTimeScale |
| An scale of the Time makes CAM faster or slowér. | |
| float | CAMAxisScale |
| The scale of the CAM axis. It will scale the values of the CAM curve. | |
| float | CAMAxisOffset |
| The offset of the CAM axis. It will be a offset to the design position. | |
| Drive | MasterDrive |
| The master drive this slave drive is attached to. | |
| float | StartOnMasterPosGreaterThan |
| AnimationCurve | CamCurve |
| The Animation Curve which is defining the slave drive position in relation to the master drive position. | |
| TextAsset | CamDefintion |
| A text assed containing the CAM definition. This asset is a table with optional headers and columns describing the master axis position and the slave axis position. | |
| bool | UseColumnNames |
| If true the Column Names are used to define the data to import. | |
| string | MasterTime |
| The master axis column name. | |
| string | AxisColumn |
| The slave axis column name. | |
| bool | UseColumnNumbers |
| If true the Column Numbers (starting with 1 for the 1st column) are used to define the data to import. | |
| int | TimeColumnNum |
| The master axis column number. | |
| int | AxisColumnNum |
| The slave axis column number. | |
| bool | CamDefinitionWithHeader |
| if true during import a column header is expected and first line of the imported data should be a header | |
| bool | ImportOnStart |
| CAMTime | StartCamWhenFinished |
| bool | StartCAM |
| bool | IsActive |
| bool | IsFinished |
| float | CurrentCAMTime |
| PLCOutputBool | PLCStartCAM |
| PLCOutputFloat | PLCScaleCAM |
| PLCInputBool | PLCCAMIsRunning |
| PLCInputBool | PLCCAMIsFinished |
| PLCInputFloat | PLCCurrentCAMTime |
Class Documentation
◆ realvirtual::CAMTime::campoint
◆ AxisColumn
| string realvirtual.CAMTime.AxisColumn |
◆ AxisColumnNum
| int realvirtual.CAMTime.AxisColumnNum |
◆ CAMAxisOffset
| float realvirtual.CAMTime.CAMAxisOffset |
◆ CAMAxisScale
| float realvirtual.CAMTime.CAMAxisScale |
◆ CamCurve
| AnimationCurve realvirtual.CAMTime.CamCurve |
◆ CamDefinitionWithHeader
| bool realvirtual.CAMTime.CamDefinitionWithHeader |
◆ CamDefintion
| TextAsset realvirtual.CAMTime.CamDefintion |
◆ CAMTimeScale
| float realvirtual.CAMTime.CAMTimeScale |
◆ MasterDrive
| Drive realvirtual.CAMTime.MasterDrive |
◆ MasterTime
| string realvirtual.CAMTime.MasterTime |
◆ TimeColumnNum
| int realvirtual.CAMTime.TimeColumnNum |
◆ UseColumnNames
| bool realvirtual.CAMTime.UseColumnNames |
◆ UseColumnNumbers
| bool realvirtual.CAMTime.UseColumnNumbers |
