| AxisColumn | realvirtual.CAMTime | |
| AxisColumnNum | realvirtual.CAMTime | |
| CAMAxisOffset | realvirtual.CAMTime | |
| CAMAxisScale | realvirtual.CAMTime | |
| CamCurve | realvirtual.CAMTime | |
| CamDefinitionWithHeader | realvirtual.CAMTime | |
| CamDefintion | realvirtual.CAMTime | |
| CAMTimeScale | realvirtual.CAMTime | |
| CurrentCAMTime (defined in realvirtual.CAMTime) | realvirtual.CAMTime | |
| GetFloat(string value, float defaultValue) (defined in realvirtual.CAMTime) | realvirtual.CAMTime | static |
| ImportCam() (defined in realvirtual.CAMTime) | realvirtual.CAMTime | |
| ImportOnStart (defined in realvirtual.CAMTime) | realvirtual.CAMTime | |
| IsActive (defined in realvirtual.CAMTime) | realvirtual.CAMTime | |
| IsFinished (defined in realvirtual.CAMTime) | realvirtual.CAMTime | |
| MasterDrive | realvirtual.CAMTime | |
| MasterTime | realvirtual.CAMTime | |
| PLCCAMIsFinished (defined in realvirtual.CAMTime) | realvirtual.CAMTime | |
| PLCCAMIsRunning (defined in realvirtual.CAMTime) | realvirtual.CAMTime | |
| PLCCurrentCAMTime (defined in realvirtual.CAMTime) | realvirtual.CAMTime | |
| PLCScaleCAM (defined in realvirtual.CAMTime) | realvirtual.CAMTime | |
| PLCStartCAM (defined in realvirtual.CAMTime) | realvirtual.CAMTime | |
| StartCamWhenFinished (defined in realvirtual.CAMTime) | realvirtual.CAMTime | |
| StartOnMasterPosGreaterThan (defined in realvirtual.CAMTime) | realvirtual.CAMTime | |
| StartTimeCAM() (defined in realvirtual.CAMTime) | realvirtual.CAMTime | |
| TimeColumnNum | realvirtual.CAMTime | |
| UseColumnNames | realvirtual.CAMTime | |
| UseColumnNumbers | realvirtual.CAMTime | |
